NorbyW12
Everything posted by NorbyW12
  1. Vand woofer auto mac audio SX12 diametru 30cm putere nominala - 300W RMS putere maxima - 1000W impedanta - 4ohmi raspuns in frecventa - 21- 500Hz bobina de 2& quot; cu cablaj japonez TOTOKU si ventilatie suplimentara magnet de 20oz terminale push sasiu metalic Peiying Alien PY-2H30R RMS Power (4 ohms): 200W RMS Power (4 ohms) chanels: x 2 RMS Power (2 ohms): 300W RMS Power (2 ohms) chanels: x 2 Bridged RMS Power: 500W Bridged RMS Power chanel: x 1 Minimum Impedance Unbridged: 2Ohm Minimum Impedance Bridged: 2Ohm Impedance imput: 15k Ohm Fan Cooled: No Signal to Noise Ratio: 90dB Channel Separation: 50dB Remote bass boost control: 0dB - +12dB High- Pass filter: 45Hz - 300Hz Bass Boost: 0dB - +12dB Low- Pass filter: 45Hz - 300Hz Fuse Rating: 30Ax2 se mai dau si cablurile necesare pentru montaj + un adaptor cu iesire RCA. produsele sunt in stare noua am si cutiile lor, accept si unele schimburi nr contact : 0751434189 pret 1300 RON negociabil .
  2. -AMPLIFICATOR 5.1 -CONTROL INDIVIDUAL PT FIECARE CANAL -3 SET STEREO AUDIO INPUT -DTS/AC-3 5.1 AUDIO INPUT -VFD DISPLAY 7 DSP EFFECT -RADIO AM/FM ,FULL FUNCTION REMOTE CONTROL -BOXE FRONTALE:output power 10-100W(4 ohm) -Freq response:45Hz-20 Khz -Sensitivity:88 dB -CENTRU/SURROUND:output power 10-60W(8 ohm) -Freq response:75Hz-20 Khz -Sensitivity:85 dB -SUBWOOFER(incorporate in boxele frontale) -output power 30-130W(4 ohm) -Freq response:30Hz-35 Khz -Sensitivity:87 dB -AMPLITUNER: 110 W RMS output power -(long term,THD<3%) -FRONT CHANNEL: 2x40W -CENTRE& SURROUND CHANNEL:3x10W boxele sunt in stare foarte buna si suna foarte bine ! ! petul este de 600 RON negociabil contact id messenger : norbysr sau 0751434189 si trimit oriunde in tare prin fan curier !!!
