GABIVVX1
    3
GABIVVX1 last won the day on August 31 2015
GABIVVX1 had the most liked content!
    G4
GABIVVX1's Achievements
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
377
  1. Rear axle oil specification ---Hypoid oils for axle gearboxes with laminar self-locking differential. And for axle gearboxes with electro-hydraulic locking differential. BMW Synthetic axle gearbox oil MSP/A 83 22 9 407 870 *** Castrol SAF - XJ Mobil gearbox oil VS 500 Aral gearbox oil BS-LSX BP Energear SHX-ZR Shell gearbox oil ZLS BMW Agip HLZ Fina Pontonic MLX ---Hypoid oils for axle gearboxes without laminar self-locking differential. BMW Synthetic axle gearbox oil SAF- XO / OSP 33 11 7 695 240 *** AGIP HLX Castrol SAF - X0 Mobil Gearlube VS 600 VALVOLINE HL Plus BP Energear SHX Shell gearbox oil OLS-BMW Esso gearbox oil NLS 75W-90 *with LSD (self-blocking differential) 83 22 9 407 870 Original oil *without LSD (self-blocking differential) 83 22 9 407 768 Original oil
  2. Luam la intamplare BMW 5 (E60); 525 d; kW 120 *Engine oil with filter 8,25 litres *Engine oil viscosity BMW Longlife 04 SAE 0W-30|SAE 0W-40|SAE 5W-30|SAE 5W-40 *Engine oil specification BMW Longlife-04 *Manual gearbox oil Gearbox GS6-53DZ 1,60 litres *Manual gearbox oil specification -up to 2007/02, Gearbox GS6-53DZ 83 22 0 309 031 Original oil -from 2007/03, Gearbox GS6-53DZ 83 22 7 533 818 Original oil *Automatic gearbox oil Gearbox GA6HP26Z, New filling 9,50 litres *Automatic gearbox oil specification Gearbox GA6HP26Z 83 22 0 142 516 Original oil *Rear axle oil specification 33 11 7 695 240 Original oil *Power steering oil 1,00 litres(4) *Power steering oil specification Cover marking ATF 81 22 9 400 272 Oil colour red Cover marking CHF 83 29 0 429 576 Oil colour green *Cooling fluid specification 83 19 2 211 191 Original anti-freeze agent *Brake fluid when changing 1,00 litres Brake fluid specification 83 13 0 443 026 Original brake fluid *Air-conditioning system refrigerant 690 - 710 Gram The definitive information is given on the type designation plate in the engine space. *Refrigerant specification R134a *Air-conditioning system oil 170 - 190 cm³ The definitive data is given on the type designation plate of the air-conditioning compressor. *Air-conditioning compressor oil specification 81 22 9 407 724 Original oil Compressor oil refilling quantity when replacing the high-pressure line 35 cm³ Compressor oil refilling quantity when replacing the low-pressure line 35 cm³ Compressor oil refilling quantity when replacing the compressor 50 cm³ Compressor oil refilling quantity when replacing the condenser Condenser with integrated dryer 55 cm³ Compressor oil refilling quantity when replacing the dryer Condenser with integrated dryer 55 cm³ Compressor oil refilling quantity when replacing the evaporator 35 cm³ (4)Data are guide values! Finally check filling level on the vehicle! Cooling fluid specification 83 19 2 211 191 este antigel albastru.
  3. http://bringatrailer.com/2016/08/27/rare-four-door-cabrio-1993-bmw-318i-baur-in-the-us/ Pareri ?
  4. 11617801206 pentru E60, 520d, M47N2 sau E83, 2.0d, M47N2 ,furtun partea dreapta intercoler-turbo. http://bmwcentrum.pl/uszczelka-przewodu-powietrza-doladowania-m47n-m47n2-bmw-e46-e60-e61-x3-e83-e87-e90-e91,id4773.html
  5. Doar la DIESEL bielele fac soc mecanic si se stramba,la benzina nu am auzit. Totusi nici apa multa in motor nu este binevenita la banzinare.
  6. KLOKKERHOLM 0061581 lei 150 maxim KLOKKERHOLM 0061582 lei 150 maxim VAN WEZEL 0646147 VAN WEZEL 0646148 Varianta pt 4 usi. http://parts62.ru/products/KLOKKERHOLM/0061581.html Asa arata piesa,mergeti la un magazin care are contract cu ELIT si in 2 zile va soseste din Cehia.
  7. Deci e eveniment petrecut la noi in tara....asta e si mai trist.(mi-a trimis doar pozele si am crezut ca in bulgaria sa intamplat accidentul)
  8. Poze primite de la un prieten din vacanta in bulgaria.
  9. 13537787236 13532247156 Verifica oringurile de la injectoare si saibele de foc. In primul rand vezi pompa de inalte 13518511826,posibil ea sa fie cauza principala si sa iti bage motorina in ulei.
  10. Turbina fluiera pt ca nu mai are ungere adecvata,uleiul amestecat cu motorina ...a rezultat un fel de ulei lung si subtire ..un pisat. Nu mai merge cu masina ca faci motorul ala de balamuc.
  11. Da , asa este,nu prea mai gasesti codul respectiv de ambreaj si problema este ca nici sachs nu-l mai livreaza(pe codul asta in cutia de sachs gasesti setul de ambreaj luk cu stantele luk mascate si cu coduri sachs aplicate cu vopsea). Deci daca luk nu mai produce nici sachs nu o sa mai gasesti. Posibil toata treaba provine de o greseala a celor din grupul Schaeffler care din greseala au ,,uitat'' sa mai produca codul respectiv sau pur si simplu e o greseala undeva. Trimite un mail aici si cere un raspuns despre codurile:623 3001 00 si 600 0030 00 (setul cu volanta). http://webcat.schaeffler-aftermarket.com/web/schaeffler/ro_US/contact.xhtml
  12. 415 0282 10 volanta luk superdisponibila 623 3182 00 set ambreaj luk superdisponibil BMW 3 (E46) 318 d | Saloon Power; 85KW / 116HP Capacity 1.995ccm / 2,0l Engine Type / Fuel Type Diesel Cylinders / Valves; 4 / 4 Motorcodes M47 D20 (204D4)
  13. https://www.ecstuning.com/b-vaico-parts/parking-brake-cable-right/34411165020~vai/ https://www.ecstuning.com/b-febi-parts/parking-brake-cable-left/34411165021~feb/ Sunt cu catare,st mm 1693 si dr mm 1708 (lungime)
  14. Din ce oras esti ? Cunosc personal pe cineva care masina din poza si acum restaureaza un 1600.
