resetare placute E60
aditzzaa
am un prieten cu un E60 care imi zice ca a schimbat placutele dar nu a resetat indicatorul si nu ar putea sa depaseasca 100km/h de atunci. sa fie oare o limitare electronica de precautie ca sa nu mergi tare cu placutele uzate?
si daca poate cineva sa-mi indice cum se reseteaza acel indicator?
1. nu are legatura una cu alta
2. da un search ca gasesti in cateva locuri diferite cum se face resetarea. Inainte de a face resetarea sa fi schimbat si senzorii de la placute. Altfel nu are sens resetarea
Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (I found this step was critical, otherwise I couldn't get to the "Service" menu).
Now you are ready to go through the reset steps as follows:
1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car.
2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear.
7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above).
Hints & Tips
Before actually resetting anything, go through steps 1, 2 and 6 above until you are familiar (and sure) what you want to reset. Practice this a few times and note down in what order the icons appear after the initial "Service" icon appears.
If you do happen to hold the button down too long against an item you don't want to reset and the "RESET?" appears, just leave the button alone for 10 seconds or so and it will not let you reset the item. (Alternatively just switch the ignition off and start again).
Sometimes if you have not released and pressed the button again quickly enough, when you hold it down again the German technical writing will appear after about 15 - 20 seconds instead of the Service item icon you were expecting. (If this happens just switch off the ignition and start again).
Once you are sure what item you want to reset and are confident of the sequence, then give it a go. If you do hesitate between releasing and pressing the button at any time, you will have to go back to the beginning and start again as "he who hesitates is lost".
Edited by IulianC
Ăn primul rând, cu aprindere prin pornit, seta contorul de cĂŁlĂŁtorie ĂŽnapoi la zero contorul de parcurs, ĂŽmpingându-l o datĂŁ. Comuta apoi contactul ĂŽnapoi din nou. (Am gasit acest pas a fost critic, altfel nu am putut ajunge la "Service" din meniu).
Acum sunteĂži gata sĂŁ treacĂŁ prin paÂşii de resetare, dupĂŁ cum urmeazĂŁ:
1. Pornirea aprindere pe (astfel Încât bateria, Petrol si parcare luminile de frânã sunt afiºate), ºi cheia este gata pentru a porni motorul - dar nu Începe de fapt masina.
2. ApãsaÞi butonul de reset kilometrajul pentru Între 5 ºi 10 secunde, pânã când un triunghi galben cu un semn de exclamare În centrul apare În fereastra de sus dintre ceasurile (În cazul În care temperatura de afara / ora sau data În mod normal apare) - aceasta este "Serviciul" icon .
3. Lansat pe scurt butonul de contorul de parcurs ºi apãsaÞi din nou imediat, care aduce o imagine a simbolului lichidului de frânã (la fel ca cea pe care i-drive prezinta atunci cand te uiti la meniul Service).
4. Dacã doriÞi sã resetaÞi intervalul de lichidul de frana pentru un alt 2 ani pãstreazã apoi apãsat butonul contorul de parcurs pânã la cuvântul "RESET?" apare În partea de jos a ferestrei inferioare.
5. Lansat pe scurt butonul ºi ÎmpingeÞi-l din nou ºi ÞineÞi apãsat pentru aproximativ 5 - 10 secunde pânã la noua datã apare În fereastra de jos. AveÞi posibilitatea sã comutaÞi apoi aprindere off ºi noua data lichidului de frânã va apãrea În meniul de serviciu de pe ecran i-drive data viitoare când veÞi porni.
6. Dacã doriÞi sã resetaÞi Oil, microfiltru sau indicatori de frânã tampon, atunci va trebui sã urmeze aceeaºi ordine ca paºii 1 ºi 2 de mai sus, dar când ajungi la pasul 3 ºi pictograma lichidul de frana pare, doar de presã ºi apãsaÞi din nou butonul ºi elementul de servicii va apãrea urmãtoarea.
7. PuteÞi continua eliberarea ºi apãsarea butonului pânã când elementul de servicii necesare pictograma apare pentru cea pe care doriÞi sã resetaÞi. De Îndatã ce-l deÞine, apoi În buton pânã la cuvântul "RESET?" apare din nou ca la pasul 4 de mai sus. Dupã cuvântul "RESET?" a apãrut, aveÞi nevoie pentru a elibera scurt butonul ºi ÞineÞi-l din nou timp de aproximativ 5 - 10 secunde pana cand se Înlocuieºte cu cifra noua intervalului de service (pe pasul 5 de mai sus).
Sfaturi utile
Inainte de resetare de fapt nimic, trece prin etapele 1, 2 ºi 6 de mai sus pânã când sunt familiare (ºi sigur) ceea ce doriÞi sã resetaÞi. Practica aceasta de cateva ori ºi notaÞi În ce ordine apar pictogramele dupã iniÞialã "Serviciul" icoana apare.
Dacã se Întâmplã sã ÞineÞi butonul apãsat prea mult timp Împotriva un element pe care nu doriÞi sã resetaÞi ºi "RESET?" Apare, pur ºi simplu lãsaÞi singur buton timp de 10 secunde sau cam asa ceva si nu te va lasa sa reseta element. (Sau doar comutatorul de aprindere off ºi Începe din nou).
Uneori, dacĂŁ nu aĂži eliberat Âşi apĂŁsat butonul din nou destul de repede, atunci când vĂŁ ĂžineĂži-l jos din nou de scris german tehnice va apĂŁrea dupĂŁ aproximativ 15 - 20 secunde ĂŽn loc de pictograma Serviciului elementul pe care au fost aÂşteptam. (Ăn cazul ĂŽn care acest lucru se intampla doar de pe comutator de aprindere Âşi ĂŽncepe din nou).
Odatã ce sunteÞi sigur ce elementul pe care doriÞi sã resetaÞi ºi sunt siguri de secventa, atunci da un du-te. Dacã ezitaÞi Între eliberarea ºi apãsând butonul În orice moment, va trebui sã se Întoarcã la Început ºi Încep din nou, ca "cel care ezitã este pierdut".
VARIANTA IN ROMANA :p
