siulian
Everything posted by siulian
  1. Cand crapa da eroare pe tester. Iti spune ca bujia cutare nu mai functioneaza si trebuie schimbata. Si ca sa nu schimbi una, le schimbi pe toate.(mai ales ca la BMW e sub admisie). PS: bujiile se schimba si in fuctie de starea motorului si in functie de cum se merge cu acel motor.
  2. Si ca sa reintregim ce a zis DOMI, daca te joci cu ET-ul prea mult e foarte posibil sa dai de COPAC/STALP/etc. "Inset or outset This is very important. Ignore this and you can end up with all manner of nasty problems. This is the distance in mm between the centre line of the wheel rim, and the line through the fixing face. You can have inset, outset or neither. This determines how the suspension and self-centring steering behave. The most obvious problem that will occur if you get it wrong is that the steering will either become so heavy that you can't turn the car, or so light that you need to spend all your time keeping the bugger in a straight line. More mundane problems through ignoring this measurement can range from wheels that foul parts of the bodywork or suspension, to high-speed judder in the steering because the suspension setup can't handle that particular type of wheel. This figure will be stamped on the wheel somewhere as an ET figure. Inset and outset are subsets of offset and the relationship is this : positive offset = inset. Negative offset = outset. Typically you can get away with 5mm-7mm difference from the vehicle manufacturer specification before you'll run into trouble with the wheels fouling the suspension or bodywork. So for example if your stock wheels have an offset of 42mm and you can only find replacements with a 40mm offset, that 2mm difference ought to OK. " Cititi foarte atent articolul si lasati presupunerile.(gasiti poze cu explicatii foarte tehnice si la obiect) http://www.carbibles.com/tyre_bible_pg2.html Si la urma urmei de ce ti-ai pune distantiere cand sunt sigur ca exista si jante frumoase si late si etc cu ET-ul PENTRU masina ta. Dar daca voi vreti sa va jucati cu viata voastra doar pt ca sa aveti voi jante iesite in afara si frumos colorate atunci va urez succes.
  3. Auleu... Mi-ai pocit id-ul. Astept mielul :) Cu placere. 1) sper sa le faci paguba la aia cu casco 2) da bani si inscriptioneaza-le, merita.
  4. Pe tanarul intelectual din imagine l-am intalnit la o reprezentanta BMW, de unde a plecat la volanul unui seria 7, banu' jos :lol: Uite de aia tampesc cateodata.. Noi astia normalii, ce vina avem ca "chestiile" astea si-au luat si ei BMW?
  5. Alt BATMAN care acum va merge fara masina. Bine macar ca nu s-a soldat cu morti.
  6. Pai daca o sa dai jos un filtru de aer jos si o sa vezi ce e in(pe) el, probabil ar trebui sa-ti dai seama ca toata mizeria aia n-ar trebui sa-ti intre in camera de ardere :)
  7. 1. imi pare rau pt E60-ul tau 2. cred ca ar fi trebui sa postezi in alta sectiune a forumului :)
  8. nu merge decat pentru E46 si E39 si sectiunea de vanzari nu mai exista?
  9. Am gasit mai demult un filmulet pe youtoube , dar acu mi-am dat seama ca nu l-am postat. Ca drept urmare pentru punctul 4, folositi garantat : Toata chestia este ca inainte de a apasat butonasul de reset , e sa pui meniul pe data.
  10. Trapa e un mare bull-shit, am eu..si cred ca am folosit-o de maxim de ori. Btw, masinile de lux nu sunt full pana nu ai cosuletul de picnic, umbrela si alte acareturi :lol:
  11. Ce-i drept, nu cred ca soferul va invata ceva din toata chestia asta.(sper sa ma insel) Totodata, sunt oarecum de acord cu el_fefe, merita cel putin inchisoare(ideea cu impuscatu pare foarte buna in momentul in care auzi ca un dobitoc ti-a omorat fiica, dar e posibil sa regreti pana la urma).
  12. Tu nu folosesti flash-uri ? Nu claxonezi? tu ce faci cand mergi mai tare decat restul si dai de unu care merge cu 50KM/h pe a doua banda? NU. Mi se pare oribil si de proasta crestere. Din cate stiu limita este de 50Km, voi unde va grabiti ? Chiar atat de mult va avantajeaza cele 10 minute castigate, incat sunteti in stare sa puneti viata voastra a a altora in pericol? Sa inteleg ca voua vi se pare normal sa mergi toata autostrada(atat cat avem) cu 200km/h si sa o tii din flash in flash, doar pt ca ai BMW(sau alta marca mai rasarita)? Sa inteleg ca voua vi se pare normal sa claxonati in prima nanosecunda scurta de la punerea semaforului pe culoarea verde? Pai daca asta e parerea voastra atunci eu ma retrag si Bafta Voua. Stii tu ce stii cu limita ,dar conducatorul auto este obligat sa mearga pe prima banda daca este libera,nu sa stea pe a doua ca asa vrea vreju lui. Si ce ai tu cu mine daca eu vreau sa merg cu 80KM/h daca drumul imi permite? Daca eu simt ca la viteza respectiva am masina sub control? Cine a zis aici ca merge cineva cu 200KM/h? Tie ti-ar convenii sa mergi cu o viteza peste medie ,pur si simplu te grabesti si intalnesti o masina care merge pe a doua banda cu 40 la ora? Tu ce faci? stai in spatele lui? Il depasesti pe dreapta? Cu claxonatul la semafor nu sunt de acord,eu si Ciupanezu ne-am referit ca in caz ca unu intra in tine sau nu se asigura atunci folosim claxonul. Dar tu ce faci? Il poftesti sa intre in tine? S-au mai vazut si altii care au crezut ca au masina sub control.(destul de recent pe la Romana) Cat despre 200km/h, merg destul de des pe ruta Constanta-Bucuresti si am aproape de fiecare data sansa sa vad vreun vitezoman(si crede-ma ca de cele mai multe ori sunt BMW-uri) care are scurta la deget si pedala la maxim. Zicea Ciupanezu mai sus ca Romanii in afara merg civilizat, nu arunca gunoaie pe geam,etc. Crezi ca daca am face cu TOTII acelasi lucru aici nu s-ar simti diferenta?(daca precam de la premisa ca si asa e murdar, de ce nu scoatem organul genital pe geam si urinam?) Eu zic ca se poate responsabiliza si poporul roman, dar trebuie sa o faca toti. Una peste alta , sunt de acord si cu voi cĂŁ trebuie circulat pe banda cea mai apropiatĂŁ de marginea drumului dacĂŁ aceasta este liberĂŁ, dar asta nu inseamna ca daca cineva nu o face noi va trebui sa sarim repede cu claxonul sau cu flash-ul.(crede-ma ca te va vedea si fara flash) Daca vei da cu flash probabil vei obtine mai multa carne in frigider, il vei frusta, si cu prima ocazie cand are bani isi va lua BMW si va da si el cu flash-ul pentru ca acum poate.
