23xwe
Everything posted by 23xwe
  1. Salut, Un pret pentru 225/45/17 - Bridgestone - SH - runflat - /bucata, /pereche. Multumesc
  2. Salut, Un pret pentru 225/45/17 - Bridgestone -SH - runflat - /bucata, /perechea. Multumesc
  3. Rog ajutor identificare an fabricatie piesa [media]https://picasaweb.google.com/rtrsorin/FollowMeHomeBmwE90#5610127570385865634[/media ]My link https://picasaweb.go...127570385865634
  4. http://www.desprealcool.ro/zerolamie/http://www.motorstory.ro/wp-content/uploads/2011/04/Aplicatia-ZeroLaMie.jpg
  5. 23xwe
    AM DAT IN RADAR
    cam asa face un om cu minte care a invatat din greselile sale sau ale altora si care cunoaste limitele prevederilor legale si ale portofelului
  6. http://www.youtube.com/watch?v=1iYlx1CEasg
  7. http://www.youtube.com/watch?v=hSHkBrhixD8
  8. Pot exista probleme permanente sau sporadice in ceea cepriveste repozitionarea oglinzilor BMW E90, in special cele situate in parteapasagerului. In mare parte se datoreaza conectorilor, dar pot fi si altecauze: "SI B51 36 08 Body Equipment April 2009 Technical Service This Service Information bulletin supersedes SI B51 36 08 dated February 2009. designates changes to this revision SUBJECT Outside Mirror Moves when Unlocking the Vehicle MODEL E90, E91 (3 Series Sedan andSports Wagon) produced up to 9/2008 and equipped with power front seats, optioncode SA459 SITUATION When unlocking the vehicle via the remote key fob or the centrallocking button, the driver's side outside mirror moves unexpectedly.This condition occurs intermittently. When the mirror moves, it seemingly goesto a random position. Pressing the seat memory button typically will return themirror to the stored position. CAUSE When the unlock signal is sent to the car, a mirror position self-check isperformed. One of the factors in determining the mirror's present position isan expected resistance value in the circuit. Due to a higher than expectedresistance, the Footwell Module (FRM) calculates the mirror positionincorrectly. The mirror is then moved to what is believed to be the correctposition. The unexpected resistance value is caused by one of the following: * Corrosion on the LIN-bus connection at the mirror, switch block, or FRM * Poor connection at the mirror, switch block, or FRM * Damaged mirror electronics CORRECTION Repair or clean the appropriate connections. In isolated cases, the mirrorelectronics need to be replaced. PROCEDURE 1. Reproduce the customer complaint by locking and unlocking with theremote key fob or central locking switch. 2. Remove the driver's side door panel per Repair Instruction RA 5141 000. 3. Remove the window frame trim panel, which covers the mirror connection, perRepair Instruction RA 51 32 160. GRUSB5108-29 4. Unplug the connector from the mirror. 5. Inspect the connector for any damaged or poorly fitting terminals. 6. If any damage is found, repair or replace the connector and/or terminals. 7. Remove the terminals one by one, and clean thoroughly with electricalcontact cleaner. 8. Apply a small amount of dielectric grease to the contact side of theconnector. 9. Reinstall the connector. 10. Attempt to reproduce the customer complaint again to determine whether theproblem has been resolved. 11. If the problem has not been eliminated, continue with the followingprocedure. 12. Inspect the connector at the door switch block to check for damaged orpoorly fitting terminals which lead to the mirror, as well as those leading tothe FRM. These are pins 1, 2, 3, 10, 11, and 12. 13. If any damage is found, repair or replace the connector and/or terminals. 14. Remove the terminals one by one, and clean thoroughly with electricalcontact cleaner. 15. Apply a small amount of dielectric grease to the contact side of theconnector. 16. Reinstall the connector. 17. Attempt to reproduce the customer complaint again to determine whether theproblem has been addressed. 18. If the problem persists, remove the mirror cap per Repair Instruction RA 5116 040. 