Trask
Everything posted by Trask
  1. Salut, daca nu ai rezolvat, ma poti contacta si te ajut eu cu cablul AUX. Catalin - 0721925442
  2. Salut. Da, va fi disponibil din nou, in curand. Ne putem auzi la un telefon daca esti interesat. 0721925442
  3. Frumoasa masina! Din ce an s-a pus CIC pe E60?
  4. @pilifache - Inlocuiesti modulul de sunet cu un BM54 fabricat dupa 09/2002 iar cablul AUX il legi direct in modul. Daca faci rost de modul compatibil, te ajut cu tot ce ai nevoie.
  5. Salut, doar AUX va merge. Fara o interfata nu merge USB la E46.
  6. N-am mai postat de mult de forum.Dupa 5 ani frumosi petrecuti impreuna, masina a fost vanduta.Prin urmare, acest topic poate fi inchis. Drumuri bune tuturor! https://lh3.googleusercontent.com/LpZfUAq6XZH4mzjZvcNoqxl9bSVeYJ0Zi4S_oRdt_IB5HQNIGnA6V6GypZbVq-pptsiz2TO9F_VHd98YNUEoC5qnAYPFCNkE8Ka0xNrXGxC2xppJADo7Lx_UXTV1PPxMVmZSji6NvRGAx_qnsdvQ2C2SLjVmg2PKgEpNLpF3TfROkLqNgisS-Ukgd9cHaMLnh8DhGlPJXp7rA8valgqHUO39FcwmF9E0MoN2wOPIv51uHFkGyoY0-Wn-Adsh9eV9VgGoeFSxcjBOdHfPzd12uSaBzVm9RUUwpLVH1gqFm12OK4Ge2MseqJf60s1Ulkmq_u68np8MHhYbzw1pqyKK0s28LpV4t0N_5Gxg9oB4tuQOFYBWfXLwxmhleCDBlDVOrHgS_s9p_nuRdYm8sZc3U7X2kn2LWHX07GCUWoyq11iZJ1u-0FRdl2cieL8af8Yk07OsZDeLGkiER7mf6VOXoCD9IolCXrOhylKaZ5-cderuD6IUGyrF3mR7ChEgUjRe18sosCLO4gD5wLc9qJdFMwF_AR-OFF2aqqrtI9SasXkCX4nyIL4Jdlm7FWQihvHPhUvarm9_rCiRYYimex1cRcQBUYlMaW4lLU8j2cP4=w1678-h944-no https://lh3.googleusercontent.com/h9InBRaA6lyNSQOVAolEF7yyGJXqktgS8noocZziL2JqpBwVOm1Ln1ubSnOVCcvvmwa3FLfXaVlLYPwQhKe0cOBQmPSaFKMMLFSCQjrbXVsGcpszeWztisjIrKXGMngL2IO7unHIemUsNNPxEL8JW4SifitNqaApRWu72kv7RZ2eh1eaaxUNkxgOg6dlXvUprEoIvmHLCkkl-vkA1Vnoj1LAfqyxXZZZdHkvy5aL9p1kgbovDPg6x5aiHIaqHEsiHmGWjPIsXQp7miF4L-P3UgK1H0SG2GU2wKxi3ylfMj3bY0kVjocf7vThk2AAE-K-V9sfm9k0XW_Xdoy34138NOLlW94bCztU0r3FFe7YnO5qIImc2lFbepiLC4_ugC374Q3--8tZAxPIO5mGbGfcK-_IzFyD3BeK7959uq_aaJEOCUCvO-z62HkX1WUZ1cV0RHC4e7-78gfdPuBQpemhgRRSh66ZHEVcHMVVWY9kynhvFFkfES0S4AkbrlxgpXTowFvaVczzEFfnrVzmcaFZMnbkERrYHbV8jYtZy3FlbVlRyWzG75BY31dsBJU-buGcH5CDmqd8y_eg3jk5xnzl3UnmAJ0SDvqAhrh9FdFS=w1678-h944-no
  7. Din ce am mai citit si in alte surse, la motoarele dupa 2010 riscul de rupere al distributiei este mult mai mic sau deloc. Zgomotele specifice persista insa.
