SunKode
    BMW e90
SunKode's Achievements
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
-6
  1. Da, cere licenta. Am acest key: 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 Ma poate ajuta cineva cu licenta?
  2. Salut. Trebuie sa schimb racordul flexibil la un Bmw 320d, E90, modelul facelift, cel de 163cp. DacĂŁ știe cineva ce dimensiuni are, vĂŁ rog sĂŁ ĂŽmi spuneți și mie. O sa ma duc la un sudor priceput, dar as vrea sa rezolv astĂŁzi si sa cumpĂŁr piesa in avans. Mersi!
  3. ar trebui sa o verifice si el,macar de curios
  4. Cum "a descoperit"? Unde? Nu e vorba despre dauna totala sau despre discuții tehnice. Tipul care o vinde se știe cu varamiu și e de ĂŽncredere. In cartea mașinii cicĂŁ nu scrie ce emisii are. Sub capota ar fi ceva. O sa revin cu detalii.
  5. Salut. Sunt off-topic. Am un vĂŁr care si-a luat un Bmw din Europa (Lituania) - ĂŽnmatriculatĂŁ acolo. Modelul e de SUA. Cum va fi la rar? Trebuie sa faca test de emisii(3250 lei)? Mulțumesc.
  6. Distribuția. Axele cu came nu mai erau sincronizate din vanosi. Lanțul era fleașcĂŁ, o bucatĂŁ dintr-o patinĂŁ era ruptĂŁ.
  7. Cât de sigur esti pe soft?
  8. Când am luat-o nu se auzea nimic. Era praf inclusiv pe busonul de la ulei, nu fusese umblat pe acolo. 1. 1l dupĂŁ 1700km. FĂŁrĂŁ gram de fum. Plus cĂŁ acel clicking NU se aude decat in ture mici, pana la 2000, aproximativ. Cum ar putea sa consume motorul ulei daca nu scoate fum deloc? 2. Pot verifica rapid distribuția vizual? 3. La relanti un mecanic a scos pompa de ĂŽnalte, a crescut turatia, si nu se mai auzea acel zgomot. 4. Pe tester a dat eroare pe un Vanos. Poate fi el rĂŁspunzator pentru toate problemele spuse? @zeronoo @cristianro
  9. Am schimbat bujiile si bobine inducție. Am mers 1400km cu ea și uleiul e la level maxim...Poate nu i-a plĂŁcut "fostul" ulei. Nici o avertizare in bord, l-am verificat mereu și stĂŁ la lvl max. A rĂŁmas zgomotul "tick" de la relanti și ture mici. Ăntreruperea e fix la 2600rpm, doar acolo mi se ĂŽntâmplĂŁ. Am fost la Bavaria in Militari și mi-au zis cĂŁ e distribuția de vinĂŁ, zgomotul fiind de la lanț. Mi se pare imposibil sĂŁ se audĂŁ atât de rĂŁu sau in felul ala, mai degrabĂŁ simt ca mi-au zis asta sa scape de mine. Intrebat 3 mecanici, toti pĂŁreri diferite. Aparent prea puțini cunosc cu adevĂŁrat motorizarea asta. VĂŁ mai țin la curent. Când o pornesc la rece ĂŽmi sta undeva la 1200 rpm si "tzacanitul" NU se aude. Abia dupa vreo 20-30 sec pânĂŁ cand scade puțin in ture, apare și zgomotul. DacĂŁ era lanțul de la distribuție, nu fĂŁcea și imediat la rece? Mai ales atunci!
  10. SunKode
    N20
    Salut! Avem posesori pe aici de Bmw'uri cu motor N20/N26? Benzinarele turbo in 4 cilindrii. In special București sau Târgoviște. Am câteva ĂŽntrebĂŁri pentru cei care dețin.
  11. @alexmag90, mĂŁ duc cu ea la Bavaria in 1 sĂŁptĂŁmânĂŁ cĂŁ e full. De ce? Ai și tu 328i cu probleme?
  12. Ok, sĂŁ nu abandonez topicul. Progrese mari nu am fĂŁcut. Am programare la Bavaria peste 11 zile (e full) și luni 28 ianuarie la Service Scream (Tezparii) Bmw. Zilele trecute am fĂŁcut schimbul de ulei si filtre, am pus Bmw 5w30. Mașina o am de puțin timp, nu stiu ce ulei a avut ĂŽnainte sau când fusese schimbat. Am mai parcurs vreo 500km cu ea si i-am mĂŁsurat mereu uleiul. E la level max. Prin pierderi de putere mĂŁ refer de fapt la mici ĂŽntreruperi. Și numai intre 2-3000 ture (chiar si la mers cu viteza constantĂŁ) se ĂŽntâmplĂŁ saau când ii dau kick-down mai are momente cand nu mai trage. Daca iau gazul si accelerez, trage de rupe, ĂŽși revine. De asemenea mai are sunetul ĂŁsta ciudat la relanti: https://youtu.be/vrJ7aBZZHvg https://youtu.be/CbbagsmID8M Sunt videouri puse de mine, nu comparații.
  13. Tot timpul face asa. Mai am alte simptome: Intrerupe intre 2-3000 ture, chiar si la viteza constanta. Mi-a dat eroare "drivetrain malfunction. full performance is not available". S-a oprit motorul, am stat 1 minut si dupa totul Ok. Daca ii dau cox, apare eroarea destul de repede. Am pus-o pe tester si a dat: verificare bujii, cablaje sau calculator motor. Si totusi zgomotul nu prea are cum sa fie din cauzele astea. Am programare la BMW peste 1 saptamana, momentan e full. De ce e "faimos" si de la ce ar putea fi? Pare ca stii mult mai multe decat mine.
  14. Salut. Masina in cauza e un F30 328i. Are un sunet ciudat: https://www.youtube.com/watch?v=vrJ7aBZZHvg Ce credeti ca ar putea fi? Mai ales cei care cunosc motorul, sunetul si problemele lui.
