ERROR DME/DDE 4a63
Andrei_fitness
Salut! Am aceeasi eroare 4a63 dupa ce am deconectat bateria vreo 2 ore. Iar dupa ce am pus la loc nu mai porneste masina deloc. Da o gramada de erori in bord. Cel cu testerul a zis ca s ar fi blocat probabil pompa dar nu stie sigur. Aici vad altceva dar eu am un e87 2.0disel si nu aparea nimic cu DME/DDE acolo pe calculator. A folosit un Bosch ..pentru testare
Trebuie sa mergi la cineva care are INPA ....se rezolva in cateva minute....
1- Launch inpa
2- Select the engine
3- Choose the model of the engine
4- Select option: activate (usually F5 but check in your inpa)
5- Select option: EWS
6- Select option: reset ----> in progress ----> click ok
7- Bak to the main menu, ie, back, back, back, and close the INPA
8- Open the inpa and check the errors. That errors should have gone by now.
9- Turn the ignition off, remove the obd connector and start your car.
