egrimisu
Everything posted by egrimisu
  1. Buna ziua, As dori sa activez Lunch Control pe 420xd-ul meu. Sport+ l-am activat deja. Am folosit Bimmercode + vGate iCar2 dar nu gasesc modulul EGS pentru a activa LC (EGS 3000 LC> aktiv). Voi cu ce codati? Am si obd-ul carly dar aplicatia costa 60euro pentru un an, o gluma adica.
  2. Mi-am luat un Carly pentru diagnoza. Nu stiu prea multe doar ca a costat destul de mult mufa iar aplicatia pe iOS costa cam 60euro pe an fiind un fel de abonament. Mi-am scanat masina un 420xd 190ch 2016 iar erorile gasite sunt mai jos. Nu sunt in masura sa le interpretez deci as dori opina voastra. E de rau gagiilor? --------------------------------------------------------- Engine / Motor Fault Code: 284E00 Fault Explanation:Lambda probe according Kat, Nernst voltage signal: Interruption --------------------------------------------------------- Air conditioning / Klimaanlage Fault Code: 8011F9 Fault Explanation:PTC module: reducing heat output for Power Management --------------------------------------------------------- Integrated Chassis Management Quer/Längsdynamik Fault Code: 480134 Fault Explanation:SBS function - direction unsure vx greater than 2 m / s --------------------------------------------------------- ICAM - Rundumsicht + Rßckfahrkamera als Standalone System Fault Code: 800BAA Fault Explanation::Composite Output: open or not connected / Error in composite output, not connnected --------------------------------------------------------- Central Gateway / zentrales Gateway Fault Code: CD0487 Fault Explanation::Synchronization process failed, CC was not in sync with the date of repeal of error Memory Lock / FLEXRAY StartUpFailed --------------------------------------------------------- Anti-Blockier-und Stability Control 5 auto. E34 / 16 Fault Code: 801A55 Fault Explanation::Disconnection of loads due to overtemperature / Car alarm: Alarm - details in the alarm memory --------------------------------------------------------- Advanced Telematic Module Fault Code: 03178A Fault Explanation::SIF: General Mobile network error ---------------------------------------------------------
  3. Detalii masina: 420xd 190cp 2016 cutie 8+1 fara clapete, deci fara Sport+. Inainte de a intra in intersectie las piciorul de pe pedala de acceleratie iar masina incetineste dar cand schimba vitezele din treapta superioara in cea inferioara simt frana de motor destul de accentuat. Daca cutia este comutata pe modul manual si eu schimb vitezele nu simt acest efect sau probabil la 10-20% intensitate. Mi-am luat un Carly ca te diagnostichez troaca, am gasit niste fault-uri minore care nu sunt legate de motoro doar una la sonda lambda dar banuiesc ca nu e legat. Mentionez ca am inlocuit acum 5000km sonda EGR fiind inlocutita gratuit la o reprezentanta in Franta, sondele de pe acest model au venit cu fiabilitate scazuta din fabrica. Masina are acu 35000km, am cumparat-o la 23000 si nu simteam acest efect. A mai patit cineva?