19. Inspect the wiring of the mirror electronics for damage or poorconnections. GRUSB5108-30 20. Unplug the mirror electronics (1) and clean the connection (2) on the backside with electrical contact cleaner. 21. Attempt to reproduce the customer complaint again to determine whether theproblem has been addressed. 22. If the problem persists, replace the mirror electronics for the driver's sidemirror for vehicles not equipped with auto dimming/power fold mirrors(SA430),or the complete mirror for those equipped with auto dimming/power fold mirrors. PARTS INFORMATION Part Number Description Quantity Locally sourced Electrical contact cleaner 1 83 23 0 149 149 Dielectric grease 1 67 13 6 972 536 Mirror electronics – driver's side with SA459 1 – if necessary 51 16 7 189 977 Mirror – complete driver's side with SA430 1 – if necessary WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty. Defect Code: 51 16 36 41 00 Labor Operation: Labor Allowance: Description: 51 41 000* Refer to KSD R&I door trim panel for left or right front door +51 16 540 Refer to KSD R&I mirror cover for left or right front door – if necessary 51 99 000 Work Time Work time for testing and cleaning connections. *Main Work - use this labor operation number when this is the only repair beingperformed, or if this is the main repair when performed along with otherrepairs at the same time. If this is not the main repair, refer to KSD for theassociated (+) labor operation code. Sublet Code 4** $2.00 ** Reimbursement of up to the amount listed may be charged to sublet code 4 forthe Contact cleaner and Dielectric grease required to perform this repair.Claiming this part number outside of sublet code 4 will result in a delayed ordenied claim payment. [ Copyright Ë 2009 BMW of North America,LLC ]
  9. http://www.youtube.com/watch?v=P9KPJlA5yds
  10. Asa cum a spus si Iulian am postat pentru colegii incepatori si care sunt la primul BMW. Cine a avut si inainte deja stie efectul. Era mai interesant daca E90-ul respectiv avea si trapa.
  11. http://www.youtube.com/watch?v=NjQCxtscWoo&feature=list_related&playnext=1&list=PLFFF8B1C3A3BC112F
  12. La 320i, luat de nou, in 40000 km nu am avut vreo problema grava legata de motor, articulatie, mecanica in general. In patru ani s-a ars o siguranta la inchiderea centralizata si am avut o eroare la capsa de la baterie. Consum real: - in Bucuresti 13-16l / 100km - in afara cu aer conditionat 9-11,5l / 100 km. Am condus si 320d si mi s-a parut cam tractoras dar are cuplu pe care il simti fata de 320i. Poate sunt eu subiectiv pentru ca nu imi iau decat motoare pe benzina.
  13. Ce putem face noi, membrii acestui club, pentru a schimba sau imbunatati imaginea posesorilor de BMW in Romania? Pareri, sugestii, discutii. Este prea mare efortul pentru a dona jucarii, articole vestimentare, jocuri unor case de copii?
  14. Multumesc lui Robert TAU si lui MAS, dar si baietilor mentionati pe respectiva harta si care m-au ajutat ieri seara in Constanta. Consider ca este utila atunci cand ai o problema intr-un oras, altul decat cel de domiciliu sau de resedinta. Problema, simpla pentru unii, dar complicata pentru altii (inclusiv subsemnatul), a constat in blocarea pe la ora 21 intr-o parcare a trei usi si imposibilitatea deschiderii din exterior si interior. Datorita sfaturilor si discutiilor purtate telefonic cu cei mentionati mai sus am reusit sa identific si sa rezolv problema. Pe scurt am reusit sa deschid cu cheia metalica usa de la sofer si sa inlocuiesc temporar o siguranta arsa cu una buna de la claxon. Astazi la reprezentanta BMW Constanta curentul era cazut, iar la benzinarii nici in seara respectiva si nici astazi nu am gasit tipul de siguranta necesara. Am reusit sa cumpar cate trei sigurante de amperaj diferit de la reprezentanta FIAT unde baiatul de la piese era chiar membru club BMW, posesorul unor frumoase E36 cabrio verde si E46. Cu riscul de a ma repeta: Multumesc tuturor celor implicati.
