Farurii si stopuri aprinse
Buna seara. Acum aproximativ o ora am parcat masina in fata blocului, iar acum cand m-am uitat pe geam am observat ca mi s-au aprins farurile. Am deschis-o din telecomanda, am inchis-o dar tot nu se sting. Intre timp am observat ca din cand in cand se mai si comuta dupa faza scurta pe pozitii. Comutatorul din masina este pozitionat pe auto, dar nici daca il dau pe 0 nu se opresc farurile cand o inchui. Stie cineva care ar putea fi explicati(problema)?
Car Access System (CAS) in Comfort start with immobilizer function
The following functions are grouped in the Car Access System (CAS):
· Terminal control
· Comfort start with electronic car immobilization system
· Remote control
· Central control of the central locking system
· Central control of the power windows
· Gateway module for K-CAN
Terminal control
Terminal R and 15 as well as the cable for activation of the data bus PT-CAN (wake-up line, terminal 15 WUP) are controlled in the CAS.
· When the remote control is inserted in the ignition lock, the CAS transmits the information (terminal R On) via the data buses K-CAN SYSTEM and K-CAN PERIPHERIE. Control units that are active as of terminal R (e.g. wiper module) are thus activated. There is no separate cable for terminal R.
· When the remote control is inserted in the ignition lock and then the start-stop button is pressed, terminal 15 is switched on. The CAS forwards this information across the data buses to the control units. In addition, CAS has four terminal 15 outputs to which control units or release relays are connected.
· When terminal 15 is switched on, the control units on the data bus PT-CAN are activates (woken up) across the cable terminal 15 WUP.
Edited by roninbz
