cookin
Everything posted by cookin
  1. Poate te intereseaza ceva mai ieftin si de calitate daca tot nu vrei sa investesti f mult... http://www.bmw-oem.ro/non-oem/toba-finala-...-2-x-76-mm.html
  2. Retrofit kit pachet aerodinamic M pentru seria 5 E60 Limuzina fara PDC (Senzori de parcare). Kitul include: - Bara fata si spate model M - Praguri stanga si dreapta model M - Proiectoar stanga si dreapta model M - Difuzor bara spate model M (nu M5) - Grile, canale de aer... etc. Lista completa de componente: 1 buc x 01290017969 Stick-on label EBA-AUFKL. GELB 4 buc x 07129901653 Body nut ST4,8-6 ZNS 16 buc x 07129904150 Body nut ST4,8-9-ZNS3 5 buc x 07147137416 Fillister head self-tapping screw ST4,8X16 2 buc x 07147142326 Clip 2 buc x 51117061659 Spring 6 buc x 51117070199 Hex head screw 1 buc x 51117896586 Grid, center M 1 buc x 51117896587 FRONT LEFT BRAKE AIR DUCT M 1 buc x 51117896588 FRONT RIGHT BRAKE AIR DUCT M 1 buc x 51117896597 Dummy plug left M 1 buc x 51117896598 Dummy plug right M 1 buc x 51117896601 LEVER LEFT M 1 buc x 51117896602 LEVER RIGHT M 1 buc x 51117896603 Cover, fog lamp, left M 1 buc x 51117896604 Cover, fog lamp, right M 2 buc x 51117896611 Adapter M 1 buc x 51117897183 Grid ACC, right M 1 buc x 51117897184 Grid, right M 1 buc x 51117897185 Grid left M - NIVI 1 buc x 51117897186 Grid left M 1 buc x 51117897207 PRIMED FRONT BUMPER TRIM M 1 buc x 51117897210 Flap, towing eye, primed M 1 buc x 51117897211 FLAP PRIME COATEDLEFT M 1 buc x 51117897212 FLAP PRIME COATED RIGHT M 1 buc x 51117897271 Licence plate base primed M 1 buc x 51117897272 Licence plate base primed M 1 buc x 51118032081 Adapter strip M 6 buc x 51127004445 Plug Nr. Buc. 6 1 buc x 51127896615 Mount, bumper rear left M 1 buc x 51127896616 Mount, bumper rear right M 1 buc x 51127896619 Guide, bottom center M 1 buc x 51127897144 Guide, bottom center M 1 buc x 51127897215 Cover for diffuser, primed M 1 buc x 51127897216 Cover for diffuser, primed M 1 buc x 51127897217 Flap, towing eye, primed M 1 buc x 51127897221 Bumper trim panel, rear, primed M 1 buc x 51127897224 Trailer hitch flap, prime-coated M 2 buc x 51181813017 Covering cap WEISS 20 buc x 51711932996 Grommet D=9,1 - GRĂN 4 buc x 51717066220 Clip 16 buc x 51717066223 Clip 16 buc x 51717066226 Spacer clip 16 buc x 51717066229 Securing pin 1 buc x 51717896607 Cover, bottom left 1 buc x 51717896608 Cover, bottom right 1 buc x 51717896625 Cover, battery tray 1 buc x 51717897173 Air duct front bottom M 1 buc x 51717897174 Air duct front bottom 1 buc x 51717905332 Air duct, bottom M 1 buc x 51718036575 Air duct set, front left M 1 buc x 51718036576 Air duct set, front right M 1 buc x 51777907177 Door sill cover, primed left M 1 buc x 51777907178 Door sill cover, primed right M 1 buc x 63177897187 Fog lights, left 1 buc x 63177897188 Fog lights, right 4 buc x 64111375497 Covering cap BLAU + Instructiuni instalare - Kitul este nevopsit. Poate fi livrat vopsit in culoarea caroseriei dumneavoastra la cerere contra cost. - Este necesara seria de caroserie pentru comanda http://www.bmw-oem.ro/promotii/51710396683.html - ACEST PACHET ESTE IN STOC - Pret: 6.173 Ron
