Bala
Moderators
    4
Everything posted by Bala
  1. aha. Uite aici ce zice un nene cu HB assist: Hi I've had my car a couple of weeks - and it has HBA - It works really well!! High Beam Assist is a bit more sofisticated than I had thought - so it may be hard to "test" witout going out for a spin... Main Beams are normal "Dipped" High Beams don't come on until you go over approx 30MPH They Dip again when you go under 25MPH (This is handy round towns, but not so handy round my narrow country lanes where I am often under 25MPH, but would like the main beams on!!) Things I have noticed (not done a lot of night driving yet - gets dark about 21:30 in the UK at the moment) Speed Sensitive - see above Dips when you go into an area lit with streetlights Dips when on-coming car approaches Dips when there is a car infront (must be able to "see" the rear light) In all - its very impressive - never had to override it (apart from driving slowly down narrow lanes!) So to test - I think you will have to cover the sensor and then go out for a drive over 30MPH
  2. @ins1dez - poti pune te rog o poza cu butonul pe care il apesi pentru a activa aceasta functie?
  3. Exista acest feature dar nu are legatura cu senzorul de lumina. http://www.bmw.com/com/en/newvehicles/3series/sedan/2005/allfacts/ergonomics_highbeam_assistant.html Daca ai doar senzori de lumina, nu ai high beam assist. Cel putin eu asa stiu...
  4. Le dai cu lumina in tot ce inseamna oglinzi. Este deranjant pentru cel din fata si inutil. High Beam Assist, se face in mod normal cu o camera care folosind ceva algoritmi, detecteaza o masina cand o ai in fata. Asta cu senzorul este vrajeala pentru nu este directionat intr-o parte sau in alta. In plus, timpul de reactie + corectidinea detectarii lasa mult de dorit.
  5. DRL la generatia noastra se refera doar la angeleyes. Atat. Daca pui pe auto, cu DRL sau nu, xenonul nu se aprinde ziua. Daca intri in modul de diagnoza din bord, exista intr-un meniu optiunea de a vedea ce rezultat da senzorul. Poti apoi sa-l acoperi sau nu si sa vezi daca se schimba. Nu stiu pe dinafara meniul sa iti spun care dintre ele este.
  6. Nu, nu este asa senzorul. Nu se taie nimic ci este progresiv.
  7. Senzorul trebuia schimbat. De aceea ai estimarea gresita. La E60, senzorul nu este ON/OFF ci ii creste rezistenta progresiv. Cat despre estimare, este cam degeaba. Cand am cumprat-o imi arata dupa vreo 4-5k km ca mai pot merge 20 si 25k km. Astazi, la 65k km, imi arata >20k km fara sa schimb nimic...
  8. Am anvelope cu protectie pt jante Din ce tin eu minte este vorba de pachet oglinzi sau asa ceva. Nu tine de scaune.
  9. Poate faci si un [DIY] sa vedem si noi ce si cum. Desi nu cred ca as investi bani si timp atat de mult pt acest feature. As face mai tarziu un upgrade CCC la CIC (cred ca tu ai deja CIC) sau as pune modul Tv si CD changer
  10. Intr-un singur topic ai incalcat 3 reguli: -lipsa pret -lipsa locatie la profil -titlu aiurea - modificat acum de mine Citeste regulamentul!
  11. Cred ca inteleg unde bati insa te inseli. Din punct de vedere al traficului, orice activitate aici, pe acest topic sau pe altul, postat sau un simplu citit, tot genereaza trafic. Acest topic, nu are nimic special. Din motive de flame, offtopic si alte cele, cel putin temporar acest topic se inchide
  12. Offtopic: avem multi ingineri in tara care sunt mai buni decat cei nemti. Si asta o spun dupa ce am lucrat/lucrez in 2 multinationale.
  13. ai inteles gresit! la BMW,cand este disponibil, iti pot adauga un power box si iti pastrezi garantia. La 520d-ul meu de 177cp, puteam sa-l duc in 209cp sau 210cp si pastram garantia. Jucaria, cu montat cu tot, costa aprox 600 eur. La dealer. deci la tine nu are cum sa fie mii. Intreaba si poate o fi deja disponibil pt motorul tau. La mine am aflat cam dupa un an de ea si am avut cam prima serie de 520d 177cp din Ro.
  14. cu sau fara lupe? Xenonul fara lupe deranjeaza pe ceilalti participanti la trafic!
  15. 7. Initiatorul topicului poate da un singur UP la 7 zile de la ultima sa postare. Nu se admit UP-uri date mai repede de 7 zile de la ultima postare sau UP-uri date de catre alta persoana decat initiatorul topicului. Exceptia UP-ul la 7 zile va fi permis doar atunci cand initiatorul doreste sa scada 10% din pret. Daca se da UP inainte de cele 7 zile topicul va fi inchis 10 zile. Sunt considerate UP-uri si actualizarile de stocuri, noi produse, sau postarea de poze in intervalul celor 7 zile. Din acest motiv, topicurile trebuie sa contina cat mai multe informatii inca de la deschiderea lor.
  16. incearca sa arunci un ochi pe regulemantul de la MP. Mai ales pe punctul 7!
  17. vezi aici Mai sunt si altele. Foloseste functia search cu incredere.
  18. Topic inchis pentru nerespectarea pct. 9 din regulament
  19. Topic inchis pentru nerespectarea pct. 9 din regulament
  20. Topic inchis pentru nerespectarea pct. 9 din regulament
  21. Topic inchis pentru nerespectarea pct. 9 din regulament
  22. pentru ca era offtopic ???!!! Pentru ca era un citat modificat si atat ?!?? Hai sa repet: sunteti offtopic!
  23. domnilor, sunteti complet offtopic!
