Totul despre codare
Alex_wly
Pentru 2007 poti sa iei si ieftineaua, majoritatea oamenilor, din ce am citit eu pe e90post si pe bmwcoding o recomanda pe asta:
http://www.ebay.com/itm/160845701117?item=160845701117&viewitem=&sspagename=ADME:X:RTQ:MOTORS:1123&vxp=mtr
Pai si ce are diferit dpv harware fata de cea ieftina de 30euro? Din ce vad eu e identica. Pretul asta e exagerat.
E diferit hardware-ul.
Rasfoieste putin aici daca chiar te intereseaza sa stii diferentele, e diferit chip-ul din ele, cat dai atata face:
http://www.e90post.com/forums/showthread.php?t=451145&page=13
The new ones onestop and doitauto.de are selling are Rev 2.00.
Ever since onestop and doitauto.de has been pushing out their new cables many china suppliers are trying to replicate them and sell them for 20-30$ less.
I've provided close up photos of the K+DCAN cable by one-stop.
Micro controllers made by ATMEL. High-quality indeed. Made in China FOR THE WIN.
I've been coding for quite some time now... and honest to say this cable(onestop K+DCAN) is the closest one to a real OMITEC interface.
Do not believe everything you hear, see it for yourself!
Edited by InSidE
Am facut si eu operatiunea de decositorire a pinului 7 de 8 , exact cum zice si aici http://www.e90post.com/forums/showthread.php?t=672940.
Spune ca din 03/2007 incolo ... "I modified my D-can cable and installed a switch in order to have it operational with 2006 and earlier models that use the OBDII port. My cable did not come with an adapter... 2/2007 and older vehicles requires the pin 7 and 8 to be bridged to work..3/2007 and later requires pin 7 and 8 to be separate. So for 2 bucks at Radio Shack and about 20 minutes of my time, I have a fully functional cable for both applications!"
> 03/2007 ce ar inseamna? Trebuie sa existe o limita undeva prin 2008 , unde s-a schimbat protocolul.
Acum pentru cine se pricepe.
Value(valoarea) " c:\ediabas\bin" din variabila "ediabas_config_dir" apare in Environment Variables si apare si in "Path(cale)" la value. E bine sa fie asa sau o singura data?
http://imageshack.us/a/img831/4307/var1g.png[/img]"]http://imageshack.us/a/img831/4307/var1g.png
http://imageshack.us/a/img542/9480/var2b.png[/img]"]http://imageshack.us/a/img542/9480/var2b.png
Edited by Andrei_VUV
Pentru ca nu mi-a raspuns nimeni il mai pun o data:
Pe windows 7 starter 32bit va merge NCS-ul? La laptopul mic(10") cu 7 nu-mi merge ca nu vede aplicatiile de 16bit. Am respectat metodele DIY de instalare,am cautat si niste emulatoare de Dos,am modificat prin registrii ceva si tot nu merge,da aceeasi eroare.
La celalalt laptop(15.4") cu windows vista 32 bit am reusit instalarea si functioneaza fara probleme si NCS si INPA.
Cu DosBox am incercat. Se zice ca face treaba dar nu vrea pur si simplu. Chiar nu inteleg desi am facut cap coada tutorialul.
Ori o fi avand ceva versiunea asta de W7 Starter de nu accepta aplicatii 16bit?
La mine, pe un ASUS EEPc de 10 cu Win7 Starter, merg perfect Carsoft, Inpa, DIS și Progman. Inpa, Carsoft și DIS mi le-a instalat prin TEAMVIEWER persoana de la care am cumpĂŁrat interfața. Eu am incercat ulterior instalarea lor pe un laptop normal, dar nu mi-a reușit, deoarece nu mai știu exact cum se instaleazĂŁ ... :(
Deci la tine, problemele sunt sigur ori de la soft, ori de la pașii de instalare.
Ma poate ajuta cineva cu o lista cu ce trebuie codat la E60 dupa ce am pus stopurile LCI ? Am cabluri adaptoare si vin direct cu mufele si un fir in plus care este doar la un capat prins . Cu el ne`prins in celalalt capat imi da eroare la becul de frana , apoi daca il pun la pinul becului de frana nu mai da nici o eroare , dar nu imi place ca stau toate becurile aprinse , dar nu la putere maxima .
Ma amuzi :laugh: Daca tu ai luat teapa si ai luat interfata cea mai ieftina, nu inseamna ca toata lumea o sa faca la fel
Nu merge la toate masinile, interfata aia doar la masini sub 2007!
BALA are una identica si spune ca functioneaza perfect, la noi ne trebuie D-CAN care ai recomandat-o tu, are alt "miez" inauntru chiar daca arata identic
Cand ajunge interfata din hong kong, eu deja is perfectionat in instalare programe.
Edited by smiley32
