RaduXI
Contact Methods
  • Website URL
    http://
  • Gender
  • Location
    Bucuresti
    Bmw 325xi, 330xd
RaduXI's Achievements
-1
  1. Aici apar toate H7, daca observi sunt 4 buc (12V 55W) : http://realoem.com/bmw/showparts.do?model=...hg=63&fg=05 Sper sa ajute.
  2. Bucsele de la bascule sunt cauza cea mai frecvent intalnita. Lemforder sau Meyle.
  3. Frumoasa masina! Sa o conduci sanatos!
  4. Nu mi se par scumpi la 100 ron buc, exceptie facand cei defecti. Sunt colegi pe forum care cer si 50E pe bucata. Zi-mi si mie de unde cumpar cu 50 de ron, am cautat ceva vreme si n-am vazut un asemenea pret.
  5. Preturi pentru bare complete cu tot cu intarituri? Are senzori de parcare? Mc.
  6. Nu vad cum ai putea verifica km din functiile ascunse ale obc-ului, cred ca mai simplu e sa mergi la reprezentanta sa verifici km masinii (bineinteles daca are reviziile facute la bmw). Succes!
  7. Am gasit, sper sa te ajute: Instructions to access the hidden OBC functions: 1. Hold Trip Reset while turning ignition key to on position 2. OBC should show "Test" 3. Use Trip Reset to select function 19.0 that unlocks all the features 3. Wait for display to show "Off" 4. Depress Trip Reset for 1/4 second and release it 5. With no delay press Trip Reset several times to select one of the following function s BMW E46 On-Board Computer (OBC) Hidden Codes nr example description 1 Car Engine and cluster data 1.0 46nnn Chassis nr/VIN serial number (last 5 digits) 1.1 4nnn K-number 1.2 690236 Cluster Part # 1.3 045210 Coding (04)/diagnosis (52)/bus index (10) 1.4 1200 Week (12)/year of manufacture (2000) 1.5 09_160 Hardware (09) and software # (16.0) of cluster 1.6 Not used 1.7 04__44 CAN-version (04) KI-revision index (44) 2 (test) Cluster System Test - Activates the gauge drivers, indicators and LEDs to confirm function 3 SI Data 3.0 1098 Used fuel in liters since last SI (Service Inspection) 3.1 0231 Periodic inspection days; elapsed days (since last SI) 4 Momentary Consumption 4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km 4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour 5 Distance Gone Consumption 5.0 082 Average mileage; 082=8.2 liters/100km 5.1 0536 Calc. km to refuel (momentary distance to go) 6 Fuel Level sensor inputs in liters 6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters 6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters 6.2 0442+ Indicated value (44.2) and tank phase 7 Temperature and Speed 7.0 021+ Coolant/Engine temperature (2.1C) 7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135 7.2 + Engine speed / Current RPMs 1/min 7.3 + Vehicle speed / Current Speed in km/hour 8 Input value in HEX form 8.0 1d0+ System voltage ADC-Value Hex code 8.1 26C33C+ ADC Values HG left/HG right 8.2 0000 ADC Value brake degradation sensor (000=o.k.) 8.3 18C ADC Value outside temperature 9 Battery 9.0 140 Battery Voltage - 140 = UB 14.0v 9.1 242013+? 9.2 074_78+? 9.3 0011+? 10 Not used 11 Not used 12 Not used 13 GonG Gong Test 14 Not used 15 Status cluster I/O-ports (bit codes) 0=low; 1=high 1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0 Status Digital Outputs (bits) 0=inactive, 1=active 1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot 16 Not used 17 Not used 18 Not used 19 Lock Status; unlocks functions in range 3-18 19.0 L-On/L-Off Unlock: press button when "L-Off" 20 Not used 21 Software Reset; reset OBC settings 00 End of test Am iesit acum sa verific pe masina daca acel k-number (pozitia 1.1.) e numarul de km...nu are insa nici o legatura, sunt 4 cifre care nu stiu ce reprezinta. Referitor la afisajul tau pe pozitia 1.2 cu 690xxx, daca te incanta cu ceva cluster part #-ul meu este cu 691xxx. :twoup:
  8. pozitia 1.2 este cluster part # si incepe cu 690xxx. incearca pe 1.1 si vezi ce numar iti afiseaza. exista o lista cu toate datele oferite de obc, le am pe hartie, iti caut in format digital si iti afisez.
  9. costi301 ii ofera un 320d la schimb, de aceea se vad 23xk. Si eu am fost derutat la prima vedere. :)
  10. "Epoca", "primul proprietar" si "model 2008" (cand e inmatriculat la jumatatea lui 2007) ma lasa rece. :twoup:
  11. Incearca sa cuplezi in marsalier si verifica fiecare senzor ca lucreaza. Pui degetul pe senzor si vei simti niste intepaturi fine, de asemenea vei auzi niste pocnituri, daca nu simti nimic inseamna ca senzorul respectiv este defect sau mufa nu face contact. Verifica si mufele, dar cu grija sa nu le rupi (trebuie curatate de noroi inaintea demontarii). Poate ti-a schimbat vreun senzor cu unul defect.
  12. ET 20 este recomandat la e39 , la e46 iti ies in exterior...deci ating aripa.
  13. Se fura si inscriptionate, daca au sistem antifurt au grija sa le sparga...in acest fel se incurajeaza "comertul" second hand.
