neo_andersson
    79
Everything posted by neo_andersson
  1. PuMA measure SCR System - CC message: Ad-Blue system fault V1-R2-RO 63310358-02 - 20/04/17 Complaint: The customer complains about CC message or MIL (Malfunction Indicator Light) Ad-Blue system fault. The following faults may be entered in the fault memory: SCR03 8052D0 -- Active tank, pre-supply pump delivers air (PUMP_AIR) 2C3000 -- SCR system, Diagnosis feedback: Transmission status system fault OBD from SCR control unit to DDE SCR03 8052CD -- Active tank, communication fault Cause Application SCR control unit Measure In the event of a customer complaint, run diagnosis with ISTA/Next and work through the possible faults with the test module, if necessary. Then program and encode the vehicle with ISTA/Next 4.04.1x or ISTA/P 3.61.0 to integration level S15A-17-03-502 or a more recent version. Then clear the fault code memory and reassess the vehicle. A parts replacement does not provide a remedy. Note on invoicing: Processing and reimbursement must be conducted according to current warranty conditions.
  2. sincer imi plac mai mult farurile led de pe pre-LCI.
  3. Da, eram in drum spre MHS, am fost sa schimb lichidul de frana si sa fac ITP-ul ca expira saptamana viitoare.
  4. BMW tocmai ce a amanat livrarile pentru 6WB pentru trimestrul 3 2017, asa ca mai am de asteptat.
  5. Urmatorul retrofit, LCI taillights. :frantics:
  6. toate informatiile astea se gasesc pe forum cu un simplu search. Am facut acest topic special pentru coduri si nimic mai mult, am specificat din primul post, nu am timp sa citesc zeci de posturi aiurea ca sa le gasesc pe alea care intradevar sunt cereri de coduri. imi aloc din timpul meu, si asa putin pentru a ajuta colegii de forum si nu cer in schimb decat putina intelegere si respectarea unor reguli minime. Topicul asta a mai fost "curatat" o data si din ce vad NIMENI nu citeste primul post cu acele reguli.
  7. Am avut si eu o rugaminte cu acest thread, doar cereri de coduri, fara alte povesti suplimentare. Vad ca nu se poate, asa ca ma las pagubas, bine cu forta nu se poate ca sa nu amintesc vorbele cu "facerea de bine....." Se poate inchide.
  8. O77LFB36BGPE4ABIAD7Q Citeste te rog regula nr.1 Citeste te rog regula nr.1
  9. sa o stapanesti sanatos, upgrade-ul la navi professional este destul de ieftin daca te bate un gand.
  10. Va rog postati pe acest topic doar cererile de cod, ATAT, nimic altceva, fara impresii, fara cereri de numere de telefon sau altele, nu ofer nici un fel de servicii pe forum. Deci, va rog, doar posturi scurte cu ultimele 7 caractere din VIN si atat, cred ca nu cer prea mult, nu sunt necesare nici macar multumirile ulterioare sau feedback de genul "a mers codul".
  11. Sunt functii ale Park Assist, daca masina are PMA Gen.2 se poate coda desi ele vin oricum active din fabrica. Se poate la orice Nivi Gen.2 sau 3 indiferent pe ce Fxx se monteaza.