  3. 07 11 9 900 518 Hex bolt M10X110-8.8-ZN Nr. Buc 2 07 11 9 904 129 Hex head screw ST4,2X16-C-Z2 Nr. Buc 2 07 12 9 904 221 Body nut ST4,2-3-ZNS3 Nr. Buc 2 07 14 6 986 938 Fillister head screw TS5X20 Nr. Buc 2 51 11 2 495 280 Insert, center M Nr. Buc 1 51 11 2 496 283 Frame, fog lamp left M Nr. Buc 1 51 11 2 496 284 Frame, fog lamp right M Nr. Buc 1 51 11 2 693 539 Flap, towing eye, primed M Nr. Buc 1 51 11 2 694 213 Licence plate base primed M Nr. Buc 1 51 11 2 695 761 ALTERNATOR AIR DUCT M Nr. Buc 1 51 11 2 695 762 Air duct, oil cooler M Nr. Buc 1 51 11 7 890 013 AIR BRAKE CHANNEL FRONT LEFT M Nr. Buc 1 51 11 7 890 014 AIR BRAKE CHANNEL FRONT RIGHT M Nr. Buc 1 51 11 7 891 421 Frame, fog lamp left M Nr. Buc 1 51 11 7 891 931 Cover left M Nr. Buc 1 51 11 7 891 932 Cover right M Nr. Buc 1 51 11 7 893 048 Web, center, primed M Nr. Buc 1 51 11 7 894 379 PRIMED FRONT BUMPER TRIM M - PDC Nr. Buc 1 51 11 8 174 185 EXPANDING RIVET SCHWARZ Nr. Buc 30 51 11 8 191 149 Gasket 2125MM Nr. Buc 2 51 12 2 498 489 Bumper trim panel, rear, primed M Nr. Buc 1 51 12 2 693 663 Flap, towing eye, primed M Nr. Buc 1 51 12 8 174 878 Insert Nr. Buc 1 51 41 8 201 057 Axial securing clip Nr. Buc 10 51710027254 Retrofit kit,M aerodynamic kit (basic) PDC - Pret 4662 Ron cu TVA inclus
  4. http://www.bmw-oem.ro/tag/product/list/tagId/12/
  5. Pachet aerodinamic Seria 3 e46 Coupe si Cabrio cu PDC Include: 1 buc x Spoiler fata 1 buc x Spoiler spate 1 buc x Prag stanga 1 buc x Prag dreapta 1 buc x Eticheta - Doar pentru modelel cu PDC (pe bara din spate). Toate piesele se vand nevopsite. Se pot vopi in culoarea caroseriei dumneavoastra contra cost. Folositi formularul de contact daca doriti ca piesele sa fie livrate vopsite *Pozitia 1 in poza. Pret: 1720 RON Tva Inclus (factura, garantie) Tel: 0741 BMW OEM
  6. Maneta schimbator de viteze model M pentru cutie manuala cu 5 rapoarte Culoare neagra, inel de aluminiu la baza. Noua si originala. Se emite factura si beneficiaza de garantie. Pret : 288 Ron Tva inclus. Tel: 0741 BMW OEM http://www.bmw-oem.ro/media/catalog/product/cache/1/thumbnail/600x600/9df78eab33525d08d6e5fb8d27136e95/2/5/25117896031.jpg
  7. Set 4 jante Bmw 18 inch - Radial spoke - Style 32 - Brillant-Line Pret: 1.935 RON / set 4 jante. Jantele sunt noi si originale. Dimensiuni 8j x 18" ET 20 - Toate cele 4 jante au aceiasi dimensiune. -Jantele se vand fara anvelope, capacel emblema, valve sau alte accesorii. http://www.bmw-oem.ro/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/3/2/32.jpg 0741 BMW OEM
  8. Trusa medicala e60 - 171,06 RON Tva inclus ( Noua, originala si in termenul de valabilitate) 0741 BMW OEM
  9. Salut, nu am 128 la promotie dar le am pe astea pe 18" daca te intereseaza: -Set 4 jante Bmw 18 inch - Star spoke - Style 69 Dimensiuni: 2 jante dimensiunea - 8j x 18" ET 20 2 jante dimensiunea - 9j x 18 ET 24 -Jantele se vand fara anvelope, capacel emblema, valve sau alte accesorii. Pret: 1.984 Ron TVA Inclus. Imi cer scuze dar am gresit nr de tel postat ...Nr de tel corect este: 0741 26 96 36
  10. De vanzare volan sport nou si original cu comenzi incluse - se potriveste la seria 3 e46. Pret promotional: 790 Ron ( TVA inclus). Se emite factura si beneficiaza de garantie. Tel: 0741 26 96 36 * Pozitia 1 in figura.
