Onnix
Contributors-
1532 -
41
Everything posted by Onnix
Aveai peste 70km/h cand ai verificat daca-ti merge? Nu functioneaza la viteze mai mici… si nici daca bagi doar un sprint de cateva secunde peste 70 in oras…
320d vs 320d Efficient Dynamics
Onnix replied to Dens's topic in Probleme tehnice si rezolvari Seria 3
Gasesti detalii pe internet despre ce am scris mai sus… nu le-am scos din burta. Doar trebuie sa cauti. Brake energy regeneration Using technology developed in Formula One racing, this feature harnesses the energy that’s usually lost when you brake. The system converts it to electrical energy which charges your battery instead, meaning the engine does less work and uses less fuel. Coasting function Also part of ECO PRO, this function cuts the power between the engine and drive in automatic cars, the second that the driver takes their foot of the accelerator without braking. This then allows the vehicle to ‘coast’ freely without resistance from the engine, using up less fuel and therefore reducing emissions in the process. Electric power steering The electric motor that powers this system is only fired up when you move the steering wheel, meaning less energy is used when you’re driving straight or through a long corner. EfficientLightweight and aerodynamics BMW is now using carbon more widely in the production of their cars, or carbon fibre reinforced plastic (CFRP) to be precise. Around 30% lighter than aluminium and 50% lighter than steel, it still provides exceptional protection. Along with lots of design improvements when it comes to aerodynamics, it creates a highly stable body and greater safety, plus improved handling and lower fuel consumption due to the weight loss. ECO PRO mode If you don’t feel like adjusting your driving style to gain better efficiency, ECO PRO mode will do all the work for you, allowing you to save up to 20% of fuel without doing anything yourself. The amount you save is converted into a mileage on your display, giving you an instant indicator of how much more you’re getting out of your fuel tank. Active air stream kidney grille - the grille automatically opens its vents when parts of the car need air. When they don't, it closes and allows air to flow over the body, reducing resistance. Air curtain & air breather - at the bottom and sides of the car are two smaller vents that control air as your vehicle accelerates. Both of these features let the air fly through and prevent air resistance. Drag is also reduced, allowing the car to continue accelerating while using less fuel. Aero wheel rims - the wheels act as a wind turbine to guide the airflow along the sides of the vehicle, creating the perfect air channel. Again, this boosts aerodynamics by letting the car cut smoothly through any air resistance. Rear spoiler and air blade - both of these features combine to reduce drag and stop the rear axle from rising up at increased speeds. In essence, they keep your car firmly on the ground, reducing energy demands. The engine doesn't have to fight as hard against air resistance, so less fuel is consumed. Brake energy regeneration - this technology reuses the kinetic energy that's generated when you brake. It takes the energy and puts it back into the car battery, stopping it from depleting. In turn, this also stops the engine from working hard to charge the battery, lowering fuel consumption. Electric power steering - an electric motor is used to create a more efficient power steering system that demands less energy. When driving in a straight line, the power steering function automatically turns off so no energy is used whatsoever, until you start turning. Coasting function - this feature is reserved for automatic vehicles as it cuts off the power between the engine and drive. It kicks in when you lift your foot off the accelerator pedal but don't brake. Essentially, it turns the engine off, so you coast along without using any additional fuel. -
Are garda putin mai joasa pt o aerodinamica mai buna, deci consum mai mic. ED are regenerare la franare, greutate putin mai mica, Eco Pro obligatoriu, functie de coasting si cutie de directie obligatoriu electrica. -
Nivel antigel si furtun intercooler
Onnix replied to s1l3nt15's topic in Probleme tehnice si rezolvari Seria 5
Nu este absolut nimic dubios din punct de vedere legal. Tot ce s-a schimbat apare in istoricul masinii la o simpla verificare in reprezentante si nu numai. Poate parea dubios doar din punctul tau personal de vedere, dar asta nu conteaza. Bucura-te de masina si nu te stresa. -
Nu "e boala lor" daca au fost intretinute de la bun inceput. Dar cand pana in 100k km ai doar 3 revizii de ulei, raul/uzura a fost facuta. Ideea este ca acest motor NU se repara decat in niste conditii mega draconice si nimeni in RO nu-l va repara cum trebuie. Ca sa-ti dau un exemplu concret, cand se monteaza elementele din motor, temperatura camerei in care se face procedura, inclusiv piesele, trebuie controlata! Daca e prea frig, contractie si nu-ti ies bine cand se dilata la caldura... si invers. Atat de mici sunt tolerantele acestui motor. Si nu e numai asta... sunt multe, multe altele. Din acest motiv am pus linkul cu pataniile de mai sus... si stiu multe cazuri asemanatoare. Decat nervi, frustrare si frica de a mai merge cu acest motor reparat, mai bine altul in care nu s-a umblat. Il stiam inainte de a-mi pica motorul si pe langa altele, a fost inca o confirmare ca reparatiile pe acest motor nu reusesc.
