errori tester , cum le interpretez
ak_47
MASINA E65 735 an 2003 luna 11
I N F O R M A T I O N M E M O R Y ---------------------------------------
Date: 11.05.2011 02:40:05 ECU: CAS JobStatus: OKAY Variant: CAS -------------------------------------------------------------
RESULT: 1 error in error memory ! -------------------------------------------------------------
9906 error transponder communication
Error counter: 2
1. Umweltsatz Mileage 223424 km
2. Umweltsatz Mileage 223424 km
Implausible signal or value Test conditions fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up
Error code: 99 06 28 02 6D 18 6D 18 =============================================================
NU MERGE INCHIDEREA CENTRALIZATA DIN BUTON, DOAR DESCHIDEREA
E R R O R M E M O R Y ---------------------------------------
Date: 11.05.2011 02:14:35 ECU: ARS_E65 JobStatus: OKAY Variant: ARS_E65 -------------------------------------------------------------
RESULT: 2 error in error memory ! -------------------------------------------------------------
5D52 Supply switch setting sensor
Error counter: 12
Mileage 0 km
No signal or value Test conditions fulfilled Error present now and already stored Error would cause a warning lamp to light up
Error code: 5D 52 E4 0C 00 00 -------------------------------------------------------------
D1E4 CAN angle of steering wheel
Error counter: 1
Mileage 0 km
Implausible signal or value Test conditions fulfilled Error present now and already stored Error would cause a warning lamp to light up
Error code: D1 E4 E8 01 00 00 00 00 =============================================================
NU MERGE DINAMIC DRIVE
Date: 11.05.2011 01:57:03 ECU: ME9E65_6 JobStatus: OKAY Variant: ME9E65_6 -------------------------------------------------------------
27A0 CDKELS - Control E-box fan
Error counter: 1 Logistic counter: 40
Mileage 223432 km Engine speed (nmot) 440.00 /min Engine temperature (tmot) 70.50 degrees C Supply voltage (ub) 11.49 V Vehicle speed (vfzg_u) 0.00 km/h
No signal or value Test conditions fulfilled Error present now and already stored Error would not cause a warning lamp to light up diagnose active Cyc. flag actived
Error code: 27 A0 64 05 00 00 01 28 6D 19 0B 9E 7A 00 FF FF FF FF FF FF FF FF FF FF FF FF =============================================================
Edited by ak_47
  • 4 months later...
E-box fan schimbat http://farm5.static...._9c9f67cd5f.jpg
http://farm5.static...._6a005ebb8f.jpg
Culmea e ca pe tester dadea eroare , daca-l conectam la sursa de curent , mergea.
Costa aprox 400 ron , doar pe original bosch.
Cum a dedus ecu ca el nu functioneaza corect ?
Pai simplu : Ecu il testeaza la pornire , si il alimenteaza o secunda il invarte tare, dupa care asteapta sa primesca curent de la el , folosindu-l pe post de generator.
Daca el nu mai invarte in parametrii sau se mai blocheaza, stocheaza eroare.
Acest ventilator in forma de turbina, trage aer de pe tubulatura de la filtru de polen , si il baga la calculatoare.
Asa ca pastrati filtrele de polen curate good.gif.
Inainte sa cumpar unul nou , l-am curatat bine cu spray de contacte pe cel vechi , inclusiv in interior, am bagat prin gaurelele alea.
Ce e drept , se invartea mult mai bine cand a fost curatat , insa degeaba, tot stoca erori pe tester, tot nu era in parametrii
Edited by ak_47
