costty
Everything posted by costty
  1. costty
    DPF lipsa 530d
    Nu e logic, nu? Gaze mai multe, Euro mai mic.
  2. costty
    DPF lipsa 530d
    Da-i pace. Ai scapat de o grija destul de costisitoare. Totusi... acum nu ar trebui sa fie Euro3? Cum de au iesit bine noxele? ITP-ul l-ai facut pe bune? Intreb si eu sa stiu pe viitor.
  3. Si nu cred ca s-a gandit mult. E46 Module Names ABG - Airbag Module AEWS - Immobilizer AKMB - Instrument Cluster ALSZ - Light Switch Center BTM - Passenger mirror Module CVM - Vert Module - don't touch this, apparently it's sensitive DSC - DSC FTM - Driver rearview mirror module GM5 - ZKE - Central Body Electronics GT - Navigation IHK - AC LWS - Light Switch RAD - Radio RLS - Rain Sensor SM - Seat Memory UEB - Rollover Sensor GM5: QUIT_AKUST_ENTSCH : alarm beep on unlock (two beeps) QUIT_AKUST_SCHAERF : alarm beep on lock (one beep) QUIT_OPT_ENTSCH : optical Acknowledge remote un-locking (two flashes) QUIT_OPT_SCHAERF : optical Acknowledge remote locking (one flash) ALARM_OPT_ABBLENDLICHT : alarm flashes low beam when tripped ALARM_OPT_WARNBLINKER : " " emergency flashers when tripped ALARM_OPT_FERNLICHT : " " high beam when tripped ALARM_AKUSTISCH :alarm sound choices (dauerton is the US tone/intervallton is the euro) PANIK_MODUS :Panic mode DWA_HANDSCHUHFACHKONTAKT :Alarm glove compartment switch BEIKLAPPEN_B_KOMFORTSCHL : press the unlock button twice, and the drivers window will open FH_TUEREN_HINTEN_TIPP_AUF :rear window power down one touch FH_TUEREN_HINTEN_TIPP_ZU : rear window power up one touch FH_ZTR_SCHALTER_TIPP_AUF : window switch down one touch FH_ZTR_SCHALTER_TIPP_ZU : " " up " " (do these after modifying the switches) KOMFORTOEFFNEN_FB_O_FH_HI :remote opens rear window (this has to be nicht_aktiv) KOMFORTSCHLIE_FB_O_FH_HI : remote closes rear window (this has to be nicht_aktiv) KOMFORTOEFFNEN_FB_O_SHD : holding open button on remote opens windows without sun roof KOMFORTSCHLIE_FB_OHNE_SHD : holding close button on remote closes windows without sun roof KOMFORTOEFFNUNG_FB : convertible top opens by holding the open button on remote..Or opens all windows & sun roof on non convertible KOMFORTSCHLIESSUNG_FB : convertible top closes by holding the close button on remote..Or closes all windows &sun roof on non convertible MAUT_N_ABBRECH_N_TUER_AUF - windows carry on opening/closing even when you open the door VERRIEGELN_AUT_AB_X_KMH : automatic central locking after X KMH VERRIEGELN_AUT_NACH_2_MIN : automatic central locking is re -locked after 2 MIN if you dont open a door VERRIEGELUNGSSCHWELLE : locking Device-swells (threshold) (speed of X above) VERRIEGELN_XKM/H_SENDER_1 VERRIEGELN_XKM/H_SENDER_2 VERRIEGELN_XKM/H_SENDER_3 VERRIEGELN_XKM/H_SENDER_4 (these all have to be aktiv for the auto central locking to work on all keys) PANIK_MODUS - panic mode! press and hold boot button for the siren CYCL_TI_BLK;1-touch on turn signal blinks. einmal-1 . zweimal-2 . dreimal-3. One touch indicators, lane change. HHS_AUTOMATIK - enable auto rear window fogger (I haven't found the last three in any module, but I can see it in the full read-out. So if you find it, then tell!!) FTM/BTM: SPIEGELABKLAPPEN_GM - folding mirrors with lock/unlock ABKLAPPWERT_GM (in GM5) - mirror tilt value ABKLAPPWERT - mirror tilt value SPIEGELMEMORY - gives you the option to change the mirror tilt value whilst it's in reverse ALSZ: HEIMLEUCHTEN : home lights activated by flashing high beam with key off HEIMLEUCHTEN_ABBRUCH : home light stop HEIMLEUCHTEN_AL :home lights are low beam HEIMLEUCHTEN_BL : " " " turn signals HEIMLEUCHTEN_FL : " " " high beam HEIMLEUCHTEN_FUNKSCHL :lights on on closing car with remote (only on e39 ) HEIMLEUCHTEN_KL58G : home lights are interior backlighting, cluster, ashtray etc. HEIMLEUCHTEN_KZL : " " " license plate HEIMLEUCHTEN_NSL : " " " rear foglight HEIMLEUCHTEN_NSW : " " " front foglight HEIMLEUCHTEN_RFS : " " " reverse light HEIMLEUCHTEN_SL_H :" " " rear parking lights HEIMLEUCHTEN_SL_V :" " " forward parking lights FL_UND_NSW_NICHT_GLEICHZ : high beam & fog lights come on together when nicht_aktiv (I haven't got this working yet) Xenons with high beam: PWM_WERT2_FL_BIXENON wert_02 to PWM_WERT2_FL_BIXENON wert_01 (I haven't tried this yet) BLINKIMPULS_WARNBLK to wert_04 - double impulse hazards. AKMB Set warning tone on key in ignition. Code: ZUENDSCHLUESSEL_WARNUNG = aktiv Be warned, writing this code appears to reset the cluster, so you need to set time and date afterwards. LED (ALSZ) upgrade: KALTUEBERWACHUNG_BL_MI : " " " " brake light WARMUEBERWACHUNG_BL_MI : " " " " brakes FEHLER_BL_BLINKEN (if these don't work, then retrofit with GT1 instead). Seat: AUT_SPIEGELVERSTELLUNG : automatic mirror adjustment linked to specific key AUT_SITZVERSTELLUNG :choose between automatic seat adjustment [nach_fb_entriegeln] when remote signals door open or[nach_entr_u_tuer_oeffnen] when door opened (A bit hit and miss with these) IHK: 1. DISPLAYANZEIGE_HIGH :temp. display on ihka shows HI if aktive 32*C if not aktive 2. DISPLAYANZEIGE_LOW :temp. display on ihka shows LO if aktive 16*C if not aktive Others: REGENSCHLIESSEN - Rain sensor closes sunroof! (I haven't found these yet!) REGENSCHLIESSENTILT
  4. Fix asta am facut acum 5 minute. Le-am strans ca se miscau ambele. Coborasem cu cablul si laptopul sa sterg erorile dar nu mai erau. Acum vreo 3 luni am pus folie si au ascultat baietii muzica din masina mai bine de 1h si nu a facut figuri la pornire.
  5. Nu am pornit masina vreo 3 zile si ieri mi-au aprut 3 erori: ceva cu terminalele bateriei, ABS, Run Flat Indicator. Am intrat in casa sa iau telefonul sa fac poze si la intoarcere nu mai aveam nici o eroare. Astazi din nou erori. De data asta nu o mai aveam pe cea cu terminalele bateriei dar au aparut 2 noi: Battery si Transsmision. Ma gandeam ca o fi bateria de vina dar cel de la care am luat masina zice ca a fost schimbata. Bine.. nu inseamna neaparat ca l-am crezut. Am vazut ca e baterie originala. Altceva ce ar putea fi? Ceva senzor tot de la baterie? http://i50.tinypic.com/35hlheb.jpghttp://i50.tinypic.com/348plbp.jpg http://i46.tinypic.com/2q84l54.jpghttp://i48.tinypic.com/v49bna.jpg
  6. Scoate sigurantele de la BT, macar asa iti vei da seama daca problema e sau nu de acolo. Vezi in torpedou 18 si 37.
  7. Difera tabelul ala in functie de motorizare? Am gasit mai multe variante. http://www.babybmw.net/viewtopic.php?f=11&t=28559 bmw 1 series fuse box diagram
  8. Alea le gasisem eu pentru seria 1. Nu am modelul ala de masina deci nu stiu daca e corect tabelul. Sa verifice Pole.
  9. Stiu ca si la E60 se intampla chestia asta. Acolo trebuie scoase sigurantele de la simbolul cu telefonul. Deci la seria 1 ar veni: 17, 26, 27. http://i46.tinypic.com/ac8meo.jpg
  10. Se poate si la Timisoara: http://www.bmwclub.ro/forums/topic/120677-power-reduction-dezactivat/page__p__1802441__hl__power+reduction__fromsearch__1#entry1802441
  11. Cica ala cu BMW conducea noaptea cu farurile stinse. :logik:
  12. Aveam si eu la fel la E46 si la E60. Porneau ambele masini cu modelul ala de cheie.
  13. Am subliniat faptul ca sanctiunea a fost data corect.
  14. Daca are stampila pe fisa inseamna ca e ok la financiar, nu? Eu am inmatriculat o masina doar cu fiscalul, pe fisa nu aveam stampila.
  15. I-a inchis topicul pentru ultima postare, cea anterioara fiind pe 3 august.
  16. http://www.philips.co.uk/c/car-lamps/14238/cat/ Apesi GO , alegi modelul masinii, anul si becul care te intereseaza.
  17. E vorba de comutatorul de lumini. http://img534.imageshack.us/img534/3341/lcmb.jpg