Imi pare rau pt cele intamplate. Totusi, daca eram in locul tau si completam cu peste 1L de antigel cum ai spus, nu mai circulam cu masina pana nu remediam problema.
Ai avut motorul acesta? Daca nu, zic sa te abti :))) Am fost in situatia lui, nu ai ce sa repari in caz ca se invart cuzinetii! Punct! Orice tentativa de reparatie este cel mult temporara si doar in ideea de a pasa altcuiva masina. Las un link cu patania unui coleg de forum cu acelasi motor.
Dupa cum am completat mai sus, au schimbat algoritmul si la seriile F. Asta am simtit-o dupa ce am facut update de soft cand am avut recall pe racitor. Inca un motiv pt care am sustinut si sustin update-urile de soft.
Dimpotriva, l-au facut mai bun la noile generatii. Pot da exemplu la seria 8 G15. Dupa revizia de ulei si filtru, resetat arata 25.000km pana la urmatorul schimb. In bord masina avea 30.005 km. La 38.000 km in bord, CB arata 13.000km pana la urmatorul schimb. Am schimbat uleiul in regim propriu, fara sa resetez in bord. La 46.000 km in bord, CB arata 1.500km pana la schimbul de ulei. Facut programare la reprezentanta si schimbat uleiul cand aveam 46.500km in bord si pe CB 1000 km pana la schimb. Facand un calcul simplu, cei 25.000 km estimati in CB, au fost 16.500 km efectivi “la roata”. Nu este rau deloc dpmdv! La F10 530xd 258hp, CB arata 30.000 km pana la schimb iar cand faceam drumuri multe pe afara, regim normal autostrada, ajungeam la roata sa parcurg 25.000-27.000 km. A nu se intelege ca atunci schimbam uleiul, ci tot timpul faceam schimb intermediar la jumatatea perioadei din CB, fara sa resetez. Inca ceva! Dupa ce am facut update de soft la F10, s-au schimbat algoritmii si imi scadeau mult mai rpd km pana la revizie, semn ca au facut ceva modificari In bine.
Capacul l-am schimbat si eu, OE, atunci cand am cumparat masina, deoarece e stiut ca se deformeaza si curge ulei. Ai putea sa verifici daca nu cumva iti curge si tie... undeva in spatele motorului spre parbriz. Nu prea a avut simptome masina... pilitura nu avea in filtru de ulei, verificam la fiecare schimb. Uneori pot spune ca era zgomotos motorul dimineata la pornirile la rece... un fel de mica bataie... dar am dat vina uneori motorina, injectoare desi alimentez doar cu Maxx Motion de la OMV. Erori nu avea deloc masina, verificam lunar cu Ista, regenerari isi facea normal. Ce cred cu tarie este ca de vina sunt schimburile rare de ulei (30k conform schemei de servisare BMW), de care a avut parte motorul la primul proprietar in DE... doar 5 schimburi pana la 150k.
Nu vreau sa te alarmez prea tare. Am avut aceeasi masina, acelasi motor, doar ca fara soft. Cam la 1 an dupa ce incepuse sa consume putin ulei (gen 1L la 3-4k km), au picat cuzinetii. Nu stiu daca e relevant dar incepuse sa consume cand am schimbat uleiul. Cat am avut BMW OE, nu consuma. Dupa, am bagat Motul X Clean+ 8100 un schimb, apoi Liqui Moly Top Tec 4200 2 schimburi, la al doilea a picat. Rezolvare, alt motor iar in acesta am bagat doar BMW OE, nu consuma deloc ulei dupa 50.000 km si 4 schimburi.
