ar85gyl
Everything posted by ar85gyl
  1. Vreau sa achizitionez un bmw e39 motorizare pana in 2500,am gasit asta pe net ce parere aveti? http://olx.ro/i2/oferta/vand-525d-m-pachet-full-full-ID2xDTh.html
  2. Se poate inchide ,multumesc
  3. Pai sa inlocuit capota ,bara si farurile Sent from my iPhone using Tapatalk - now Free A fost doar o tamponare dar la ce lume rea exista vad ca imediat aruncati cu noroi,tipic romanesc Sent from my iPhone using Tapatalk - now Free
  4. Vand/Schimb BMW 320d an 1999,inmatriculat Ro 2010,taxa nerecuperata,albastru metalizat,161 Cp(resoftat profesional),bara M technich II US Style(este nevopsita doar in fuler cum a venit),suspensie reglabila pe inaltime FK,jante MK Motorsport originale model deosebit 18" 8.5j fata-10j spate cauciucuri 225/40/18 toate 4 stare foarte buna dot 2011+set de iarna pe 15,aripi roluite,interior semi-piele,Trapa electrica,oglinzi electrice/rabatabile,Alarma OEM(fabrica),sirocou,comenzi volan,pilot automat,volan sport,stopuri led,xenon,angel eyes,semnalizari smoked US Style,nefumator,folie omologata.capota facelift Schimb cu Auto de teren Nissan Navara sau Patrol Mai multe detalii la telefon Pret:4300e negociabil Tel:0747907831 http://img.tapatalk.com/d/13/10/26/be4yte4u.jpghttp://img.tapatalk.com/d/13/10/26/eguradug.jpghttp://img.tapatalk.com/d/13/10/26/mazeba3y.jpghttp://img.tapatalk.com/d/13/10/26/6y6apy6a.jpghttp://img.tapatalk.com/d/13/10/26/je4eva6a.jpghttp://img.tapatalk.com/d/13/10/26/daqazyme.jpghttp://img.tapatalk.com/d/13/10/26/y2esu4e9.jpghttp://img.tapatalk.com/d/13/10/26/ne3a3uje.jpghttp://img.tapatalk.com/d/13/10/26/u9uvubuz.jpghttp://img.tapatalk.com/d/13/10/26/u4umetyq.jpg Sent from my iPhone using Tapatalk - now Free
  5. La un prieten de al meu i-a sarit airbagul si nu ii mai merg comenzile pe volan deloc,adica nici nu se aprind nimic si a incercat cu mai multe volane,trebuie resetat ceva din tester s-au care ar fi problema,masina este e 46 nfl 2000 si volan in 3 spite,multumesc Sent from my iPhone using Tapatalk - now Free
  6. S-a rezolvat,era dusa si cea dea doua electrovslva,am luat alta din schro iar scum rupe asfaltu,va multumesc Sent from my iPhone using Tapatalk 2
  7. Poti sa imi spui daca conteaza in care vacuum e bagat fiecare furtun sau nu ,ma refer la distribuitorul ala ce este pe furtunu ce pleaca din pompa Sent from my iPhone using Tapatalk 2
  8. Am bagat muga si a mers ca inbainte Sent from my iPhone using Tapatalk 2
  9. Oare contraza in ce gaura e pus fiecare sau e doar un distribuitor cu 3 gauri care comunica intre ele? Sent from my iPhone using Tapatalk 2
  10. Astazi am schimbato pe cea defecta si cand amscos furtunu de vacum dindistribuitoru ala cu 3 picioruse mi sa rupt piciorusu ,furtunasu egr vine in mijloc ?l-am lipit eu si trage un pic mai bine dar cred ca pierde vacuum pe acolo maine sa merg in schort sa iau altul Sent from my iPhone using Tapatalk 2
  11. Am schimbat electrovalva defecta cea de la egr acum si tot ssa imi merge,sa fie bulita si electrovalva din schrot,diseara o sa le schimb din nou cea de la turbo o sa o pun la egr sa vad daca revine veche problema,sa fie furtunele prea mici am luat de 3,2x7 scrie pe ele,ms Sent from my iPhone using Tapatalk 2
  12. Fratilor cred ca am gasit buba,am schimbat astazi toate furtunele de vacuum si am inversat electrovalvele cea de la turbo cu cea de la egr iar dupaaceea am dat o tura sa vad cum sta treaba si acum nu mai imi trage pana in 2500 ture iar dupa aceea rupe,maine sper sa am timp sa schimb si electrovalva cea bulita si revin cupareri Sent from my iPhone using Tapatalk 2
  13. Stie cineva la ce se refera mai exact Sent from my iPhone using Tapatalk 2
  14. Pe tester imi da ceva eroare cu charge air pressure in bmw scsnner Sent from my iPhone using Tapatalk 2
  15. K o sa schimb furtunele si vad dupa aceea cum sta treaba deoarece a facut dintro data ca si cum ar fi puscat ceva si pierde vacuum pana se umple iar rezervorul de vacuum Sent from my iPhone using Tapatalk 2
  16. Sa fie electrovalva care e la fel cu cea de la egr sau sa fie valva vacuum care actioneaza tija?sau cum pot verifica daca am vreun furtun spart Sent from my iPhone using Tapatalk 2
  17. Am scos mufa si merge muuuult mai rau,nu are forta deloc deci la mn cred ca e valva de la turbo ca ,cand merge peste 3000 adik 1.2.3.4 cateodata,scoate un fum negru si nu are forta dinnainte Sent from my iPhone using Tapatalk 2
  18. Crezi ca ar fi debitmetru?astazi verific dar trebuie sa dau filtru ca sa scot mufa,nu sar plafona exact la 3000 si nu trece de 140 cum zc colegu Sent from my iPhone using Tapatalk 2
  19. Tu ai schimbat si furtunele de la vacuum? Sent from my iPhone using Tapatalk 2
  20. Aia ce inchide si deschide turbo?tia dat pe tester ceva? Sent from my iPhone using Tapatalk 2
  21. Am o problema cu e46 320d,filtrele sunt schimbate de o luna de zile,iar intro zi am talpalito pana pe la 4000 ture si am simtit ca pica in bot de atunci cand merge la drum intins si ii dau talpa in 5 pica in bot la 3000 ture si daca nu o calc un timp dupa aceea merge ok iar o perioada dupa iar pica ca si cum nu s-ar alimenta,a mai patit cineva? Sent from my iPhone using Tapatalk 2
  22. Valabilllllll Sent from my iPhone using Tapatalk 2
  23. Valabil in continuare,las si numar de telefon:0747907831 Sent from my iPhone using Tapatalk 2
  24. Cu mare placere,ce versiune ai? Sent from my iPhone using Tapatalk 2
