Unde se afla tabloul de sigurante la un E38
La e46 sigurantele se afla in torpedou in partea de sus...se desface o clema si coboara un compartiment.
La e28 se afla la motor in partea dreapta cum te uiti...
La e38... banuiesc ca in unul din locurile astea doua. La alte genuri de masini am vazut ca mai sunt si in partea stanga sub volan... intre usa si volan mai exact, se trage de o clapeta...
:blink:
Sper sa te ajute:
http://www.nmia.com/~dgnrg/page_22a.htm
There are 2 locations for the fuse boxes, the front which is in the rear right hand side of the engine compartment (in what is called the E-Box), and the rear which is in the right side of the luggage compartment (behind the trim, and above the battery area).
i just bought a 89er 735 and found the cig lighters do not work (no
currency lying on (at?) them). Before asking the seller, i intended to
check the fuses. the manual, as you will know, doesn't say anythig about
the fuses, and at the fuse box near the engine there is a list assigning
function units to fuse numbers. but:
1. in that fuse box i just find some boxes that look more like relais
than fuses. is there some trick to get the fuses discovered from a place
that is not very obvious?
2. same is for the box that resides under the backseat. I see some
(rather eight) fuses, but they are
    a) too few
    :blink: unnumbered
^^ Aici din pacate, nu exista un raspuns.
  • 8 years later...