Pai daca e masina ta de suflet, atunci ai grija de ea. Pune EGR la loc, debitmetru nou iar apoi fa-i o diagnoza cu Ista si vei vedea ce coduri de eroare apar.
g31 AdBlue Active Tank Fault (80527A)
Onnix replied to Tavicu's topic in Probleme tehnice si rezolvari Seria 5
Cand rulezi masina la greu si sunt multe regenerari, nu se infunda si nici cristalizeaza sistemul ad blue. Problema apare la cei ce nu fac multi km, frecusi prin oras cu motor rece, incercari de regenerare incomplete etc etc -
In cazul meu pe G15, merge update-ul automat de harta OTA, dar nu integral, ci doar pe regiunea setata de mine in cont, Romania, Moldova si Belarus parca. Contul cu serviciile platite il am pe DE. Remote 3D view nu merge nici la mine, chiar daca am cont pe DE.
- 118 replies
- bmw online
- mybmw
(and 3 more)
Tagged with:
Ti-am pus si clipul oficial de la BMW cum se incarca. Nu te sfatuiesc sa faci altfel.
E destul de ok redresorul de la Lidl pt a tine bateria incarcata. Doar acolo la motor se da curent masinii… sa nu pui redresorul pe baterie cand e montata pe masina. Vezi ca pe partea pasagerului, sub stergatoare gen, ai un loc special decupat in plastice pe unde se scoate cablul de la redresor… ca sa poti inchide capota bine.
posesor nou de BMW 520 D automat an 2008
Onnix replied to Octavian Antoniu's topic in Probleme tehnice si rezolvari Seria 5
Nu e nevoie de Exide, merge orice baterie AGM (gel). Ca sa iti functioneze corect si sa te tina bateria multi ani, trebuie inregistrata bateria cea noua. Ista este programul de diagnoza oficial BMW. -
Pai nu mai schimba nimic, Fanele, ca e normal sa nu schimbi uleiul la cutia de transfer dupa 15 ani. E normal… “asa face toate” Schimbi uleiul, resetezi adaptarile cutiei de transfer, stergi erorile si dupa vezi cum se comporta…
Fara pierderea garantiei nu exista, momentan.
- 1 reply
- 1
Am scris mai sus, update la 2 masini, nicio problema. Urmeaza sa fac si la X1 F48 sapt viitoare.
Nimeni nu-ti poate da o data fixa. Depinde cat de repede ajung piesele in stoc. Si pe forumurile din Germania, UK, vad useri care se plang ca se asteapta si acolo cu lunile.
m50d X5 M50d F15 probleme motor
Onnix replied to Geotim's topic in Probleme tehnice si rezolvari Seria X
Nu am facut nicio contradictie, antiteza ori alta nebunie. Nu e vorba de bani aici, ci de fiabilitate. Nu stim cum a fost exploatata masina de la 0km pana la 144k. Poate fostul proprietar i-a dat forja cu motorul rece, poate schimburile nu au fost facute bine de la inceput, poate nu s-a folosit uleiul potrivit tot timpul etc etc Nimeni nu-si ia tri turbo si nu-i da “in gura”… sa fim seriosi. Una peste alta, daca la seria 8 imi pica una din turbine la aprox 150k, asta e… nu inseamna ca e capat de tara. -
Cadeau turbinele pe capete si la E46 cu faimosul M47, been there, done that! Sa nu uitam ca in urma cu aprox. 20 de ani, aveam 134hp in medie de la un motor de 2L si in jur de 214hp la motor 3L. Acum avem dublu putere. Normal ca tineau mai mult :))) In ziua de azi, toti vor putere cat mai mare dar si fiabilitatea de odinioara. Se poate, oarecum, dar toate astea vin cu niste costuri… -
Corect, doar cele de retur sunt obligatorii pt garantie gen, insa, eu le-as schimba pe toate dat fiind complexitatea motorului si faptul ca manopera pt a le schimba dupa, probabil egaleaza (daca nu si depaseste) costul acestora.
