327 -
Everything posted by WeTe
Cumpar piese Seria 7 725tds E39 an 97
WeTe replied to Tyby_G's topic in Cumparari piese si accesorii BMW
0749899121 - te poate ajuta cu ceva piese pt masina ta p.s este e38( seria 7) nu e39( seria 5) -
The Check Control in the instrument cluster of the E38 BMW 5/7series hides some secrets. Here is the procedure how to unveil them and how to unlock the system to get access to all tests: • Turn ignition to pos. II • Push right button in the instrument cluster and keep it pushed. You will first see "Check Control OK", some seconds later you will see "Test Nr.01" • Push the left button on the instrument cluster to see the car's identification number. Add the 5 digits together and write down that number, you will need it for unlocking all the functions. Example: DG23278 will lead to 2+3+2+7+8 = 22 • Push the right button until you see "Test Nr.19" • Push left button until you see the number that is equal to the one you calculated above • Push right button again Now you will have unrestricted access to Test No.3-21. If you made an error in the procedure mentioned above, Test No.3-21 will only display Lock:ON Most of the tests are self-explanatory, and here is a first listing (as far as I can recall): 1. Display Car's identification number, HW/SW version, date of construction 2. A very beautiful instrument test 2. Current consumption (liters/100 km) 3. Current consumption (liters/hour) 4. Average consumption (liters/100 km) 5.Current range 6. N/A 7. Average fuel in tank (liters) 8. Current Speed (kph) 9. System voltage at Term. "R" (Battery Voltage) 10.Country/Language (UK, Spa, Ger, Jap, etc.) 11. Units am/pm 12. Average Speed 13. ETA 14. Date of Software Mask 15. Production Diagnosis 16. "" 17. Display Vehicle Specific Data 18. Alarm Changeover (cont. vs. intermittent OBC chime) 19. Lock/Unlock 20. Correction factor for fuel consumption (nicht ändern!) 21. Reset all defect codes 1. several numbers and data 2. [Dispay Test] 3. VBR: x,x (liters/hr) 4. RW-VBR: x,x (liters/100 km) 5. RW: x (km) 6. N/A 7. TMTL: x,x (liters) 8. V: x (kph) 9. UB: xx,xx (V) 10. LAND: 2=USA, 3=I, 4=E, 5=J, 6=F, 7=CDN, 8=AUS/GOLF, 0=D, 1=GB 11. EINHEIT 1: B3, B4, B5, B6, B7, B8, B9, BA, BB, BC, BD, BE, BF, B0, B1 EINHEIT 2: [similar to above, I didn't want to mess with it] 12. VANK: xx,x (kph) 13. ANK:xx:xx 14. ROM: 15. DIAG: 01 01 000 E3 16. PORT: 01 101010000, 02 101010000, 03...etc 17. PROM: 00 12, 01 37, 02 18, 03 E6, 04 02, 05 B3, 06 FF, 07 7E 18. HORN: DTON or [DTON flashing] 19. LOCK: ON 20. KVBR: 1000 21. RESET?
la e38 http://img180.imageshack.us/img180/697/mmx0215.jpg Uploaded with ImageShack.us
n-am spus ca in Cj , de gaseam in zona nu umblam o juma de an descentrat, in PL mi-am facut. Am auzit ca pe Campinei-Plevnei ar fi ceva unguri ce apreciaza si munca dar si banu'.
dai jos rotile de pe masina spala jantele pe interior apoi echilibreazale la o firma ce are aparatele calibrate, o jumate de an am tot echilibrat in Cj si nu dispareau acele vibratii pana am gasit o vulcanizare ce nu-si bate joc de clienti. Ocoliti Auto Marinero de pe varianta manastur-zorilor (din Cluj) , lucreaza ieftin dar degeaba, dupa 3 echilibrari consecutive in aceeasi zi am aflat ca recordul a fost de un client ce a revenit de 11 ori pt echilibrare, La fel si vulcanizarea-spalatoria de pe pod ( tot manastur-zorilor ) lucreaza foarte scump dar la fel de prost.
