SunKode
31 -
Everything posted by SunKode
ISTA PROGRAMARE SI DIAGNOSTICARE
SunKode replied to Reluthex1guy's topic in Audio/Video/Navigatie/Electronica auto
Da, cere licenta. Am acest key: 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 Ma poate ajuta cineva cu licenta? -
Salut. Trebuie sa schimb racordul flexibil la un Bmw 320d, E90, modelul facelift, cel de 163cp. DacĂŁ știe cineva ce dimensiuni are, vĂŁ rog sĂŁ ĂŽmi spuneți și mie. O sa ma duc la un sudor priceput, dar as vrea sa rezolv astĂŁzi si sa cumpĂŁr piesa in avans. Mersi!
Cum "a descoperit"? Unde? Nu e vorba despre dauna totala sau despre discuții tehnice. Tipul care o vinde se știe cu varamiu și e de ĂŽncredere. In cartea mașinii cicĂŁ nu scrie ce emisii are. Sub capota ar fi ceva. O sa revin cu detalii.
Salut. Sunt off-topic. Am un vĂŁr care si-a luat un Bmw din Europa (Lituania) - ĂŽnmatriculatĂŁ acolo. Modelul e de SUA. Cum va fi la rar? Trebuie sa faca test de emisii(3250 lei)? Mulțumesc.
Distribuția. Axele cu came nu mai erau sincronizate din vanosi. Lanțul era fleașcĂŁ, o bucatĂŁ dintr-o patinĂŁ era ruptĂŁ.
Cât de sigur esti pe soft?
Când am luat-o nu se auzea nimic. Era praf inclusiv pe busonul de la ulei, nu fusese umblat pe acolo. 1. 1l dupĂŁ 1700km. FĂŁrĂŁ gram de fum. Plus cĂŁ acel clicking NU se aude decat in ture mici, pana la 2000, aproximativ. Cum ar putea sa consume motorul ulei daca nu scoate fum deloc? 2. Pot verifica rapid distribuția vizual? 3. La relanti un mecanic a scos pompa de ĂŽnalte, a crescut turatia, si nu se mai auzea acel zgomot. 4. Pe tester a dat eroare pe un Vanos. Poate fi el rĂŁspunzator pentru toate problemele spuse? @zeronoo @cristianro
Am schimbat bujiile si bobine inducție. Am mers 1400km cu ea și uleiul e la level maxim...Poate nu i-a plĂŁcut "fostul" ulei. Nici o avertizare in bord, l-am verificat mereu și stĂŁ la lvl max. A rĂŁmas zgomotul "tick" de la relanti și ture mici. Ăntreruperea e fix la 2600rpm, doar acolo mi se ĂŽntâmplĂŁ. Am fost la Bavaria in Militari și mi-au zis cĂŁ e distribuția de vinĂŁ, zgomotul fiind de la lanț. Mi se pare imposibil sĂŁ se audĂŁ atât de rĂŁu sau in felul ala, mai degrabĂŁ simt ca mi-au zis asta sa scape de mine. Intrebat 3 mecanici, toti pĂŁreri diferite. Aparent prea puțini cunosc cu adevĂŁrat motorizarea asta. VĂŁ mai țin la curent. Când o pornesc la rece ĂŽmi sta undeva la 1200 rpm si "tzacanitul" NU se aude. Abia dupa vreo 20-30 sec pânĂŁ cand scade puțin in ture, apare și zgomotul. DacĂŁ era lanțul de la distribuție, nu fĂŁcea și imediat la rece? Mai ales atunci!
@alexmag90, mĂŁ duc cu ea la Bavaria in 1 sĂŁptĂŁmânĂŁ cĂŁ e full. De ce? Ai și tu 328i cu probleme?
Ok, sĂŁ nu abandonez topicul. Progrese mari nu am fĂŁcut. Am programare la Bavaria peste 11 zile (e full) și luni 28 ianuarie la Service Scream (Tezparii) Bmw. Zilele trecute am fĂŁcut schimbul de ulei si filtre, am pus Bmw 5w30. Mașina o am de puțin timp, nu stiu ce ulei a avut ĂŽnainte sau când fusese schimbat. Am mai parcurs vreo 500km cu ea si i-am mĂŁsurat mereu uleiul. E la level max. Prin pierderi de putere mĂŁ refer de fapt la mici ĂŽntreruperi. Și numai intre 2-3000 ture (chiar si la mers cu viteza constantĂŁ) se ĂŽntâmplĂŁ saau când ii dau kick-down mai are momente cand nu mai trage. Daca iau gazul si accelerez, trage de rupe, ĂŽși revine. De asemenea mai are sunetul ĂŁsta ciudat la relanti: https://youtu.be/vrJ7aBZZHvg https://youtu.be/CbbagsmID8M Sunt videouri puse de mine, nu comparații.
