X6M si M5 ... diesel ?
ngl
At first glance, this footage from BMW seems like just another promotional video, but then you rub your eyes and lean in closer to the screen. Elements of the front and rear of this X6 are blurred out; BMW must be drumming up anticipation for a facelift. But why, then, is the badge also distorted?
Within the blur, notice the familiar splash of color: It’s an M. But notice the extra script beyond where the M would be, and the lack of noise as the X6 charges up a mountain road. Based on what we see here and what we’ve heard murmured around BMW, we think that badge says X6 M50d. That stands not for a 5.0-liter engine, but for a 3.0-liter, inline-six oil-burner. With two turbos, the engine will likely make more than 370 hp and more than 500 lb-ft of torque. It will be the most powerful six-cylinder diesel on the light-duty market by far—Ram’s HD pickups use a 6.7-liter diesel inline-six to produce 350 hp and 800 lb-ft—and rumor has it that the turbos will operate in three different stages, making power when you want it, sipping fuel when you don’t, and balancing the two when you’re feeling greedy—or is that indecisive?
The diesel will be backed by a ZF eight-speed automatic and standard all-wheel drive. This powertrain also will find its way into an X5 M50d and—brace yourself—even an M5 50d. All three will be visually differentiated not only from their lesser diesel siblings, but their gas-powered M counterparts as well.
Click pentru articolul intreg
Oare o sa apara si un M3 diesel curand ? :rolleyes:
si tu zici ca gallardo ala e 4x4 ? foarte tare :LMAO:
ps:gallardo are si varianta cu tractiune spate, spre deosebire de gtr, da si tu un search si cauta un gtr sa faca asa ceva :goodjob:
tie vad ca iti place sa o dai in contre aiurea
singurul gallardo cu tractiune spate din cate stiu eu e Valentino Balboni.restul au fost toate 4x4
