1299 -
Everything posted by edy1092
DA http://img826.imageshack.us/img826/7236/image0024lc.jpg
[Vand] piese OEM import Germania
edy1092 replied to alex.teile's topic in Vanzari piese si accesorii BMW
salut preturile sunt , in ordinea in care mi-ai dat reperele: 2.48 eur ( pret pentru 20 buc/ cantitate minima de comandat) 2.3 eur /buc o, 79 eur .buc Daca imi ajung saptamana asta poti da comanda . Multumesc -
Clip Natur -L=13,20MM - 51471840960 - 7 bucati Screw plug - 17111707818 - 1 bucata Plug - M TECHNIC - 51162239737 - 2 bucati -
CE ANVELOPE SA ALEG?
edy1092 replied to CARBON's topic in Probleme tehnice si rezolvari comune mai multor modele BMW
+1 pt Continental dar Sport Contact 3, am citit numai de bine despre aceste anvelope http://img269.imageshack.us/img269/5892/sportcontact3ad.jpg -
Cu vaselina pe discuri :)
Scrie M+S pe ele. M+S M+S (Mud and Snow) tyres All season The All Season tire classification is a compromise between one developed for use on dry and wet roads during summer and one developed for use under winter conditions. The type of rubber and the tread pattern best suited for use under summer conditions cannot, for technical reasons, give good performance on snow and ice. The all-season tire is a compromise, and is neither an excellent summer tire nor an excellent winter tire. They have, however, become almost ubiquitous as original and replacement equipment on automobiles marketed in the United States, due to their convenience and their adequate performance in most situations. All-Season tires are also marked for mud and snow the same as winter tires but rarely with a snowflake. Owing to the compromise with performance during summer, winter performance is usually poorer than a winter tire.
Pune niste poze cu jantele, nu sunt interesat de capace si nici anvelope, doar cele 2 jante ...dar sa fie sigur pe 16
Cunosc un alt caz din Romania, un 330d cumparata in 2009 din Ro, coleg de servici , si-a dus masina sa schimbe filtre + ulei si ceva bucsi ...la AB in bucuresti l-au sunat dupa 2 zile ca operatunea dureaza ceva mai mult si dupa fix 3 zile ia cazut turbina ...dar el a remarcat inca de cand a iesit de pe portile AB ca masina nu era in toate mintile ei ..... Il cunosc pe individ, omul merge linsitit, are copil mic, nu e genul sa rupa masina pe la semafoare .... i-au schimbat turbina in service cu una defecta 100% Lista o continui pana dimineata si nu numai la bmw se procedeaza asa, am unu pe la skoda / altosyncro are un client caruia nu ia schimbat uleiul de 60 000km ... deoarece stia ca motorul duce, uleiul il face bani deoarece are salariul foarte mic ....
Poate ca este valabil ce spune amicul tau...dar nu in Romania :) Cunosc personal un caz in Viena, MASINA 2010, i-au schimbat parbrizul in bataie de joc, proprietarul si-a dat seama ca nu l-au prins bine dupa ce a vazut o alta masina noua, motorul face figuri, nu porneste la cald, masina a stat mai mult in service de cand a luat-o ... nu-i dau de cap sub nici-o forma, a schimbat integral cu M pachet, bara spate a fost vopsita la un neica nimeni pe bani de nimic in viena a iesit impecabil, bara fata vopsita cu bani grei la repreentanta, are numai valuri si nici nu a iesit la culoare .... problema motorulul nu e rezolvata nici in clipa cand scriu, TOATE ASTEA LA REPREZENTANTA bmw-wien
Sunt indivizi cu orientari diferite, m-am si contrat de curand cu unul, in viziunea lui numai la reprezentanta BMW se pot face schimburile, numai acolo sunt cei mai corecti si buni mecanici din lume si pun piese de calitate, pt el BMW inseamna totul :twoup: daca te face sa poti dormii linistit noaptea dute la AB si fa schimbul de consumabile si de ce orice doresti .....Bafta .
Cand mi-am instalat dynavinul m-am chinuit 4 ore sa scot grila asta de ventilatie centrala, am crezut ca inebunesc, m-am invartit pe langa masina, am tras usor de ea, am bagat lanterna pe acolo sa vad cum e prinsa, dar NIMIC, 4 ore de chin, iar dupa cele 4 ore am tras tare de ea ,,,aveam 2 alternative ...ori se rupe si o fac praf ori iese ..... :twoup: :) :twoup: Nu-mi aduc aminte in 30 ani din viata sa-mi faca atat de multi nervi ceva sau cineva , cat mi-a facut grila asta ..... :twoup: :twoup: :twoup:
Crezi tu ca se merita sa pui varianta mai scumpa? Daca se merita sau nu, stiu doar cei de la rafinarie, macar el este resemnat ca a bagat ce-a mai scumpa/buna motorina din Ro .
