Am facut si un scan. Mi-a dat urmatoarele erori: # ERRORS DETAILS - DTC(hex)/PARAM(hex) --------------------------------------------------------------------------------------------------------------------------- DDE -> 08/C8 - Glow-plug system Shadow-memory: 2D/06 - Electronic car immobilisation system 10/02 - Power supply 45/08 - Control unit DDE (CAN controller) 46/0A - Control unit, injection pump (communication) 2F/10 - Speed sensor, crankshaft 65/08 - Charge-air-pressure control 49/08 - Speed sensor, injection pump 48/10 - Control, timing device 08/C8 - Glow-plug system 06/08 - Exhaust-gas recirculation EWS -> 0F/3F - Power on reset 00/03 - Wrong identification, key 0 03/06 - Toleration of changing code increased, key 0 10/01 - Wrong identification, key 1 A/C -> 18/02 - Water valve SRS -> 05/C2 - Belt tensioner, driver's side 0A/42 - Side airbag, rear left 0B/42 - Side airbag, rear right 06/C2 - Belt tensioner, passenger side IKE -> BE/C8 - Data-filing difference to central light module (LCM) 8C/84 - Voltage supply, terminal R, faulty 11/84 - Thermal oil-level sensor CE/81 - Outside-temperature sensor LCM -> 1E/01 - Control unit error in HVAC 1F/04 - Activation, motor for HVAC 1 20/03 - Activation, motor for HVAC 2 Shadow-memory: 33/1F - Sidelight, front right 34/05 - Brake light, left 35/11 - Brake light, right 37/03 - Turn indicator, front right 38/1F - Sidelight, front left 39/0B - High beam, left 3A/03 - High beam, right 3B/04 - Sidelight, rear left 3C/1F - Licence plate light 3D/06 - Sidelight, rear right 3E/06 - Rear fog light faulty 3F/03 - Turn indicator, rear left 40/07 - Turn indicator, rear right 41/0E - Low beam, right 42/09 - Low beam, left ZKE -> 30/03 - K-bus or Control unit for Instrument cluster basis (Gateway) 3D/3F - Central locking system: Short circuit or Open circuit at Motor Tailgate 02/02 - Central locking system: Fuse 01/01 - Wiper: Fuse for Pump, Interior light, Customer cut-off 29/0B - Central locking system: Relay doesn't switch to on at Unlocking 3B/3F - Interior light: Short circuit Shadow-memory: 90/3A - Battery Voltage: Open circuit 93/01 - Repeat blocking: Unlocking Tailgate RAD -> 02/02 - Error power-supply for antenna # SCAN END Acum nu mai stiu care din ele erau cu rosu sau care cu galben. Tipu le-a sters si a doua oara nu a mai aparut. El spunea ca e dus releul de bujii. Sa fie releul ala atat de pacatos incat sa nu lase masina sa porneasca ? Tot evit sa pun problema pompei de injectie ... inca nu-s psihic pregatit ) glumesc.