73 ooo in 5 ani din care 2 in ro, o fi masina de garaj, sau de duminica. Poate ca am idei preconcepute dar cand aud de ...mondialu, internationalu, fenomenalu , cocalaru, samsaru. . .. . primul meu gand se duce catre tarafTV. manyeleTV si sa nu uitam de 0tv.
a 'murit' bateria, in momentul in care dai la cheie se aude ticaitul acela? si bordul incepe sa palpaie? incearca sa-i dai curent de la (un taximetrist binevoitor) alt atelaj. ai borne pt + - si la motor.
elecroventilator e38 FL - daca se poate doar modulul- ceasurile de bord (EXCLUS uk- o poza daca se poate la pixeli)
la 5800 lei/an impozit cred ca nu
Este frumos sa ne bucuram impreuna de aceastĂŁ revista si vreau sa le multumesc celor care au facut si fac inca posibila aparitia ei. O seara faina in continuare.
cred ca ai uitat un 0, daca nu atunci cred ca mecanicu ala intradevar ii 'foarte bun'
a mai fost unu care cerea pe un 728 /'99 5000euro tot cu volan pe dreapta si recomandarile au fost tot DEZMEMBRARI. ( cica avea jante de 2-3000 euro dupa socoteala lui si era indreptatit sa ceara atita :twoup:) prafu' ii de 3 dejete in romanica, orienteazate putin , apreciem gestu' tau dar sansele sunt aproape nule la pretul cerut. speranta moara ultima , bafta.
no ce mai conteaza cum ii zice OZ RACING , OZ Parking principalu' ca'i incaltata masina :twoup:
1.Merita sa te duci personal daca au pe stoc piesele de care ai nevoie ( poti negocia orice pret iti dau ei la telefon) http://img708.imageshack.us/img708/8673/dogarugroup.jpg 2. pieseautosecond@yahoo.com (Dl. Ion Dumitru - din ALBA-iULIA- are vreo 4-5 7-er gata dezmembrate) foarte de treaba tipu'. Poti sa-i spui ca ficioru cu 7er-ul de cluj( cu nr de polonia) te-a trimis la el si poate indulcesti si mai bine preturile.
completare : 5. presiunea in pneuri sa nu depaseasca 0.73 BAR 6. porti pantofi cu 2 numere mai mici ( vei simti cand apesi pedala)
Vand jante originale BMW pe 17+anvelope
WeTe replied to Raul69's topic in Vanzari piese si accesorii BMW
DA, sunt functionale link-urile. -
0749899121 stiu ca avea ceva senzori pt seria 3 si cred ca la 50 lei bucata. poate ai noroc .
eu am dat o diferenta de 120 lei pt cel cu semnale albe ( bonus cele de pe aripile fata, lucas-uri) si cu 100 am cumparat semnale albe fata. am 2 stopuri fumurii insa nu stiu daca sunt facelift sau daca te ajuta cu ceva http://www.bmwclub.ro/forums/index.php?s=&...st&p=932784
ai de la mine 5 ***** pt autobuzu' tau :). este dublu vanos ?(B52B28TU ?) am citit tot topicul, dar nu am observat sau poate ca am scapat vreun post in care se specifica acest amanunt.
la e 38 daca am inchis masina din cheie dupa 20 sec se blocheaza absolut tot si nu mai merge sa deschid nimic din interior, Mi-am uitat si eu 2 seturi de cheie in portbagaj si am chemat un tip ce lucra la reprezentanta BMW. A venit cu tot felul de chestii si dupa 1 ora a reusit sa-mi deblocheze masina cu un aparat ( ca si in filme ) ca un fel de pistol cu 2-3 lamele. am platit 150 zloti ( 150 lei - 250 era pretul cu chitanta) fara chitanta. Am fost multumit ca pt a 3 cheie trebuia sa fac 1200 km pt cea de-a 3 cheie ( care era acasa eu fiind plecat din tara). Inainte am chemat un hot si nu a reusit sa-mi deblocheze usile , a incercat sa actioneze la butonul de la usa si cel de la inchiderea centrazilata cu o tija pe la chederul de la usa. Dupa 1 ora s'o lasat pagubas. Recomandarea mea este sa chemi un tehnician de la BMW sa nu distrugi ceva care sa te coste mult mai mult decit o interventie de la un meserias.
0749899121- are preturi foarte bune , cred ca la 50 lei bucata ( nu 50 euro !!!! )
Alternatorul, am pus un set de perii noi si am scapat de problema la un VW care se manifesta la fel ca in descrierea ta.
http://www.brickhousesecurity.com/car-camera.html
