zatz
Contributors-
231 -
Everything posted by zatz
Sunet ciudat 730d F01
zatz replied to FreeStyleDaNuTzU's topic in Probleme tehnice si rezolvari Seria 7
Salut! Nici la mine nu merge link-ul. -
@DinuR cred ca va trebui sa dai motorasul jos, sa-l desfaci si sa cureti discul din el. Daca nu se rezolva, atunci cred ca va trebui inlocuit. https://www.e46fanatics.com/threads/diy-windshield-wiper-motor-replacement.704507/ "Low and behold the disc inside was covered in grease. I took a rag and wiped all the grease off the disc (first picture below) and the two little brushes (2nd pic below circled in red) that contact the disc. I reassembled the motor, plugged it back into the car to see if it worked, and what do you know, it works like new. So before buying a brand new motor, open your existing motor up and give it a good cleaning and see if that solves your problem. It can also solve the problem of having your wipers stop halfway across your windshield."
Ai dreptate, sunt de acord cu tine. Nu vrea nimeni sa strice topicul, dar eu am inteles din mesajul tau de mai jos ca doar ce ai pus tu in masina e recomandat de producator. A fost doar o clarificare din partea mea, fara intentia de a intra intr-o discutie contradictorie. Te salut! @BlshOp-VR6 bafta in noul proiect. O sa urmaresc cu drag evolutia lui.
Dar si 5w30 e recomandat de producator.
Frumoasa! Sa o conduci sanatos!
bmw g11 730d sau 740d ?
zatz replied to marian sandhu's topic in Probleme tehnice si rezolvari Seria 7
As alege 730d fara sa stau pe ganduri -
f10 Bataie motor F10 535xD N57D30B
zatz replied to dragosRDK's topic in Probleme tehnice si rezolvari Seria 5
Mi s-a facut pielea de gaina.. nasol.. acum stai sa cauti motor ok, nu te grabi sa iei ceva decat daca esti 100% convins ca e ce trebuie.. apoi, la fel cum au zis si colegii, schimba pompa de ulei si cuzinetii si tine-l in valorile de fabrica. Bafta si sa-ti iasa bine! -
Ma gandesc la doua lucruri: 1. Motorasul din cutia de transfer: 2. Bateria masinii.. pot aparea erori de genul din cauza bateriei invechite/slabe..
Daca masina se comporta normal si ai doar erori, ai facut o diagnoza cu ISTA?
Am dat mail acum vreo 2 saptamani la infobmw si m-a sunat un baietas sa-mi spuna ca se poate face activarea, dar imi face o proforma de vreo 400 de lei, ma duc la ABG si o achit si apoi trimit catre Germania sa-mi activeze . Am zis ca il sun eu.. daca e :))
@Mircea-Si arata belea volanul! Ai rezolvat pana la urma cu serviciile connected drive?
Salut! Cati km are masina? Dupa schimbul de ulei s-a facut si resetarea adaptarilor cutiei?
Apple CarPlay full display
zatz replied to andrei_alin2000's topic in Audio/Video/Navigatie/Electronica auto
+1 pentru @DragosVl -
masini frumoase M3 Competition G80 Isle Of Man Green
zatz replied to cristy7610's topic in Masina mea
S-a terminat smecheria!!! Superba! Sa o conduci sanatos! -
g30 Nivel antigel sub minim - low colant level
zatz replied to claudiu1892's topic in Probleme tehnice si rezolvari Seria 5
139000 km a mea. -
Ai dreptate, insa montarea transversala a motorului nu mai pune greutatea lui spre spatele rotilor de pe puntea fata (cum e la longitudinal), iar asta inseamna un compromis in ceea ce priveste dinamica de condus.
Retrofit Ceasuri Bord / Cluster Basic F30 la 6WA/6WB + NBT EVO?
zatz replied to Octa21's topic in DIY Seria 3
Salut! Pentru instrument cluster poti face retrofit la 6WA. Uite si link mai jos pentru a vedea cum se face: Pentru versiunea de NBT... judecand dupa controller, mie imi pare a fi NBTEvo Business cu ID6. Daca e asa, poti face activare carplay pe sistemul actual. Nu sunt sigur, insa daca vei vrea sa faci upgrade si la display (sa-l pui pe cel mare), cred ca va trebui inlocuit si HU-ul... dar nu sunt sigur de asta. -
Foarte frumoasa! Sa o conduci sanatos, @Mircea-Si!
Subtire rau... La banii astia le iau pe amandoua.
Masina mea actuala e prima masina cu tractiune integrala si, desi este extrem de stabila (cat am simtit eu cu mazga asta de pe jos), recunosc ca ii cam fura din feeling-ul acela de RWD :). In schimb, la o plecare agresiva de pe loc se simte foarte bine cum pune puterea pe asfalt. Concluzia, pentru a raspunde la topic, nu consider xDrive un "must have", insa poate fi util in anumite situatii.. totodata conteaza si cat de puternica este masina.. cai mai multi + RWD = mult mai usor sa pierzi controlul.
Asa va ramane, se vor cunoaste mereu diferentele. Cel mai bine mergi si vopseste bara la un tinichigiu bun sau un service.. e pacat sa o lasi asa, pentru ca nu arata prea bine.
Verifica daca busonul este inchis corespunzator. Daca da, atunci e probabil sa fie uzat si va trebui inlocuit. Avertizarea va disparea dupa vreo 1-2 zile de mers. Daca nici dupa inlocuirea busonului nu se rezolva, e posibil sa ai vreo pierdere/scurgere pe undeva care va trebui investigata.
Frumoasa masina! Sa te bucuri de ea!
Sa o conduci sanatos! Cum este, iti place? Poate lasi si o poza cand ai timp