  8. Salut. Da, in cazul tau, unitatea este M-ASK, ai nevoie de cablu plus o mufa adaptoare. Pe langa cablul si mufa pe care ti le pot livra, este nevoie si de codarea (activarea) functiei AUX. Cu acest serviciu te pot ajuta doar daca ajungi in Bucuresti. Merci, Catalin
  9. Am citit mare parte din paginile topicului insa imi cer scuze anticipat daca se repeta intrebare: Modelele fabricate dupa 2012 (06.2012 mai exact, cod N47T) sunt afectate in proportie mai mica? Sunt interesat de achizitionarea unui E92LCI de 163CP (model Belgia cu power reduction) insa problema distributiei ma pune pe ganduri. Mentionez ca masina o comand online astfel ca nu pot sa ascult motorul sau sa fac verificari suplimentare.
  10. Exista si E46 cu DPF, modelele 2005-2006.
  11. La E90 si E87 este des intalnit fenomenul. Se rezolva doar prin recodarea unitatii CD. La E46, modul de AUX nu se activeaza prin codare ci prin filtrul de pe cablu.
  12. Foloseste "AUTOSOL" si fereste-le de spuma activa. Incearca sa mergi la spalatoriile care folosesc spuma alcalina, este mult mai bine si pentru vopsea/lac.
  13. Sa-nteleg ca aceste distantiere nu permit arcurilor sa se comprime peste limita impusa? Pare o idee buna insa in cazul asta socul va fi resimtit de caroserie si va fi un disconfort major.
  14. Dupa conectarea cablului, functia "AUX" va aparea in meniu.
  15. Salut. Am eu receptor bluetooth care se leaga pe AUX. Putem discuta in privat daca te intereseaza.
  16. Salut. Este compatibil. Daca esti interesat, iti pot trimite un cablu AUX. Lasa-mi te rog pe privat datele de livrare.
  17. 225/45/17 pe 10J este ok. Vor face un strech decent insa nu suficient. Este nevoie de mult mai mult, mai exact modificarea aripilor.
  18. Salut. Tind sa cred ca nu vor intra, cel putin pe spate, fara interventii asupra aripilor. Consider ca masina va avea suspensie sport si va fi lasata, altfel nu vad sensul achizitionarii unor astfel de jante. In cel bun caz va trebui sa faci: - roluire aripi spate, aplatizarea buzei - anvelope mai inguste, noi sau dot recent, gen 215/40/17 sau 205/45/17. - Negative camber. Bratul stock permite din cate stiu o inclinare de 3.5grade Eu am avut 17x9J ET20 si mi-au intrat fara probleme cu anvelope 205/45/17, suspensia lasata maxim. Succes! btw, jantele sunt un model frumos dar se preteaza mai mult modelelor E30/E36. Parerea mea...
  19. Si la VW e la fel, cel putin la Golf7. In felul asta pot conduce si incepatorii, fara grija ca le moare motorul la semafor.
  20. Nu cred ca exista asa ceva... Si eu as avea nevoie insa nu cred ca exista. TabletTalk este destul de limitat si ofera suport doar pentru SMS.
  21. Salut, pe casetofonul cu navi monochrome nu functioneaza cablul AUX.
  22. Iarna - jante aliaj 17" - suspesia ridicata Vara - jante aliaj 18" - suspensia lasata
  23. Incarcatorul este prost , cablul OTG este prost calitativ sau mufa microusb este proasta. Eu am rezolvat problema construindu-mi singur un cablu otg, cu fire groase (cablu de date NOKIA), nu lite chinezesti.
  24. @xfil3s - Iti multumesc si eu pentru feedback si colaborare! Toate cele bune!