  15. Se poate muta la probleme tehnice si rezolvari. este siguranta 08 sursa e90post.com: "I have a 335i e92 (2008-05 according to the door sticker), and the fuse layout does not seem to be the same as layouts I've seen for earlier models. Here is my fuse layout. If yours is the same, then the Cigarette Lighter is fuse 08, (on the chart, it's the bottom right-most icon). It's a 20 Amp (yellow) mini-fuse. I had wondered why so high, then I realized that non-e92's actually have 4 (four) count-em four cigarette lighters to my two. Mine are both in the center console, but other e9x models have a third for the back seat and a fourth for the trunk. I scanned in the fuse box chart the First Thing, knowing I'll loose it very very soon, and then colored it so it's easier to read. I just wish I could find some Legend of what all the symbols meant! Edited: Note that not all 2008 e90,1,2,3's have the same fuse box. (Anyone know the actual time and model where one is different than the other?). For example, look at the orientation of the little red "H" shaped plastic fuse-removal tool that's provided. Some have it horizontal, some vertical (like my 05/2008 e92). Keep that in mind when you are looking at various DIY's fuse suggestions."
  16. Nu mai functioneaza bricheta. BMW 320 E90 Stiti care este siguranta aferenta brichetei? Tabloul de sigurante se afla in spatele torpedoului.
  17. Claxonul este foarte prost dpdv acustic. Vopseaua aceasta de ultima generatie se zgarie foarte usor. Parbrizul de calitate foarte proasta.
  18. http://ec.europa.eu/consumers/dyna/rapex/r...archives_en.cfm Pe acest link puteti verifica daca produsele detinute de voi (masini, telefoane, televizoare, etc) au facut obiectul unei campanii de rechemare in service.
  19. Used BMW 6-series buying guide The BMW 6-series is looking increasingly like a secondhand bargain - here autocar.co.uk guides you through the buying process. Our expert advice comes from Dermot Dromey, owner of Southampton-based independent BMW servicing specialist Bartley's. See the BMW 6-series used buying guide pictures "I'd buy a 3.0-litre, six-cylinder petrol," he says. "They seem to be more reliable than both the V8 and the diesel." Body Faulty electric window sensors can cause the electric windows to close slowly - or not at all. Look out for corrosion or discolouration on the window chrome too. But there shouldn’t be any sign of rust. If there is, it’s bound to be a sign of a poor repair. Electrics If it has a head-up display, be sure that it works; malfunctions can result from damage to the car’s wiring loom. Also be aware of auto headlights that don’t switch off and gearbox paddle shifters with bad connections. Suspension There was a recall about rear shock absorber mounting failures in 2006. Another recall in 2008 warned against the rear axle carrier failing, so be vigilant for both. Rear knuckle joints should be changed at 50,000 miles, costing about £300 Wheels and tyres The run-flats fitted to 6-series as standard are prone to punctures. They’re impossible to repair, don’t last long and are £300 each to replace. And they can do real damage to a wheel when they deflate. Best advice? Junk them and fit ordinary rubber. Engine If you’ve got a ‘check engine’ light on your dash, it could be that your camshaft position sensors need replacing. Leaking oil lines to valve timing units have been reported, as have cracked hoses, oil caps and valve covers.
  20. Am un E90 320i 2007 si as dori sa stiu daca se poate monta cruise control OEM si ce modificari trebuie facute.
  21. daca esti ofiter de politie ar trebui sa stii ca la ora asta sunt la o bere cu prietenii, nicidecum in fata procurorului. Astia nici in faza de incetare nu ajung, eventual la NUP si o palma dojenitoare pe umar. Ma scuzi putin. Aveau asupra lor 9 perechi de oglinzi dintre care ale mele cred ca sunt cele mai ieftine, deci prejudiciul creat este maricel. Plus ca sunt si alte sesizari din urma pe care le-au recunoscut. Salut! Si eu stau in zona si am antifurturi. Respectivii le-au spart dar nu le-au luat. S-a dat NUP in acest caz de catre un magistrat stimabil care si-a batut joc de munca politistilor de la Sectia 11! Daca ne poate ajuta colegul de forum cu numele acestui procuror. Personal ii voi face plangere.
  22. A fost "razie" pe Nerva Traian si adiacent (cel putin 4 masini E90 au ramas fara + Audi A5). Eu am avut antifurturi negre si n-au observat. Nu le-au luat dar le-au crapat pe ambele.
  23. Votat Bridgestone! Masina este echipata cu Bridgestone Potenza – Vara si Bridgestone Blizzak - Iarna (mai putin iarna aceasta deoarece am circulat cu o alta masina). Am avut pe E36 Continental SportWinterContact si mergeam super nevand dsc/dtc/etc.