  13. Tu nu folosesti flash-uri ? Nu claxonezi? tu ce faci cand mergi mai tare decat restul si dai de unu care merge cu 50KM/h pe a doua banda? NU. Mi se pare oribil si de proasta crestere. Din cate stiu limita este de 50Km, voi unde va grabiti ? Chiar atat de mult va avantajeaza cele 10 minute castigate, incat sunteti in stare sa puneti viata voastra a a altora in pericol? Sa inteleg ca voua vi se pare normal sa mergi toata autostrada(atat cat avem) cu 200km/h si sa o tii din flash in flash, doar pt ca ai BMW(sau alta marca mai rasarita)? Sa inteleg ca voua vi se pare normal sa claxonati in prima nanosecunda scurta de la punerea semaforului pe culoarea verde? Pai daca asta e parerea voastra atunci eu ma retrag si Bafta Voua.
  14. 1. Am zis AS scoate bata. 2. Sa intelegi ca faci parte din cei cu flash-urile si claxoanele ?
  15. Pt astia care dau flash-uri sau claxoneaza, as scoate bata si v-as da numai peste ceafa. Nu am vazut asemenea TARANISME in toata Europa(si slava domnului ca am facut mii de kilometri). Este inadmisibil cum in alte tari se poate si aici nu. PS: e valabil si pt cei cu alte marci
  16. siulian
    parcare
    Lool, tu de mai agiti la chestii de genul asta? Pai eu, in mai putin de jumatate de an am acumulat: zgaraietura cu cheia toata partea dreapta, gasita de vreo 3 ori busita in parcare, furat oglinzi,etc etc Cat despre casco , daca ar fi fost sa merg la ei pentru fiecare treaba de genul asta cred ca la anul imi vandeam apartamentul ca sa-mi fac casco. Astept si eu sa se mai adune, eventul poate ma buseste careva si-l si vad, chestii de genu asta. Relax man, nu va fi nici prima si nici ultima zgaraietura.
  17. Pe 17 cu anvelope Michelin Pilot ALPIN2 205/50/17 Extra Load nu te intereseaza? Nu, vreau de 16. Mersi de oferta.
  18. Salut, Caut sa cumpar jante din aliaj + cauciucuri run-flat de iarna( de preferinta 225/50/16) pentru un E90. Doresc ca vanzatorul sa fie din Bucuresti pentru a putea vizualiza rotile inainte de a le cumpara. Mersi.
  19. Pana nu faci dovada ca sunt de la masina ta pentru mine esti un ciorditor. Eu unul n-as cumpara si nici nu te-as lasa sa postezi cu chestii de genul asta.
  20. Dar de sa-l lasi? Crezi ca el a invatzat ceva din experienta aia? NIMIC. Da-l in masa sa faca accident cu duba lui cu tot si apoi clar nu va mai face in viata lui asta. Eu m-am plictisit de tot felul de stresati care depasesc coloane intregi de masini si apoi stau la MILA cuiva sa le faca loc. Am condus zilnic timp de 6 luni prin Belgia si Olanda. O singura data n-am vazut un flash/claxon/depasiri teribiliste. (au fost foarte multe momente cand am mers in paralel pe 3 benzi cu viteza maxima legala). PS: asa zic eu, dar in trafic mi se face mila de PROST si il las.
  21. Pai uite de ce: " Soferul este cautat de politisti la aceasta ora. Se pare ca barbatul va fi cercetat pentru fuga de la locul accidentului si risca inchisoare pentru infractiunile savarsite, numerele de inmatriculare provizorii de pe masina fiind expirate de aproape cinci luni de zile. " Eu unul chiar nu sunt de acord ca fiecare prost sa-si ia BMW, sa o lase atat neinmatriculata si nerevizuita cine stie cat, sa-i puna VOLAN SPORT si sa faca depasiri/drifturi/etc cum il taie capul. Astia merita inchisoare zdravana si dati drept exemplu comunitatii.
  22. recircularea aerului exista si pe dacie 1300 si nu are nici o legatura cu AC-ul :)
