poe
Everything posted by poe
  1. Multumesc, mai astept si alte pareri.
  2. Si vrei sa spui ca o turbina noua a rezolvat probema ? Eu nu am auzit de o turbina stricata care sa mearga aleator rau si fara sa scoata fum, sau consum exagerat de ulei, am gasit un raspuns undeva pe un site strain: There is a vacuum control valve on the inlet manifold side of the engine, which controls the boost pressure actuator on the turbo. I have seen a few cases where the filter on this valve gets clogged preventing it from controlling the vacuum correctly and so the turbo is not actuated as it should be. The filter on this valve is not a serviceable item, so can't replaced separately, but it can be removed to see if this has an effect on the performance. If it is OK after removing this filter you should replace the whole valve. Another possibility is that the EGR valve on the engine may be clogged and sticking, so affecting the mixture entering the engine. If you remove the pipe from the front of the EGR valve you should be able to check visibly the condition of the valve. It will have some soot around it, but still move freely when the engine is running. cred ca este piesa 3 de aici: http://bmwfans.info/parts/catalog/E53/SAV/..._turbo_charger/
  3. Salutare, Nu am gasit cu functia search nimic referitor la problema mea, asa ca postez in acest topic. Problema este ca pierde din putere dupa ce se incalzeste motorul si nu tot timpul, aleator, pur si simplu este simptoma ca nu ar mai functiona turbina (gen limp-mode), la reprezentanta si la alte service-uri pusa pe tester nu da nici o eroare, si la service de-abia au descoperit cum face ca nu le puteam demonstra. La reprezentanta spun ca este turbina si una noua e 10000 ron. Eu nu prea cred asta deoarece se intampla aleator si nu scoate fum si nu consuma ulei exagerat.
  4. Am reusit si eu sa scriu pe un DVD BMW Road Map Professional 2010 dar cu viteza minima acceptata de 6x. Am bagat discul in unitate il citeste, vad tarile pot alege adresa, calculeaza ruta dar la navigare nu-mi apare harta, raman doar coordonatele si altitudinea, ce problema poate fi? Conteaza tipul de disc, DVD-R sau DVD+R sau marca? Eu am scris pe un blank HP DVD+R.
