srb_alex
    7
Everything posted by srb_alex
  1. Si eu am cumparat evo flat recent si tot asa nu-mi calca bine cel din dreapta dar sunt multumit cum sterg.
  2. Pai nu ai fost la un tester sa vezi presiunea turbinei?
  3. Dupa spusele proprietarului 210000km
  4. Eu cred ca ai probleme cu una dintre electrovalve sau chiar amandoua (EGR + Turbo), le-ai verificat sa vezi daca functioneaza? Sau poate turbina ta este pe duca daca zici ca si fluiera.
  5. Eroarea 4530 este exact senzorul presiune admisie Uite o schema electrica si poate te ajuta si la ce piesa sa te uiti : http://wds.spaghetticoder.org/en/svg/sp/SP0000020743.svg?m=e46 4530 4530 (1297) manifold pressure regulation I've got the following error Code: 4530 4530 (1297) manifold pressure regulation Error counter: 30 Logistic counter: 40 1. Umweltsatz Mileage 133200 km mean engine speed 2206.59 rpm coolant temperature 62.17 deg C maximal rail pressure of the last 10ms 677.43 bar injection mass index value without mass balance control 23.24 mg/cyc intaken air mass per cylinder 541.94 mg/Hub value of boost pressure 1102.76 hPa Linearised APP1 40.16 % duty cycle - exhaust refeeding actuator 29.93 % duty cycle - manifold pressure actuator 77.98 % atmosphaere pressure 994.46 hPa 2. Umweltsatz Mileage 133700 km mean engine speed 2868.57 rpm coolant temperature 79.24 deg C maximal rail pressure of the last 10ms 819.22 bar injection mass index value without mass balance control 23.63 mg/cyc intaken air mass per cylinder 541.94 mg/Hub value of boost pressure 1132.30 hPa Linearised APP1 100.00 % duty cycle - exhaust refeeding actuator 4.73 % duty cycle - manifold pressure actuator 70.89 % atmosphaere pressure 1004.30 hPa positive Regelabweichung/Ladedruck zu niedrig Test conditions not yet fulfilled Error present now and already stored Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 45 30 71 06 00 00 1E 28 34 08 50 70 56 3B 56 70 33 26 63 65 34 3A 68 81 68 3C 56 73 7F 06 5A 66 =============================================================
  6. asta vroiam sa spun si eu ca am cumparat de la tine modelul evo flat blade si nu lasa urme deloc (mai putin la cel din dreapta pentru ca nu cade bine pe parbriz 1 cm)
  7. ce taran, omu ti-a facut o oferta si tu raspunzi la misto
  8. Ar fi frumos sa fie sub forma de lista: in stanga corectii si in dreapta teparii( ar fi frumos macar teparii sa ii punem la zid ca cei corecti se stie care sunt)
  9. incet incet numai este troaca :goodjob:
  10. tb sa cumperi garnitura etrier si se rezolva problema, tb curatat etrierul; si apoi cred ca tb sa ii faci si aerisirea
  11. pune mana pe EGR cand se aude sunetul asta si vezi daca este de acolo
  12. +1 (la mine se auzea ca o bataie de tacheti in partea dreapta cum te uiti la masina)
  13. Cu scuzele de rigoare colegului, pentru ce ai intrebat pompa vaccum este piesa 1 din link http://bmwfans.info/parts/catalog/E46/Sedan/Europe/320d-M47/LHD/N/2001/january/browse/engine/vacuum_pump_with_tubes/. Piesa 1 din link-ul colegului este electrovalva EGR.
  14. piesa 11 inchide/deschide clapetele din admisie
  15. Electrovalva EGr este piesa 1, piesa 11 este in cazul in care ai clapete admisie
  16. srb_alex
    MYX 4
    De prima data mi-am dat seama ca este vorba despre fostul 318iA-ul tau
  17. Din ce vad eu acolo pe langa zgarietura viitorul cumparator mai primeste bonus si o mica gaurica . Cred ca este bataie de joc cu zg in halul asta, am si eu piele si nu are nici un pic de zg
  18. sunt sanse mari sa fie E4 motorul M47N
  19. bieleta de directie? daca si acesta este buna mai ramane vreun pivot sau caseta.
  20. bieletele antiruliu le-ai verificat?
  21. Tampoanele motor sunt reperele 5 si 6 din link, recomand corteco. La cutie piesa 3 si cum ai spus si tu iti trebuiesc 2 buc.
  22. Pai de ce te-ai dus la gigi de la colt si nu la reprezentanta, nu mai ai garantie?
  23. prima data verifica sa vezi daca mai ai freon
  24. ai verificat piesa 9 din link? http://bmwfans.info/parts/catalog/E39/Sedan/Europe/525d-M57/LHD/M/2001/january/browse/fuel_supply/fuel_pipe_diesel_pump/
  25. Volanta mea este in stare buna...dar nu revine din arc 100% Astept oferte Multumesc Daca nu revine un arc inseamna ca este dus volantul
