max83
    10
Everything posted by max83
  1. vezi ca avea/are POIUYT un topic....exat la fel, foarte dezbatut http://www.bmwclub.ro/forums/topic/108728-de-la-cutie-manuala-la-cutie-automata/page__p__1539646#entry1539646
  2. daca ai scos din ecuatie restul (filtru benzina, regulator, furtune vacuum, debitmetru etc), sunt sigur ca pompa era guilty. Symptoms of a Bad Fuel Pump Fuel pumps stop working due to a variety of reasons. Once this happens, the supply to the injectors is automatically stalled and the vehicle stalls as well. The effect is similar to the problem of running out of gas. Another problem associated with the pump is proper functioning of the electrical mechanism of the pumping system. The electrical supply consists of devices like the relay and the fuse. If the fuse or the relay develop problems or blows off, it will again result in breakdown, as the driving mechanism for fuel supply is cut off. Another major symptom of a bad fuel pump is overheating. If the fuel pump gets heated frequently and within few minutes of turning on the vehicle power, it is a sign that the pump needs replacement. A bad fuel pump will also show signs of frequent stopping or intermittent breakdown. It will work for around 15-20 minutes and stop working. Once, the vehicle is allowed to remain idle for around 30 minutes, the engine gets cooled off and the pump functions normally. Such a problem is an indicative sign of a bad fuel pump. If the flow to the fuel injection system is not constant, the engine may develop problems. Signs include a hesitant start or a stumbling problem on ignition. If small, unwanted debris or grainy particles enter the pumping system it can cause vehicle breakdown, thus, abrupt stopping of a vehicle can also be considered a symptom of a bad fuel pump. If the filtering mechanism develops a problem or gets struck up with impurities, the engine will show symptoms like rough firing and fickle working. A reduction or drop in fuel supply to the engine causes symptoms of a low power engine and working problems if the problem persists for a long time.
  3. cu motorul nepornit? daca era pornit, si bagi marsarier, si o ia in fata clar...schimba cutia! asta daca nu stateai in panta si patineaza ambreiajul. fa cum ti-am zis eu, dar masina dreapta orizontal, si cu motorul NEPORNIT.
  4. nu prea poti compara asta KW2 sau asta D2 cu TA. la pretul ala, e chiar ok TA. dar nu cred ca e atat de dura cum zici.nici pe departe.
  5. totul despre EWS (drive away protection system) I II III. http://www.europeantransmissions.com/Bulletin/DTC.BMW/understandthe%20EWS%20BMW.pdf
  6. una automata e 150-200e 250 ron e pretul normal. dar vezi ca la tine nu creed ca e cutia problema. mai degraba ambreiajul.
  7. ambreiajul? cu motorul nepornit, incearca sa schimbi vitezele cu ambreiajul apasat, ar trebui sa mearga lin.
  8. cutia e aceasi pana la 2.5, gertrag 250, 200-400lei e range-ul. ai link cu shroturi. cred ca e o chestie banateana, nu? http://piese-auto.anunturi-auto.4tuning.ro/dezmembrari/dezmembrari-bmw/dezmembram-bmw-seria3-e46-1998-2005-9819641.html
  9. sef, vezi ca pompa de benzina e aceeasi de la 1.6 pana la 2.8, nu stiu M3 http://bmwfans.info/parts/catalog/16141182842/ ia-o pe proba. cand mai pui pompa pe direct, scoate releul pompei, si faci punte intre pinii 30 si 87 (ai releului) cu un fir cu siguranta de 15a intre (la mijloc). apoi auzi benzina in injectoare. nu cred ca e ok sa o pui direct pe baterie vezi aici: http://www.unitedbimmer.com/forums/bmw-oem-parts-department-diys-faqs/8287-e36-fuel-pump-diagnosis-replacement.html
  10. cu exceptia senzorului, sunt bolt on. dar app de senzor, ala ptr scaun pasager, care e rolul lui? nu mai sare airbag-ul pasager daca nu mai ai senzorul ala conectat? sau ti se aprinde in bord martorul ptr airbag...si atat?!
  11. atat timp cat scrie pe ele ca-s de iarna (snow flake, m+s etc) si nu au uzura sub limita, ce alte "certificari" va mai trebuie? Nu va mai uitati in gura unora ca in gura Maicii tereza. serios acum...
  12. daca ti le pune cine trebuie, gen emu, nu cred ca faci diferenta on: zeky, 2 seturi? :goodjob: daca dai unul, sa imi dai si mie pm te rog, cu pretul lor.
  13. la m50b20 non vanos e OBD1, din cate stiu tipul poate citi obd1. suna-l si vorbeste cu el, s-ar putea sa te ajute si pe partea mecanica. sau suna si la 0723007578 0766324050 LAF-ul, are garajul undeva pe antiaeriana, te poate ajuta pe mecanica.
  14. lucasurile sunt superbe, la fel cum sunt si cele de pe e92 M3, cu grila aerisire.
  15. eu unul nu conduc mereu la consum, de obicei un factor e starea de spirit daca s nervos, agitat, grabit cam o calc si merg in 4-5000, dar de obicei sunt "lean back" la 2500 cu ochii n patru dupa zmei si gropi, ca mi-a ajuns de cate ori am avut masina lovita cred ca toate solutiile enumerate aici, sunt nule in Bucresti, intre orele 07:30-10:00 si 17:00-20:00, cel putin in zonele pe unde trec eu.
  16. daca am avea toti venituri ca tine nu ne-am mai plange asta i alta poveste. esential e ca salariile stagneaza, iar pretul carburantului se tot duce..in sus, iar predictiile nu sunt pozitive. @kyp "Economie de carburant= lasat masina in parcare/garaj." din seria "nu oftati, evitati risipa de aer"
  17. cred ca tot de la usa se trage, pe sub plasticul de la stergatoare nu prea are [e unde sa intre, acolo e o scurgere si daca se infunda aia stiu ca vine apa pe partea pasagerului in masina, nu la sofer.
  18. cred ca am vazut pe discovery sau explorer, exact explicatia asta, cu aia din nascar, dar era vorba ceva de siguranta la vitezele alea, cand unul se xpune si piede aderenta, se rastoarna masina din cauza aerului? care opune rezistnta, sau ceva de genul.
  19. la asta nu m-am gandit... mai bine cobor si din mers, sa mai o mai usurez pe viitor, in afara orasului o sa stau in spatele unui tir, ca cica imi scade coeficientul aerodinamic sau cum ii zice, si consum mai putin. o fi pe bune? teoretic vorbind. ce sunt astea si cu ce se mananca? Profile anvelope " Fuel saver
  20. condoleante! daca stai prin sectorul 6 sau adiacente te pot ajuta cu cabluri si curent!
  21. :laugh: daca bate vantul din spate e si mai bine, eu o laspe liber la vale
  22. la fel am patit, lumini ok etc, tzac tzac...apoi am pus cabluri de la alta masina, a pornit imediat, am pust varta dynamic black 75ah si sunt
  23. eu vroiam sa subliniez faptul ca, culoarea rosie nu e Trade mark Brembo, sunt o gramada Big brake kit-uri cu etrieri rosii, si nu cred ca in cazul tau se punea problema de Brembo wannabe, din punct de vedere estetic da foarte bine, in functie si de culoarea jantelor si a caroseriei (contrast).