  11. Nu am la promotie decat dimensiunea asta style 32... Dar am asa pe 17"...daca te intereseaza: - Set 4 jante Bmw 17 inch - Cross spoke - Style 133 - Pret 1548 Ron Tva Inclus. Noi, Originale. 4 jante x 8j x 17" ET 47 Jantele se vand fara anvelope, capacel emblema, valve sau alte accesorii.
  12. Salut, 11137789387 - 1200 Ron Tva Inclus noua, originala , factura , garantie. Livrare in 48h pt. Bucuresti + 24h pt. provincie. Tel: 0741 BMW OEM
  13. Set 4 Jante Bmw 18" - Brillant-Line Jante noi si originale BMW. Pretul afisat este pentru tot setul de 4 jante. Set 4 Jante: Dimensiuni 8j x 18" ET 20 - Toate cele 4 jante au aceiasi dimensiune. -Jantele se vand fara anvelope, capacel emblema, valve sau alte accesorii. -Jantele aduc numai la comanda din Germania in aproximativ 48 ore. Se emite factura fiscala iar produsele beneficiaza de garantie. Cost livrare in provincie 60 lei prin Urgent curier. Cost livrare in Bucuresti 0 Lei. Tel: 0741 26 96 39
  14. Pachet aerodinamic Seria 3 e46 Coupe si Cabrio cu PDC - Nou si original Bmw! Include: 1 buc x Spoiler fata 1 buc x Spoiler spate 1 buc x Prag stanga 1 buc x Prag dreapta 1 buc x Eticheta - Doar pentru modelel cu PDC (pe bara din spate). Toate piesele se vand nevopsite. Se pot vopsi in culoarea caroseriei dumneavoastra contra cost. Pret : 1.719,88 RON TVA Inclus. (se emite factura si beneficiaza de garantie) Tel: 0741 BMW OEM Stoc limitat. Se aduce numai la comanda din Germania in aproximativ 48 ore. *Pozitia 1 in figura.
  15. cit costa un far dreapta xenon pt bmw 320 D E90 seria WBAVC31030VA20016 Salut, 4170 Ron TVA inclus.
  16. Salut - 51168230902 - 180 Ron /buc. Timp de livrare 48 ore. Comanda se da de luni pana vineri pana la ora 14:00. Esti sigur ca este pe stoc la furnizorul tau? Nu am spus ca este pe stoc am spus ca este livrabila in 48 ore. Adica daca faci comanda luni pana la ora 14:00 o sa primesti piesa in cursul zilei de miercuri. Este valabil pentru 95% din piese, sunt si repere care mai intarzie cateva zile dar mai rar. Am pe stoc. E cado pt. tine!
  17. Salut - 51168230902 - 180 Ron /buc. Timp de livrare 48 ore. Comanda se da de luni pana vineri pana la ora 14:00.
  18. OEM - Pret 750 Ron TVA Inclus Livrabil in 2 zile. 0741 BMW OEM
  19. Vand 1 amortizor original Bmw pentru partea din fata e39, folosit dar in stare f. buna. Cod: 31311096858 Se potriveste la urmatoarele modele: Seria 5 e39: 520i, 520d, 523i, 525d, 525i, 528i, 530d, 530i. Fara suspensie sport. Pret 200 Ron. Predare personala in Bucuresti. In provincie (Urgent Curier). In sistem ramburs cost 20 Ron. Tel: 0741 26 96 36
  20. Am ramas fara cuvinte! :twoup: :) :) Nu mai zic nimic ca nu are sens...o singura precizare nu e vb de nici o posta e vorba de curierat rapid (urgent curier) care vine acasa, la usa... Adrian M - OH MY GA!!!!
