Sezonul 2012 - Formula 1
jon doe
Cine va fi campionul mondial al Formulei 1 in anul 2012 ?
96 members have voted
Red Bull is under investigation by the FIA this morning after technical delegate Jo Bauer reported that he found an engine mapping irregularity.
Rivals confirm that the matter clearly relates to off throttle blowing of the diffuser, which is not permitted this year.
A technical report from Bauer said: “Having examined the engine base torque map of car numbers 01 and 02 it became apparent that the maximum torque output of both engines is significantly less in the mid rpm range than previously seen for these engines at other events.
“In my opinion this is therefore in breach of Article 5.5.3 of the 2012 F1 Technical Regulations as the engines are able to deliver more torque at a given engine speed in the mid rpm range.
“Furthermore this new torque map will artificially alter the aerodynamic characteristics of both cars which is also in contravention on TD 036-11.”
The stewards are now considering the matter, who have the power to cancel the qualifying times of both drivers.
http://adamcooperf1.com/2012/07/22/red-bull-engine-mapping-under-investigation-by-fia/
Guest Rosoaga
Hamilton=Spectacol !!el e sarea si piperul in F1 ,pacat de ghinionul care tot il bantuie.
Alonso a intrat de frica . Hamilton il facea sa rupa masina :))
Desi per total a facut o cursa rezonabila la Hockenheim, Scumacher tot nu reuseste sa fie rapid. A plecat de pe locul 3, a terminat pe 7. Speram macar sa iasa pe 5.
Este a doua cursa din sezonul acesta in care Schumi e foarte bun doar in ultima parte a cursei. La Hockenheim chiar a reusit fastest lap. Ii iese insa numai cu masina usoara (benzina aproape terminata) si gume soft noi. Cand masina e grea, e lent.
Pe de alta parte, Rosberg a plecat de pe 22 si a terminat pe 10 - un rezultat remarcabil.
Mercedes a avut si o strategie diversa cu 3 opriri la boxe,strategie care a fost buna doar pentru rosberg,nu si ptr schumi,insa vreau sa zic ca sauber cu kobayashi si perez au facut o cursa frt buna,perez de pe 17/6 iar japonezul daca nu ma insel de pe 12/5,destul de impresionant.
s-au retrat din cauza politicii care s-a aplicat in cazul Kers . Odata ce de la FIA l-au facut obligatoriu , BMW a investit enorm in chestia asta , dupa aia s-au sucit cei de la FIA si au zis ca nu mai e obligatoriu. Celor de la BMW nu le-a convenit joaca asta de regulile si s-au retras.
Exista vreo sansa sa se intoarca in competitie, in viitorul apropiat?
Te gândești la Superbike și S1000RR care ar putea fi transformat pentru MotoGP? Ăn SBK Melandri are 5 victorii cu BMW și ĂŽn general n-aș zice cĂŁ stĂŁ rĂŁu. De fapt ĂŽn general unde a concurat BMW nu a stat niciodatĂŁ foarte rĂŁu (vezi și DTM, unde din pĂŁcate piloții BMW au și curse fĂŁrĂŁ puncte și tot sunt aproape, mĂŁcar de locul 2). Ăn F1 atunci se spune cĂŁ ar fi fost ĂŽn luptĂŁ pentru titlu, dar au tĂŁiat efectiv finanțarea ĂŽn urma unor mĂŁgĂŁrii din partea "F1".
Hamilton a fost genial azi. PĂŁcat, un an cu ghinioane. Button pare cĂŁ revine ĂŽnsĂŁ.
Kimi se luptĂŁ cu strategiile și calificĂŁrile. Grosjean e ghinionist și el.
Vettel ĂŽn schimb are noroc ĂŽn prostie.
Vettel a fost penalizat cu 20 de sec pentru depasirea care a facut-o asupra lui button in penultimul tur,a depasit cu toate rotile inafara pistei si a fost sanctionat,asta inseamna ca a terminat cursa pe 5,button pe 2,raikonnen pe 3 si kobayashi pe 4!
A avut performante destul de bune in ultimele curse, dar masina nu-l ajuta deloc, nici pe el, nici pe Rosberg.
Rosberg a plecat de pe 17, dar Massa a avut un accident cu Ricciardo la start, Grosjean si Hamilton au avut si ei probleme, plus ce a mai castigat la start. Puteai sa il lauzi daca facea o cursa gen Webber anul trecut in China! Altii au plecat ultimii si au ajuns pe podium, pur si simplu masina celor de la Mercedes nu este la un astfel de nivel inca.
Schumacher a avut in fata un Red Bull si un Ferrari, iar din spate au venit tare si Button si Raikkonen, toti cu masini peste Mercedes-ul sau, nu poti compara caderea lui in clasament cu ascensiunea lui Rosberg. Termina in orice caz pe 5 daca nu avea trei opriri la boxe, monopostul insa nu e la nivelul celor de la Ferrari, McLaren, Red Bull, iar in cursa si Lotus ii bate. Pana si Ross Brawn si Norbert Haug au declarat ca mai au de lucru.
Chiar nu cred ca ii poti acuza pe piloti de nimic, si-au facut treaba, cat despre Schumacher, performantele lui s-au imbunatatit considerabil, dar a facut ce a putut cu masina pe care a avut-o la dispozitie.
Te gândești la Superbike și S1000RR care ar putea fi transformat pentru MotoGP? În SBK Melandri are 5 victorii cu BMW și în general n-aș zice că stă rău. De fapt în general unde a concurat BMW nu a stat niciodată foarte rău (vezi și DTM, unde din păcate piloții BMW au și curse fără puncte și tot sunt aproape, măcar de locul 2). În F1 atunci se spune că ar fi fost în luptă pentru titlu, dar au tăiat efectiv finanțarea în urma unor măgării din partea "F1".
Grosjean face mult prea multe greseli, nu e vorba de ghinion. De la inceputul sezonului a avut o groaza de incidente, majoritatea din vina lui!
Cat despre BMW in F1, mie imi pare rau ca au parasit competitia. Au pornit destul de bine in 2006 si au progresat destul de mult pana in 2008! Era interesant sa vedem ce s-ar fi intamplat daca ramaneau.
Edited by Ady320Cd
Nu sunt așa de sigur cĂŁ la ĂŽnceput a fost scos ĂŽn afarĂŁ din vina lui. Din ce se poate vedea, a fost lovit, nu-mi dau seama exact de cĂŁtre cine. DupĂŁ primele curse, ĂŽși revenise destul de bine cu incidentele. Buba e și stilul haotic acceptat oarecum tacit ĂŽn GP2 pe care l-a practicat cu succes. Și de departe nu e singurul pilot care face manevre aiurea. Numai azi Kimi a evitat vreo 2 accidente clare, nu mai zic alte momente delicate. Evident cĂŁ Grosjean nu are mâna formatĂŁ pentru așa ceva, dar oare câți au.
SĂŁ vedem ce face Alonso de ziua lui la unguri. Deși mie nu-mi plac nici Alonso, nici Ferrari. Azi mi-au plĂŁcut cei de la Sauber. Ba chiar și "indienii".
