resetare indicator ulei E39 facelift
aditzzaa
Ce an de fabricatie? Daca e facelift se reseteaza din obc, daca e prefacelift se reseteaza altfel...
Pt. facelift:
BMW Oil Service reset for 2001 ~ current
No need for reset tool for 2001+ model by: Moko
BMW insp. reset
- Iginition OFF (POS 0)
- Press and Hold the trip odometer button while turning key to position 1 (ACCESSORY)
- Keep the button depressed (about 5 secs.) until you see "Oil Service" or "Inspection" with "Reset" or "Re" in the display
- *Note: On vehicles with "High" cluster, you will also see the amount of fuel (in litres) remaining until next service
- Press the button again and hold for approx. 5 secs. until "Reset" or "Re" flashes
- While the display is flashing, briefly press the button again to reset the Service Interval. After the display has shown the new interval you should see "END SIA" for about 2 secs.
Note that if the "Reset" or "Re" does not flash, then you have not met the minimum consumption level and cannot reset.
Pt. prefacelift:
1) If you have a reset tool then turn your car key to Position II but do not start the car.
2) Turn the cap counter clock wise on the Data Link Connector and insert the Reset Tool
3) Follow the instructions of your reset tool, different models may have different fuctions however they all create a short in PIN 7 to PIN 19 for a given amount of time.
# OIL Service Reset requires pin 7 and 19 to be closed for 3+ seconds
# INSPECTION Service Reset requires pin 7 and 19 to be closed for 10+ seconds
4) Once done, remove the reset tool and close the cap .
5) Your dash should light up with green lights at this point.
If the light did NOT reset after the above steps then you might be reseting Oil Service however an Inspection Service is needed.
Deci tb sa conectezi pinii 7 si 19 ai mufei din compartimentul motor.
http://img205.imageshack.us/img205/8489/reset42db6auz5.th.jpg
Edited by Ciupanezu
  • 1 year later...
Pt. facelift:
BMW insp. reset
Pt. prefacelift:
si daca nam Reset tool ce mama racu fac? clasicele fire?
  • 1 year later...
