bmwnew730d
    bmw
Recent Profile Visitors
bmwnew730d's Achievements
  • Conversation Starter Rare
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
  1. Salut Probleme Bmw f01 740d 306 cp din 2009 mașina nu trage... Lipsa putere... Cod eroare.. CD945D Message CAS ZV ( Central locking system and lid status ) Signal invalid 25F900 Charge-air temperature sensor, signal: Open or short circuit to positive 243A00 Preheating control unit, diagnosis feedback: No voltage, terminal 30 at preheating control unit 244C00 Charge-air pressure control, control deviation: charge-air pressure too low/positive control deviation 25FA00 Charge air temperature sensor signal - short circuit to ground ... temperatura la ulei și apa în mers nu depășește 60 grade Va multumesc
  2. Salut!Am un Bmw Seria 1 118d 143cp din 2007 si am o problema,sa rupt batul(tija) de la plutitor și a cĂŁzut ĂŽn vas.Se poate ĂŽntâmpla ceva ?Multumesc anticipat.
  3. Buna seara, Detin un bmw seria 1 din 2007(118D).Masina porneste dar se opreste. Am pus diagnoza pe masina si mi-a dat urmatoarele erori: -Â E72E Message (status of Automatic Start/Stop function, 0x308) faulty, receiver IHKA, transmitter DME-DDE, present. - E1D2 NO MESSAGE FROM DME , RECIVER CCC / rad2 /rad1 , transmitter dme - dde - A562 Message (status of Automatic Start/Stop function, 0x308) faulty, receiver KOMBI, transmitter DME-DDE A mai intampinat cineva aceasta problema ? Multumesc
  4. bmwnew730d
    Bmw 118d
    Buna ziua, Recent mi-am achizitionat un bmw seria 1 din 2007(118D).Masina porneste dar se opreste. Am pus diagnoza pe masina si mi-a dat urmatoarele erori: -Â E72E Message (status of Automatic Start/Stop function, 0x308) faulty, receiver IHKA, transmitter DME-DDE, present. - E1D2 NO MESSAGE FROM DME , RECIVER CCC / rad2 /rad1 , transmitter dme - dde - A562 Message (status of Automatic Start/Stop function, 0x308) faulty, receiver KOMBI, transmitter DME-DDE A mai intampinat cineva aceasta problema ? Multumesc,
  5. Va salut pe toti , Detin un seria 7 730d f01 din anul 2010. Eram la semafor toate bune si frumoase... Nici o problema ... se face verde vreau sa plec masina se tura greu .... fara vlaga fara forta. Erori am atasat poze a mai patit cineva problema asta....
  6. Salut, masina pornita si in P. cum las geamul jos turatia motorului scade.
  7. Va salut, Am o problema ciudata de cateva zile (Bmw f01 730d din 2010)...cand deschid geamurile oscileaza acul de la turatie. Ce poate fi. Va multumesc
  8. Salutare!Am un bmw 730 F01 din 2010 cand pun picioru sa franez scade turatia 500 600 rpm dar isi revine mai nou cand cuplez cutia D sau R se opreste motorul la relantiu tremura cate odata. Aveti idee ce poate fi?
  9. Salut pe toata lumea ---- cod eroare E0940A No message (dimming, 0x202), receiver GWS, transmitter FRM . Daca a mai intilnit cineva problema as fi multumit cu ceva pareri.
  10. Salut Sunt detinator de putin timp unui BMW 730D f01 2010. Problema mea este cam asa : 1- Rail-pressure sensor, plausibility: rail-pressure signal gradient too high 26F300 ( Cred ca de aici oscileaza turatia ) cand o pornesc cate odata sau la semafor in drive cu piciorul pe frana. 2- Brake-light switch: short circuit or open circuit or not connected 930710 V-a multumesc anticipat.
  11. Salut Sunt detinator de putin timp unui BMW 730D f01 2010. Problema mea este cam asa : 1- Rail-pressure sensor, plausibility: rail-pressure signal gradient too high 26F300 ( Cred ca de aici oscileaza turatia ) cand o pornesc cate odata sau la semafor in drive cu piciorul pe frana. 2- Brake-light switch: short circuit or open circuit or not connected 930710 V-a multumesc anticipat.
