andy82
    bmw 318d
andy82's Achievements
  1. Salut, De cateva zile, am probleme cu stergatoarele la masina. Ele in mare fuctioneaza normal, numai ca in momnetul in care le opresc in loc sa se duca jos, ele raman pe mijlocul parbrizului. S-a mai lovit cineva de aceasta problema? Banuiesc ca ar fi releul sau vreo siguranta. Cineva mi-a zis de motoras, dar nu cred ca e vreo problema cu el, altfel nu mai functionau deloc. Multumesc,
  2. Dynamic Stability Control (DSC). Dynamic Stability Control (DSC) not only optimises driving stability when starting or accelerating, it also improves traction. In addition, the system recognises unstable driving conditions such as under - or oversteering and helps to maintain a safe course for the vehicle. Advanced sensory technology monitors the wheel rotation speed, lateral acceleration and the yaw rate (rotation around the vertical axis). This data is processed to obtain information about the automobile as it is currently moving, and is compared with data about how it should be currently moving, as supplied by the accelerator and the angle of the steering wheel. If these two lists of data do not match and the automobiles stability is threatened, DSC is activated and influences the brake system or the engine management. This action helps prevent dangerous situations such as skidding.
