Am scris la misto "deodorant :) , e o " potiune magica " pentru curatarea motorului .   edit: Am citit pe un forum strain mai in amanunt .   ================================================================================     Just for general clarification.      Sea Foam Motor Treatment used in Crankcase Oil All Gasoline and Diesel, Rotary style engines    Sea Foam Motor Treatment is a Blended Petroleum Product, NOT A CHEMICAL and is widely used as an old oil residue reducer and moisture drier in any oil crankcase.    Sea Foam Motor Treatment is most commonly used as a pre service, old oil residue re-liquefier / cleaner / diagnostic tool, and moisture drier, and is also used as an after service additive. Sea Foam Motor Treatment does NOT add significantly to oil volume, so removing oil is NOT required for use, when used according to printed directions on the product container.    1. As a PRE SERVICE CLEANER for old oil residue, (sticky rings or valve train noise, diagnostics), pour 1 ½ ounces of Sea Foam Motor Treatment into the engine oil crankcase for EACH quart of crankcase oil capacity including filter. (Diesels use 1 pint Sea Foam to 4 gallons of oil, please.) Drive a MINIMUM of 30 minutes/miles, MAXIMUM 200 miles, (Diesels 1 hour drive/run time MINIMUM) and then do your oil change service (LOF). This is the process of safely/slowly re liquefying the old oil residue so contaminants may flow and be filtered. This also makes your old oil dirtier, quickly, so a LOF service is necessary when the oil gets dirty. Great for Turbo & Supercharged applications where hot oils deteriorate so quickly due to heat, those residues NEED CLEANING. (LOF = Lube oil & Filter service = OIL CHANGE).    2. As an AFTER SERVICE ADDITIVE into fresh oil, nearly fresh oil, or oil (used condition) that is NOT ready to be changed (by mileage), put 1 ½ ounces Sea Foam Motor Treatment into the crankcase per quart of capacity as described above, then SELF SET a program to MONITOR your oil for proper level, color and clarity on a mileage, timed, or event basis (like every time you add fuel, etc.) to determine when an oil service is necessary. (LOF) When the oil gets dirty, CHANGE IT!    Sea Foam Motor Treatment will safely and slowly re liquefy old oil residue, This will usually make your oil need changing BEFORE your normal scheduled LOF service. Only your monitoring of the oil for color and clarity can tell when it is time to do LOF (oil change service), or 3,000 miles, whichever comes first.    Synthetic oils, both blends and 100%, were engineered and are manufactured to be 100% compatible with petroleum based oils, all brands, and vice/versa. Without compatibility, oil manufacturers and engineers would be liable for the results of mixing non-compatible lubricants.    Check your oil; monitor its level, color & clarity to determine the need for an LOF service! Change your oil when it gets dirty!    Technical Services Department July 2008 DD   Sea Foam Uses in Fuels    Sea Foam Motor Treatment #’s SF-16 (16 ounce), SF-128 (gallon container) and  SF-55 (a 55 gallon drum) is registered with the EPA as a fuel additive for use in all Gasoline, all Ethanol fuels, Gas/oil mixes & ALL Diesel fuels. Including all brands and qualities of available fuels.    When added to these fuels, Sea Foam Motor Treatment was specifically designed to Safely do five (5) simple, yet important, tasks for you, SIMPLY. They are: 1. Sea Foam Motor Treatment is a 100% blended petroleum product. That means Sea Foam is OIL, so adding Sea Foam to ANY fuel, adds lubricity for Fuel systems, Induction systems (Including Drawn through Supercharged applications), upper cylinders, fuel pumps, and related fuel system & exhaust (Turbocharged) components. Ethanol fuels need LUBRICITY, Sea Foam supplies that Lubricity! All common available fuels lack “Protecting” lubrication.    Advantage: “Sea Foam”.    2. Sea Foam Motor Treatment contains an engineered oil that dries fuel moisture. Moisture breaks down into its basic components of hydrogen and oxygen when Sea Foam Motor Treatment is added to any of the above listed fuels. This allows Sea Foam Motor Treatment to help eliminate problems caused by moisture, like diesel fuel gelling and Ethanol “Phase Separation”. Ethanol absorbs moisture, Sea Foam dries it! Advantage: “Sea Foam”.      3. Sea Foam Motor Treatment contains an oil based high detergent fuel residue cleaner. Using Sea Foam Motor Treatment in your fuel system makes that old fuel residue safely back into liquid. Old fuel residues become a “non issue”, allowing contaminants to be filtered, as engineered by the system manufacturer.  Advantage: “Sea Foam”.      4. Sea Foam Motor Treatments exclusive formula is blended specifically to clean carbon out of the engine as the engine is run. This is accomplished by our cleaning oil formula eliminating old sticky oil residue that holds carbon and allows that carbon dust to flow out of the engine dust particle by dust particle. Advantage: “Sea Foam”.    5. Sea Foam Motor Treatment adds volatility to fuel and slows down the rate at which that fuel looses its ability to properly burn. When added to fuel and the fuel is in properly sealed containers or fuel systems, per printed container instructions, Sea Foam Motor Treatment is a fuel stabilizer for up to 2 years. Always run the engine for a long enough period of time to assure the entire system is protected. Advantage: “Sea Foam”.    Technical Services Department Sea Foam Sales Company Updated July, 2008 DD
