muerte32003
Contact Methods
  • Website URL
    http://
  • Yahoo
    muerte32003
  • Gender
  • Location
    sighisoara
    bmw e36 (320i) coupe
muerte32003's Achievements
  1. locul lui este in canalul de aer de pe partea stanga deobicei, acela de langa locasul proiectorului. canalul de plastic trebuie sa aibe un orificiu unde se baga partea subtire a senzorului de temperatura
  2. poate te ajuta asta in functie de ce e mai jos poti cauta harti pe google sau torrente, in cazul in care nu iti da cineva copia dupa card link de unde am copiat informatia: https://www.farcebook.com/note.php?note_id=392570370530 What other maps can be used in Eonon, and how to make it? 7 January 2010 at 09:39 Many people who own Eonon GPS are not clear that except our built in map, what other map software can be used in our unit, now we would like to introduce to you. Until now, we know the following maps can be used in Eonon: POLNAV, IGO, Tomtom. G2201G2201 1. POLNAV is the built in Eonon map. We use the latest legal edition of POLNAV map! Different from other no brand GPS, we are using the legal map! It's the latest legal edition from POLNAV. 2. IGO is another map which can also be used in Eonon. Here this link in our Eonon forum shared by our customer Xperiat, he told us how to run iGo8 Navigation Software in our GPS: http://forum.eonon.com/Default.aspx?g=posts&t=1007 Quoted from his experience: "I was able to install the iGo8 Navigation software from Navngo! Also loaded up Caifornia Maps and am using this awesome GPS Navigation software. It's muc better than Smart2Go in my opinion and has tons of options!! PM me if anyone wants it and wants to give it a shot. I was also able to run TomTom 5.2 but Maps were inaccessible as the software expects them to be in the My Documents folder. So, I accessed the WinCe shell by getting to explorer (contact me for exact steps) and now my PNA is aso a PDA! How awesome is that?? So, now I boot into a Windows CE desktop interface and can launch my iGo GPS Navigation software from within (using a shortcut)." "The unit runs WinCE 4.2 and the version of iGo8 that I have is for PDAs, PNAs and WinCe4.2 and up devices. All one has to do is install the application to the root of the 2GB SD card and add the appropriate line i the YFAUTORUN.INI file. I have mine as \SDMMC\iGO8\iGO8.exe this instructs the Navigation Startup Screen to point to iGo8.exe in the iGo8 folder n the SD card. That's it...it loads up, discovers the GPS satellites and off you go! I have the California Maps, POIs and all the 3D Terrains loaded up and working well. Its fast and looks fantastic too. If you need the files (softwae + maps + POIs) then I can upload them somewhere (let me know where)...they're close to 1.8GB in size. Also, if you have the YAUTORUN.ini saved with the text "\explorer.exe" then it loads the WinCE 4.2 shell...the complete Windows CE UI with complete navigation, file explorer, one can run programs off the SD Card etc." E1025E1025 3. Tomtom can be also used in Eonon! Shared by one customer who posted here: http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=63829 Quoted from his experience: "Here is how I made "Tomtom" work on my eonon GPS unit with "SD card Mapping" that displays on the DVD unit.You can easily do this too! First I assume you own a licenced version of "Tomtom 6" second copy and save the files currently on the SD card to a safe folder on your pc (just incase you cock-up).Now format the sd card and create a folder on it naming it exactly like this ( MobileNavigator ) open this folder and also the folder on you pc that contains your copy of tomtom6. Copy and paste the files from tomtom6 into the folder "MobileNavigator" on the sd card." Are you still with me?" OK. Now locate the tomtom.exe file (Two red hands) and rename it "MobileNavigator.exe" when you have done this close the folder finaly go to the saved original software on your pc and you will find two very small files named 1.YFAUTORUN.INF and 2.autorun.inf copy and paste these two onto the sd card.Power off the gps unit fit SD card and power on. Bingo! it works well for me. Settings you may need in tomtom. The gps receiver now needs to be set,to do this..... Run the software,Tap screen and select " change preferences " find the icon " show GPS status" select this.Tap configure.Scrole forward to choose "Other NMEA GPS receiver" and select Set GPS Baud rate to " 9600" and click done.Select "Com one".Click done! And that's it!" Hope their experience is useful to you! That's so called community spirit! You can get happiness by sharig and helping others! Let's move on!
  3. pt oscilatii uita-te pe la furtune sa nu traga aer fals consumul marit poate fi si de la sonda/sondele lambda
  4. ti-am trimis un PM. sper sa gasesti acolo ce trebuie... nu stiu daca am voie sa postez link aici asa ca il gasesti in PM daca are airbag dual stage nu va fi functional, asta din cate am citit pe forum spor la citit si sper sa te lamureasca
  5. fara lu[e ai sanse mari sa fi amendat sau sa ramai fara talon, asta daca prinzi un politai nef..ut... iar daca iesi din tara cu masina sigur vei fi amendat (am patit-o in germania, 80e a fost amenda acu 2 ani) pt inceput poti incerca sa schimbi becurile intre ele sa vezi de la ce e (bec sau balast), dar cel mai bine ar fi sa revi la becurile normale sau sa iei faruri cu lupa daca vrei xenon ps: macar 1 bec ar trebuii sa ai cu tine in portbagaj tot timpul
  6. sti cumva daca interfata merge pe e36 (masina e din '93)? tot ce am putut gasi nu are specificat si e36 dar suporta masini din '96-'07 a incercat cineva sa le foloseasca si pe modelele mai vechi de e36 cu succes? imi cer scuze initiatorul topicului pt off-topic
  7. poate daca pui un nume/serie si model sau o poza cu ce scrie pe mufa albastra poate te pot ajuta eu
  8. Din link nu mi sa parut chiar as ade mult de desfacut, sper sa nu ma insel... Oricum astept o vreme ceva mai placuta, ca acuma la -10 -5 cat sunt pe afara e destul de naspa...
  9. Am primit si solutia pt problema mea de la Dan_316 prin pm. Pt cei care au aceeasi problema o pot rezolva exact cum scrie in link-ul urmator: link Multumesc la toata lumea pt sfaturile date.
  10. ms mult. in caz ca nu reusesc nici cum va trebui sa dezactivez pana la primavara. am sa incerc si varianta asta. ms mult
  11. sti cumva unde anume in usa? sa nu ma apuc sa fac usa bucatele )) edit: am mai citit odata toate postarile si am vazut ca zicea MiahiGSM in incuietaore ca e in incuietoare
  12. vin e ja39976 ma gandesc ca asta te intereseaza. ms de raspunsuri, dar pe stalp nu am vazut sa fie nici un contact...
  13. chiar nu a intampinat nimeni problema asta?? sa fiu asa de ghinionist...
