S-a aprins un ceas pe bord?!?
  • Replies 55
Posted Images
Sigur. Bineintele ca nu si invers (adica daca ai in specificatiile masinii DOT5 nu poti pune DOT4). Insa cei care au in specificatii DOT3 sau 4 pot pune fara grija DOT 5.1 de la OMV ( e cel mai bun de pe piata, nu cum sunt majoritatea expirate deja). Edited by Wolfman
DOT 3
From Wikipedia, the free encyclopedia
"DOT 3 is one of several designations of brake fluid denoting a particular mixture of chemicals imparting specified ranges of boiling point.
In the United States, all brake fluids must meet federal standard #116. Under this standard there are three Department of Transportation (DOT) minimal specifications for brake fluid. They are DOT 3, DOT 4, and DOT 5.1.
DOT 3, like DOT 4 and DOT 5.1, is a polyethylene glycol-based fluid (contrasted with DOT 5 which is silicone-based). Fluids such as DOT 3 are hygroscopic and will absorb water from the atmosphere. This degrades the fluid's performance by drastically reducing its boiling point. In a passenger car this is not much of an issue, but can be of serious concerns in racecars or motorcycles.
Deci 5.1, nu 5 care este intr-adevar pe baza de silicon.
Edited by Wolfman
  • 1 year later...
am pornit azi masina si mia aparut ceva in bord arata ca un ceas galben si cu 2 lini dupa un timp a disparut , e prima data cand imi apare si de aceea intreb ce poate sa fie... apare cand face inspectia cand pornesti..plls help masina e e36 din 91 318
o poza poti sa ne arati ?
te avertizeaza ca trebuie sa schimbi uleiul
nu cumva arata ca un cesulet? daca da inseamna ca trebe schimbat lichidu de frana
Defapt inseamna ca a trecut 1 an de zile de cand masina nu a mai fost in service! (nu are treaba lichidul de frana) scrie chestia asta si in cartea tehnica, plus ca la masina mea am schimbat lichidul de frana si dupa 1 an s-a aprins din nou! cesuletul acela apare odata cu Inspection.
Partea cu schimbatul uleiului de motor ar trebui ca esti deja pe galben :)
Bafta...
Edited by Lt.Powell
si eu sunt de aceeasi parere...uleiul...
  • 3 months later...
de 2 zile cind pun contactul imi afiseaza normal citi km mai am de facut cu uleiul respectiv dar mai nou chiar deasupra imi mai si un afiseaza si un ceas ,ce semnificatie are?multumesc
schimbare lichid de frana ..
Edited by myxage