Tot timpul face asa. Mai am alte simptome: Intrerupe intre 2-3000 ture, chiar si la viteza constanta. Mi-a dat eroare "drivetrain malfunction. full performance is not available". S-a oprit motorul, am stat 1 minut si dupa totul Ok. Daca ii dau cox, apare eroarea destul de repede. Am pus-o pe tester si a dat: verificare bujii, cablaje sau calculator motor. Si totusi zgomotul nu prea are cum sa fie din cauzele astea. Am programare la BMW peste 1 saptamana, momentan e full. De ce e "faimos" si de la ce ar putea fi? Pare ca stii mult mai multe decat mine.
Salut. Masina in cauza e un F30 328i. Are un sunet ciudat: https://www.youtube.com/watch?v=vrJ7aBZZHvg Ce credeti ca ar putea fi? Mai ales cei care cunosc motorul, sunetul si problemele lui.
Ce vorbĂŁ mare ai spus. Și apa e udĂŁ, nu?
Eram prin Polonia. Am mers in ture mici si am pus ulei cât sa ajung acasã. Bos.
PĂŁi poate chiar era presiune deficitarĂŁ având ulei ĂŽn cantitate micĂŁ. Linia de arbore? Fi puțin mai explicit cĂŁ nu cunosc in detalii tehnice.
Salut. Am un 328i f30 care a ĂŽnceput sa o ia razna de 2 zile. Prima datĂŁ am primit o eroare "Drivetrain malfunction problem. Full performance is not available". Motorul s-a oprit, am tras pe dreapta, am așteptat 1 minut, a pornit și a mers normal. In 1500km mi s-a ĂŽntâmplat de vreo 7-8 ori. Intre 2-3000 ture, la turație constantĂŁ, ĂŽntrerupe, se ĂŽngâtuie. Daca iau piciorul de pe accelerație si dau gaz, merge. Daca nu iau piciorul, dar apĂŁs mai tare accelerația, ĂŽși revine. Se mai ĂŽntâmplĂŁ sa ĂŽntrerupĂŁ când ii dau kick-down, schimba vreo 2 viteze și iar ĂŽntrerupe. Nu e mereu reproductibil. Cutia e automata. Nu pot sa merg in Sport cĂŁ ĂŽl ține mult ĂŽntre 2-3000 ture și se ĂŽngâtuie rĂŁu. Bun...in acest timp am mai primit o eroare: presiune slaba de ulei și sa completez. A fost nevoie sa pun 3 litrii sĂŁ ajungĂŁ la nivel maximum. DupĂŁ 1500km am primit iarĂŁși warning sa completez cu 1l ulei. Am pus 1l și a ajuns la level maxim. Wtf?! Senzorul de ulei prost? Nu am joja. Când aveam 200km/h si acceleram, mi-a ĂŽmpins pedala de accelerație in sus. Acum am un zgomot mic la relanti de 'taca taca'. Mâine ĂŽi schimb tot uleiul, ĂŽi bun Bmw si voi vedea dacĂŁ se mai aude. Cel pus era un Shell luat din Peco, aia am gĂŁsit. Ce credeți ca are mașina? De ce naiba ĂŽntrerupe? Zilele astea o sĂŁ pun testerul pe ea.
Salut. Detin un F30 328i, cod motor N26. De 2 zile masina are pierderi de putere si consum enorm de ulei. Am completat cu 3 litri pentru a ajunge la level max si dupa 2000 de km a mancat vreo 2l si ceva. Am citit ca ar fi problema la wastgate. A mai avut cineva problema asta? Implica costuri mari? O sa ma duc zilele asta cu masina la service pentru a sti exact, momentan ramane la stadiul de "vorba" intre noi
Salut! Detin un E90 facelift, 163 caluti (cel Efficient Dynamics). Ce suspensie sport recomandati? Masina are suspensia stock in prezent, dar as vrea ceva mai bun. Nu ma intereseaza confortul. Ca buget...nu am ceva fix. Vreau doar pareri despre ce sa pun pe masina si ce costuri voi avea (aproximativ).
Cumpar capse pirotehnice tetiere E90 LCI - sofer si pasager.
Salut! Am un E90 LCI, am eroare cu martori airbag + centura. Pusa pe tester, problema provine de la tetiera scaun sofer. Singura rezolvare e sa schimb tetiera? Daca da, trebuie detapitat scaunul pentru a face legatura cu restul sistemului? Habar n-am ce-i acolo. Daca ma poate lamuri cineva... Multumesc anticipat.
Salut! Are cineva pe 320D (2.0 N47) toba finala sport EVOE904E276? Pareri?
Cum spune si titlul, caut sa cumpar jante style 230, OEM, in 2 latimi. Ofer cash sau 4 anvelope Michelin Pilot Sport 4 225/45/17, noi, puse pe jante style 158 + diferenta.
Ok baieti, o sa dau cu banul intre Dunlop Sport Maxx RT 2 si Goodyear Eaglef1 A3. Le-am gasit pe la 360 lei pe cauciucuri.com; Recomandati un magazin/site? Exista sansa sa imi iau "teapa" privind originalitatea produsului?