Daca tot ai jante aliaj 16 pune anvelope de iarna tot pe aceste jante, daca erau 18 sau 19 nu se merita ....
ar fi bine sa fie si 10 $ numai sa fie identice cu alea de M3 altfel nu are rost sa le schimbe http://img525.imageshack.us/img525/1360/nommingdg5.gif
Cumpar releu bujii incandescente e46
edy1092 replied to vciprian_21's topic in Cumparari piese si accesorii BMW
Ce simptome dau aceste relee cand sunt defecte ? ce eroare apare la o eventuala diagnoza ? Rog sa-mi tirmiti si pe privat raspunsul , Mersi -
[Vand] anvelope SH iarna/vara orice dimensiune
edy1092 replied to noname!'s topic in Vanzari piese si accesorii BMW
Vreau pret + DOT ( nu mai vechi de 2008) + marka la 4 anvelope iarna 265 / 65 / R17 -
Daca ai gasii pe cutie part nr 83220026922 si pe langa asta stii de la verificarea uleiului din cutie ca acel ulei este galben tu ai baga Texaco ETL 7045 ??? :twoup: RASPUNDETI LA ACEASTA NTREBARE , nu ma intereseaza ce recomanda bmw in TIS, sau ce recomanda ei in documantatiile alea PDF ca le stiu si eu ,vreau doar sa-mi rapsundeti la aceata intrebare simpla ..... Daca ai gasii pe cutie part nr 83220026922 si pe langa asta stii de la verificarea uleiului din cutie ca acel ulei este galben tu ai baga Texaco ETL 7045 , DEXRON III, CARE ESTE UN ULEI ROSU ?????? Pe langa asta ma repet m-am interesat la BMW si dupa part nr 83220026922 uleiul vandut de ei este galben .... ESTE LA MINTEA COCOSULUI CA CEVA ESTE IN NEREGULA
Stiam de uleiul mai sus mentionat, si DA este un ulei sintetic si corespunde , eu am vrut sa clarific situatia uleiului Texaco ETL 7045E care nu corespunde deloc cutiilor steptronic deoarece este un ulei mineral (ROSU) si nici vorba de lifetime , mai subliniez faptul ca nici producatorul cutiei GM nu recomanda acest tip de ulei TQ-2, DEXRON III pt cutiile lor .....CIUDAT este faptul ca numai BMW in TIS recomanda acest tip de ulei pt cutiile GM ....dar daca te duci la ei in reprezentanta sa le ceri ulei pt cutia GM nu au in acele bidoane Texaco ETL 7045E :twoup:
Texaco ETL 7045 = DEXRON III ( scrie si pe bidoanele texaco) = ULEI ROSU ( Mineral) In cutiile GM in 5 trepte din fabrica nu se afla ulei ROSU, am vazut cu ochii mei, nu sunt orb , ESTE GALBEN intrebati macar la orice reprezentanta BMW dupa AUTOMATIC TRANSMISSION A5S360R / A5S390R CE CULOARE ARE ULEIUL PE CARE IL VAND IN ACELE BIDOANE si veti afla ca este GALBEN ... Prin urmare acest Texaco ETL 7045 = DEXRON III = ULEI ROSU ( Mineral) nu are ce cauta in cutiile steptronic .... ESTE O GRESEALA ... Bagati ochinul aici, www.automaticchoice.com / www.gm.com ,dati un telefon sau un simplu email :twoup:
Ucide turbina la diesel
Nu , la ei vine in bidoane de 20 litri si te atentioneaza inainte ca este foarte scump si ca nu-l gasesti :twoup:), bineinteles ca nu m-am dat batut de aceste povesti si la o simpla cautare pe net am gasit AICI Address 453-457 Iuliu Maniu Blvd Bucharest, Romania, am facut comanda prin telefon si in 30 minute aveam uleiul acasa :) BAFTA ! http://img202.imageshack.us/img202/6391/foto22b.jpg ATENTIE ! acest ulei este recomandat numai pt cutii GM & ZF in 5 TREPTE
