Xenzor
Everything posted by Xenzor
  1. salut, As vrea sa pot schimba ceasurile care apar atunci cand dau pe sport, in cele de pe modelele M. m-am tot jucat cu bimmercode, insa nu am reusit sa obtin ceea ce imi doresc... Am reusit sa schimb in M ramanand asa pe toate modurile de condus, dar nu imi place pentru ca pierd informatiile legate de sistemul electric, de aceea as vrea doar cand masina este in modul Sport. Orice sfat este apreciat, multumesc (poza de pe net pentru exemplu)
  2. stie cineva la ce s-ar referi cele 2 erori? din ce am scormonit pe google nu prea am gasit. mersi
  3. am revenit. am instalat insta-d, dar nu imi face conexiunea nu stiu de ce, am reusit in schimb sa fac diagnoza cu inpa exact pe module si am gasit asa: Variant: JBBF87 ------------------------------------------------------------- RESULT: 3 error in error memory ! ------------------------------------------------------------- A6DA relay FH back driver close Error counter: 1 Logistic counter: 40 Mileage 208096 km Speed 0.00 km/h battery voltage 14.15 volt Implausible signal or value Test conditions fulfilled Error present now and already stored Error would not cause a warning lamp to light up Error code: A6 DA 68 00 01 28 65 9C 00 00 01 FE ------------------------------------------------------------- A6D9 relay FH back passenger open Error counter: 1 Logistic counter: 40 Mileage 208096 km Speed 0.00 km/h battery voltage 14.15 volt Implausible signal or value Test conditions fulfilled Error present now and already stored Error would not cause a warning lamp to light up Error code: A6 D9 68 00 01 28 65 9C 00 00 01 FE ------------------------------------------------------------- A6CF sensor AUC Error counter: 1 Logistic counter: 40 Mileage 208096 km Speed 0.00 km/h battery voltage 14.09 volt Implausible signal or value Test conditions fulfilled Error present now and already stored Error would not cause a warning lamp to light up Error code: A6 CF 68 00 01 28 65 9C 00 00 01 FC ============================================================= help would be apreciated. thanks
  4. acum il downloadez. sa vad cum il configurez si etc si apoi ma duc sa ii fac diagnoza iar.
  5. Mersi pentru sfaturi, daca intru pe fiecare modul imi da o eroare de la program, nu mai stiu exact care e, mereu am folosit asta sa le dea pe toate.
  6. Am gasit si eu asta pe goagal, If you can access JBBF3 with NCSExpert then its simple since you can just: 1.) load expertmode 2.) VIN ZCS FA (F1) 3.) ZCS FA Fr. Ecu 3.) choose car model 4.) select JBBFR3, 5.)F6 to go back 6.) process ECU, 7.)SG codieren and F3 to start coding back to stock. dar mi s-a parut destul de vag si de asta am zis sa si intreb. am sa vad merg mai diseara la masina sa vad daca imi iese ceva, momentan am vazut ca imi da o eroare la windows 10 de compatibilitate cand rulez ncsexpert, desi i am bifat sa ruleze ca pentru windows xp. daca nu reusesc si ai timp zilele astea, poate ne intalnim.
  7. Salut, am si eu un 120d din 2005 si din prima zi cand a dat frigul mi-au murit geamurile pe spate si stergatorul tot spate. Am verificat sigurantele, totul ok, Dupa ceva research am inteles ca ar fi o problema la jbbf. Acum, sunt cativa care l-au adus la setarile initiale si au spus ca n au mai avut probleme dupa. Eu am cablu obd 2 si programele instalate doar ca nu stiu sa fac resetul. m-ar putea ajuta cineva? mersi. Am facut azi dimineata o diagnoza. Poza cu multe erori este cu erorile care au aparut la inceput, cealalta este cu cele care au ramas dupa ce am dat clear. Mentionez ca ma intereseaza momentan sa le rezolv pe cele de la jbbf, de la restul stiu de ele si nu e graba. mersi
