@maciu da asa e NCS-ul dar din cate stiu NCS-ul vine cu INPA? oricum am gasit pe un forum de afara asta It's really not that hard, especially if all you're doing is reading the data. Basically click file>load profile, then select expert mode. Then hit the VIN/ZCS/FA button (F1), then ZCS/FA f. ECU (F3). Select your chasis, which in this case is E46, and then select either AKMB or ALSZ (doesn't matter which). Then you'd hit back (F6) and the Process ECU. At that point select the ECU you want to read (GM5 in this case). Now click "Read ECU" and NCS will download data from that module to the computer. The data is now stored on the computer. Go to C:\NCSEXPER\WORK, and upload the file "FSW_PSW.trc" That file is overwritten everytime you read a different module, so copy it to another folder and rename it to "FSW_PSW.GM5.trc". For other ECUs, change the GM5 to the ECU you're working with. @paco ok,testez
