roby_m
Everything posted by roby_m
  1. Casetofonul vandut. Adaug cauciucuri iarna 215/55/16 Continental 5mm. Poze la diverse piese de vanzare. http://s7.postimage.org/egvfyn3wn/IMG_4605.jpghttp://s11.postimage.org/wujlo0icf/IMG_4606.jpghttp://s16.postimage.org/76i66gfi9/IMG_4607.jpghttp://s10.postimage.org/h1e8b73ol/IMG_4608.jpg http://s8.postimage.org/cx3m89jup/IMG_4609.jpghttp://s13.postimage.org/tp2uufxcz/IMG_4610.jpghttp://s7.postimage.org/4adno64qv/IMG_4611.jpg http://s9.postimage.org/6yg7am9y3/IMG_4612.jpghttp://s8.postimage.org/q8ewhva9t/IMG_4613.jpghttp://s14.postimage.org/3vccqf6sd/IMG_4614.jpg http://s9.postimage.org/a0g6c21uj/IMG_4615.jpghttp://s9.postimage.org/wu94laqjf/IMG_4616.jpghttp://s12.postimage.org/fp4cep12x/IMG_4618.jpghttp://s14.postimage.org/kq4isptlp/IMG_4626.jpghttp://s13.postimage.org/e4rc9jesj/IMG_4627.jpg http://s12.postimage.org/c1ol8msvt/IMG_4619.jpghttp://s17.postimage.org/9adtgjh7v/IMG_4620.jpghttp://s7.postimage.org/duxqufb0n/IMG_4621.jpghttp://s7.postimage.org/gin74s41z/IMG_4622.jpg http://s13.postimage.org/6wowbqgtf/IMG_4623.jpg http://s11.postimage.org/a2fc3p9zz/IMG_4624.jpghttp://s7.postimage.org/4pufxodxj/IMG_4625.jpg
  2. http://bmwfans.info/parts/catalog/E36/Sedan/USA/M3_3.2-S52/LHD/M/1997/browse/vehicle_trim/centre_console_cubbies/
  3. Te pot ajuta eu cu un vasc.
  4. Cred ca au cam 4mm. Le pot face poze peste cateva zile, daca esti interesat.
  5. termostat Behr nou 318is m44 - 100lei vascocuplaj - 90lei alternator - 70 lei (2 bucati) injectoare 318is -150 lei injectoare 316i - 100lei bobina inductie - 70lei fise 318is - 95lei _chiulasa_ completa 318is - 800 lei baie ulei - 100lei admisie m43 - 100lei bloc motor complet 316i m43 - 200lei senzori motor 316i m43 - 60lei buc furtune sistem racire - discutam suport plastic roata de rezerva - 20lei aeroterma fara clima - 40lei eletrovalva - 40lei cauciucuri Pirelli 225/50/16 5-6mm - 120lei 2 bucati cauciucuri de iarna Fulda 185/65/15 - 280lei 4 bucati casetofon bmw OEM cu fct MODE - 90lei 0766221688
  6. Cristi, asa ai si tu pe masina, cu abtibildul asta? La mine asa e si din ce am citit aici uleiul s-ar gasi doar la reprezentanta. Asa e?
  7. Clapeta actionata manual merge usor? Bazaitul respectiv la mine nu se aude...
  8. Nu am idee, dar cauta pe net niste poze cu m40-uri. Uite una http://www.strathspey.co.uk/unixnerd/m40.jpg Si niste poze cu trecerea...chiar daca e alt motor, traseul e la fel. http://forums.bimmerforums.com/forum/showthread.php?t=1640884 (cred ca-ti trebuie cont ca sa poti vedea pozele). Care e problema de fapt, agata pe undeva sau nu merge bine?
  9. La scapari de gaze m-am referit. Alte imbinari sunt sub partea superioara a admisiei, la intrarea, respectiv, iesirea din rampa de injectie.
  10. Nu are treaba lichidul de servo cu asta. Mai poti verifica si evcuarea, poate are scapari.
  11. Dar furtunasele pe care vin colierele? Cel mai bine fa o inspectie pe sub masina.
  12. Acum 2 ierni am experimentat ceva asemanator, pornea extrem de greu si dupa ce am schimbat minunea aia totul a revenit la normal. Parca si vara pornea o mica idee mai greu..dar poate ma insel. Oricum, daca ai posibilitatea verifica-l.
  13. Vara cum porneste? Daca tot nu foarte repede, verifica regulatorul de presiune in rampa de injectie.
  14. Asa face cand e bateria moarta. De ce nu te duci sa verifici?
  15. 1. Masoara tensiunea pe baterie. 2. Verifica si cablurile care vin pe langa balamaua portbagajului.
  16. Io zic sa nu-i mai pui deloc ulei, ca se pare ca ai un motor alergic la asa ceva.
  17. EWS nu se poate elimina. Cauta pe cineva cu un tester sa analizeze unde apare problema concret. Daca e din modulul EWS, atunci va trebui sa cumperi un modul EWS impreuna cu cipurile din chei (ale masinii donatoare). In fiecare cheie e cate un cip care comunica prin antena de pe langa contact cu modulul EWS; astea sunt "la pachet". Apoi dupa ce ai luat "pachetul", el va trebui sincronizat cu ajutorul unui tester care poate face asta (DIS).
  18. Cumpar buton inchidere usi e36. S-a pus pe masinile din SUA. Piesa 2 http://bmwfans.info/...ous_switches-3/ http://i.ebayimg.com/t/BMW-E36-CENTRAL-POWER-DOOR-LOCK-SWITCH-318-320-323-325-61318368931-/00/$(KGrHqQOKj4E3LN48Up,BNzn0otzKQ~~_35.JPG 0766221688
  19. Daca culoarea lui e schimbata, din rosu in negru, mai bine il schimbi. E vreo 23lei litrul. Ulei ATF (ex Mobil 220).
  20. poate sa fie si tamburul de vina. desfa-l si inspescteaza-l.
