Sezonul 2013 - F1
4EST
Astazi incep testele de la Jerez si prin aceasta, mai mult sau mai putin si noul sezon 2013! Oricum in aceste prime patru zile, echipele vor testa fiabilitatea si nu vom avea o parere prea buna legata de performanta monoposturilor!
eu nu cred. Uite cat efort depune Ferrari si nu reuseste sa treaca de Red Bull (si nici de McLaren de fapt)
Mercedes in 2012 se lupta cu Sauber, Force India. Si mai au de trecut si de Renault, care au fost pe val anul trecut.
Si nu vad motive sa se schimbe tendintele din 2012 anul acesta
ma rog.... Lotus/Renault. Si Lotus este echipa care a acumulat mai mult decat DUBLUL punctelor Mercedes
Deci daca Red Bull si Ferrari au avut peste 400, Mclaren si Lotus au avut peste 300, Mercedes a fost in pluton cu Sauber si Force India cu peste 100
acuma citesc ce scrie gary anderson despre noul mercedes si nu e deloc impresionat, si deobicei are dreptate
At first glance I can't see where the 'step change in performance' Mercedes are talking about is going to come from with their new car.
"There are a few changes here and there, but not necessarily in ways that look like they will be a big advantage.
"One area that is definitely working a bit harder is the front brake ducts, which are more elaborate.
"The nose has the allowed 'vanity panel' to hide the height difference between nose tip and chassis. If you put little ridges on either side of the nose, that can help prevent air spilling over the side. But the way Mercedes have designed their nose it looks like it will exacerbate that problem, which affects the aerodynamics detrimentally.
"The sidepods have a raised outer edge. It's aimed at getting air to the rear but it creates lift, and then there are turning vanes on top to reduce the lift. So that confuses me a little.
"They are trying to use the exhaust for aerodynamic effect at the back, but there is an awful lot of bodywork back there which will block the airflow and reduce the effectiveness of the 'coke-bottle' shape, which is what gives overall downforce, as opposed to the on-throttle downforce you get from the exhausts.
"Unlike the McLaren, which looked a step forward in every area, I wouldn't necessarily say I'm seeing anything too exciting about the Mercedes
Acesta e "volanul" complet a lui Kimi
http://img.gawkerassets.com/img/18cxc2dc1shckjpg/original.jpg
Acum noi glumim, dar butoanele alea chiar daca au alta semnificatie, exista. Cam cat timp iti ia sa inveti ce face fiecare setare? :p
Sunt 9 butoane care se rotesc, unele si cu 15 setari
si cel putin 12 butoane de apasat
Edited by 4EST
Oricum ar fi sa le utilizeze iti poti da seama ca exista o sumedienie de variante, ori ca sa stii care e varianta optima si ca sa si apuci sa faci setarea(actiunea propriu-zisa) in timp ce manevrezi masina cu viteze de 100-200-300km/h adaugand tehnicitatea traseului si fortele care se exercita asupra organismului fara sa mai punem la socoteala situatiile din dueluri sau aglomerarile de pe pista ma gandesc ca ar grebui sa avem rabdare cu Grosjean si mai multa ingaduinta. :smile: Edited by ionatan
Imi aduc aminte in ultimii ani in care a concurat Schumi, de multe ori inginerii de imagine a transmisiunilor fixau camera on board pe el si se vedea cum, ĂŽntre 2 viraje, cu o mana schimba mereu setarile monopostului. Asta numesc eu arta in pilotaj. Ce drept, pe vremea aia nu erau chiar asa multe butoane pe volan ca acum.
Jerez, prima zi - 05.02.2013 (sursĂŁ: Mercedes)
Pos.
Driver
Car
Time
Laps
1
Jenson Button
McLaren
1:18.861
37
2
Mark Webber
Red Bull
1:19.709
73
3
Romain Grosjean
Lotus
1:19.796
54
4
Paul Di Resta
Force India
1:20.343
89
5
Daniel Ricciardo
Toro Rosso
1:20.401
70
6
Felipe Massa
Ferrari
1:20.536
64
7
Nico HĂźlkenberg
Sauber
1:20.699
79
8
Nico Rosberg
Mercedes
1:20.846
14
9
Pastor Maldonado
Williams
1:20.864
84
10
Giedo van der Garde
Caterham
1:21.915
64
11
Charles Pic
Marussia
1:24.176
29
Multe dintre setari ii sunt dictate de la boxe. Pilotul de obicei modifica distributia franelor fata/spate pe diferite sectoare ale circuitului, foloseste KERS, Radio si DRS. In rest, din ce am vazut eu primeste din cand in cand indicatii de genul "comuta butonul X pe pozitia Y", in functie de datele obtinute prin telemetrie de cei de la echipa de ingineri.
3 butoane, 4 vrajeli. daca la schumi era arta pilotajului, ce sa mai zicem Clark, Fangio, Stewart, Senna, Lauda? cand pe vremea aia murea cel putin un pilot pe sezon..
