Un vis implinit
C_o_s_m_i_n
Probabil amplificatorul audio are un firmware prea vechi pentru CIC si nu comunica.
Update-ul de soft se face doar pe fibra optica. Inca n-am gasit unde... ca aici n-are nimeni scule.
Sau la reprezentanta, dar aia fac la toata masina si nu stii daca crapa ceva.
Poate te ajuta:
http://www.e90post.com/forums/showthread.php?t=1083162
Yes, you'll want to get every module completely upgraded to it'll work properly with the retrofit. The software on the TCU/MULF (which controls the bluetooth functions) could be incompatible with the CIC and require update, could be issues with other module to module communications, etc. because they don't understand the commands from the CIC.
Ideally, what you'd need to do is this:
1) Reinstall the CCC into the vehicle
2) Have the entire vehicle completely updated with ISTA/P / Autologic / WinKFP (only need to reinstall the CCC if you are using ISTA/P)
3) Then proceed with the retrofit of the CIC into the vehicle
Also, if you're having stuff like the Amp and TCU, etc reprogrammed your coder it going to want an OPS or ICOM A+B setup, with a stable power supply (*NOT* a battery charger) and the appropriate software. If they just have a D+KCAN cable and are trying to update modules that are supposed to be updated via the MOST bus, you're just asking for trouble.
Cu NCS Expert, pe profilul Expertenmodus trebuie sa adaugi in VO optiunea #0909 + $6VA si sa stergi build-date-ul tau dupa care codezi cu FA_WRITE CAS si FRM.
Dupa asta, tot cu Expertenmodus (sau cu Revtor daca altfel nu te lasa) mergi si codezi CIC cu un fisier FSW_PSW.man gol: Process ECU -> CIC -> Change Job -> SG_CODIEREN -> Execute Job.
Acum ar trebui sa functioneze si sa poti coda ce optiuni vrei pe CIC.
PS: Legat de update, daca vrei sa mai functioneze vreodata CIC-ul, nu lasa pe nimeni sa incerce un update cu K+Dcan sau altceva inafara de ICOM/MOST pentru ca nu o sa functioneze.
Edited by Kenbobo
#0909 am adaugat deja. Dar $6VA nu. <_<
Oricum, CIC-ul e instalat si codat. N-am avut probleme cu el.
Eroarea apare la codarea default a MAMP (amplificatorul).
Multumesc Bogdan. Lasa ca te hartuiesc la telefon dupa ce ajung acasa. :rolleyes:
PS: Da, update-ul categoric cu ICOM B, pe fibra, de-asta am cautat de nebun.
Vedem daca mai e necesar dupa ce fac ce ai descris mai sus.
Edited by C_o_s_m_i_n
Dupa codarea cu succes a CIC-ului pe ExpertMode(Expertenmodus) cu fisier fsw_psw.man gol, ar trebui sa se restarteze CIC-ul si sa functioneze sunetul instant.
Edited by Kenbobo
Nu stiu cine e. E prietenul unui prieten. Daca ajung, si mai am vlaga dupa operatiune, iti dau un semn.
In seara asta, 4 ore am incercat tot ce era omeneste posibil, cu Bogdan. Nu vrea nici sa-l tai. Ba mai mult, nu mai apare nici USB-ul in meniu.
Mi-a mancat zilele CIC-ul asta. :bashwall:
Chiar ma intreb daca-l mai tin sau il vand si revin la CCC care din multe puncte de vedere e inca superior.
Poate se rezolva dupa update-ul la amplificator. [partea cu sunetul]
Legat de USB, trebuie sa codezi pe CIC:
CDMM_USB
aktiv
CDMM_USB_AUDIO_SINGLE
aktiv
USB_AVAILABLE
aktiv
Iar acestea doar daca vrei:
CDMM_USB_AUDIO_AZ_SEARCH
aktiv
CDMM_USB_COMPOSER_IPOD
enabled
CDMM_USB_COMPOSER_MTP
enabled
CDMM_USB_COVER_ART
aktiv
Edited by Kenbobo
si eu am avut mari probleme cu Logic 7, am verificat peste tot sa fie ringul de most inchis si lumina circula intradevar cum trebuie pe ring. De abia dupa ce m-am conectat cu ICOM-ul si nu putea sa "blocheze" lumina am luat la rand fiecare conexiune de most si am descoperit ca la priza de distributie din portbagaj, cablul care venea de la head unit nu era bagat complet in conector. cred ca in jur de 1-2 mm lipseau maxim pana sa faca acel click conectorul. Lumina venea pe most dar nu suficienta cat sa inchida corespunzator ringul. Verifica sa nu ai aceeasi problema.
In urma unor cercetari pe forumurile straine, am zis sa incerc si inversarea fibrelor in mufa de la CIC. Mai rau, a si aparut eroarea de SOS. Deci clar nu am o problema in inelul optic.
Cel mai probabil tot update-ul e solutia.
De ce? Daca, codezi cu fisier FSW_PSW.man gol NCS-ul va rescrie modulul doar cu optiunile care apar in VO.
exact asta e greseala. Profilul FSW_PSW nu tine cont de VO.
Codarea cu un fisier gol reseteaza codarile la "default values" nicidecum nu le seteaza functie de VO.
Codarea functie de VO se face doar in expert mode. Uita-te la setarile profilului si ai sa intelegi.
S-a rezolvat si cu sunetul. Update-ul era cheia.
Insa acum ma lovesc de alta problema. Gong-ul, PDC-ul si vocea de la Navi suna foarte tare. Si cand spun TARE, nici nu te poti intelege in masina de ele. Cu toate ca le-am setat pe minim din meniul CIC-ului.
Daca mai pun si neajunsul ca ventilatia nu mai stie sa sufle simultan la parbriz, corp si picioare, balanta inclina foarte mult spre revenirea la CCC.
Sunt niste neajunsuri care pentru mine conteaza foarte mult. Prea putin ma intereseaza ca-i HD, daca pierd functiile astea.
E trist ca dupa o saptamana de chin, cheltuieli fara numar si nopti nedormite, ajung de unde am pornit.
