reset inspection
Sergiu
la ce?de cand(anul)
Incearca asta:BMW Oil Service reset for 2001 ~ current
No need for reset tool for 2001+ model by: Moko
BMW insp. reset
- Iginition OFF (POS 0)
- Press and Hold the trip odometer button while turning key to position 1 (ACCESSORY)
- Keep the button depressed (about 5 secs.) until you see "Oil Service" or "Inspection" with "Reset" or "Re" in the display
- *Note: On vehicles with "High" cluster, you will also see the amount of fuel (in litres) remaining until next service
- Press the button again and hold for approx. 5 secs. until "Reset" or "Re" flashes
- While the display is flashing, briefly press the button again to reset the Service Interval. After the display has shown the new interval you should see "END SIA" for about 2 secs.
Note that if the "Reset" or "Re" does not flash, then you have not met the minimum consumption level and cannot reset.
Edited by nik_romania
la ce?de cand(anul)
156195[/snapback]
am un bmw din 99 si de cand l-am cumparat imi aparea cand pormeam motorul "inspection 350km" pana cand a ajuns la 0 si acum a luat-o invers adik a ajuns la "inspection 50"
Nu merge ce mi-ai spus tu acolo(am incercat)
Edited by Sergiu
deci fiif atentPin Terminal # Terminal Description
1 TD TD Signal
2 - Not occupied
3 - Not occupied
4 - Not occupied
5 - Not occupied
6 - Not occupied
7 SI Service Interval Reset
8 - Not occupied
9 - Not occupied
10 - Not occupied
11 - Not occupied
12 61 (D+) Generator Charge Indicator
13 - Not occupied
14 30 Voltage; Hot At All Times
15 RXD Diagnostic Data Link
16 15S Voltage Ignition Switch in Run
17 - Not occupied
18 PGSP Programming Line
19 31 Ground
20 TXD Diagnostic Data Link
Pinul 7 e pt reset.daca pui un fir intre pinul 7 si 19 aprox 12 sec resetezi uleiul dar daca tii cam 24 sec resetezi si uleiul si inspection.Pinul 7 e cel din dreptul crestaturii.Cel mai sigur ca sa nu faci vreo istorie faci asa:
1-iei un fir de 30cm cojit la capete
2-pui contactul
3-pui firul intre pinul 7 si surubul de la amortizor(ala e ground adica -)
4-tii firele asa 12 sau 24 sec(depinde ce vrei sa resetezi)
5-iei firul si pui capacul la loc
6-te duci in masina si vezi ca s-au resetat
Alte intrebari?
156196[/snapback]
:blink:
De cand l-ai luat i-ai facut vreo revizie?
Nu de alta, dar cam asta e ideea: cand se apropie de "inspection 0 km" ar cam trebui sa ii mai schimbi una, alta. Nu se face concurs care ajunge la numarul cel mai mare de km fara nici o revizie.
:blink:
156211[/snapback]
Eu cand l-am cumparat iu-am schimbat tot ce se schimba la o revizie (ulei , filtre, placute etc )si am facut si mecanica ce era necesar
1 TD TD Signal
2 - Not occupied
3 - Not occupied
4 - Not occupied
5 - Not occupied
6 - Not occupied
8 - Not occupied
9 - Not occupied
10 - Not occupied
11 - Not occupied
13 - Not occupied
17 - Not occupied
19 31 Ground
2-pui contactul
Alte intrebari?
156198[/snapback]
As mai avea o intrebare: unde gasesc pinii astia?(esti sigur ca va merge si nu se strica ceva?)Multumesc!
1 TD TD Signal
2 - Not occupied
3 - Not occupied
4 - Not occupied
5 - Not occupied
6 - Not occupied
8 - Not occupied
9 - Not occupied
10 - Not occupied
11 - Not occupied
13 - Not occupied
17 - Not occupied
19 31 Ground
2-pui contactul
Alte intrebari?
156198[/snapback]
hmmmmmmmmmmmmmmmmmmmmmmmmmmm...asta era pt e36 , e34 .... daca nu ma insel el are mufa OBD 2
