E65: steptronic
Romulus
Sport program and manual operation
If you press the S/M/D button on the
steering wheel, the Sport program is first
activated and displayed by means of S in
the program indicator in the info display,
see page 56. This program is recommended
for a driving style that places the
emphasis on performance.
If the S/M/D button is pressed a further
time, you enter the manual mode, then a
further press returns you to the Automatic
program.
You can also move back to position D if you
wish to return to the standard Automatic
program.
If you briefly press the buttons on the back
of the steering wheel in the manual mode,
the transmission shifts up. When the
buttons on the front of the steering wheel
are briefly pressed, the transmission shifts
down. M1 to M6 appear in the info display.
Up- and down-shifts are performed only at
a suitable engine or road speed; for
example, the transmission will not shift
down if the resulting engine speed would
be too high. The info display shows the
selected gear briefly, followed by the gear
actually in use.
For rapid acceleration in the manual
operating mode, for example when
overtaking, shift down manually or by using
the kick-down.
"S/M/D button" fiind cel din dreapta sus, de pe volan.
  • 3 months later...
La naiba. Am apasat butonul ala, dar nu m-am prins ca face ceva. In schimb la un moment dat am sesizat un S pe ecran si nu stiam cum am ajuns pe sport. Silly me.
187602[/snapback]
Apesi p el, cind ai S este sport, cind ai M6,M5,M4 esti pe manual. poti schimba viteza numai in jos de pe volan. In sus se schimba pa la 6500 ture singur.
230004[/snapback]
Adica:
cind nu ai nimic pe ecran cutia e setata normal
cind ai S pe ecran, cutia e setata SPORT si schimba altfel, la turatii mai mari, si parca mai repede.
cind ai pe ecran M urmat de o cifra esti setat pe maual iar cifra reprezinta viteza in care esti, M1, M2...M6.
La setarea asta nu poti sa schimbi vitezele decit de la mare la mic, nu te speria nu schimba decit daca se poate, nu poti sa schimbi dintr-a 4 in a 1-a si sa o pui in cap, nu te lasa calculatorul.
Schimbarea o faci de la butoanele de pe volan, oricare stinga sau dreapta. Butoanele sunt cele din dreptul degetelor mari si nu au nici un semn pe ele.
Accelerezi la blana si cind ajunge la turatia maxima schimba singura de la mic la mare.
Cam asta e.
Adica:
Cam asta e.
235780[/snapback]
Eronat.Cand esti pe modul Manual poti schimba vitezele crescator din butoanele aflate pe partea din fata a volanului dar si descrescator din cele aflate in spatele volanului.Astfel poti avea frana de motor reducand viteza din 4 in 3, din 3 in 2 si tot asa din 2 in 1.In cazul in care esti pe manual si nu schimbi viteza in treapta superioara o schimba singura cand ajunge in zona rosie pe la 6500 rpm.
:blink: :)
:blink:  :)
235884[/snapback]
ERONAT.
Tocmai asta spuneam, poti sa schimbi descrescator de la butoanele din partea din FATA a volanului, in partea din spate nu sunt butoane. :))
poate ai tu, eu nu am asa ceva.
ERONAT.
236093[/snapback]
Ai E65 si nu exista butoane in partea din spate? :)
Este model comanda speciala? :blink:
236162[/snapback]
Nu e, adica nu cred ca e special. Orcum asa cum ti-am spus nu pot schimba decit descrescator de la butoanele din fata.
236800[/snapback]
Probabil ai o problema ceva, masina e dotata asa cum ti-am povestit mai sus cu butoane si pt crestere treapta viteza si pt descrestere.
din ce an e masina?
ERONAT.
Tocmai asta spuneam, poti sa schimbi descrescator de la butoanele din partea din FATA a volanului, in partea din spate nu sunt butoane. :blink:)
236093[/snapback]
Daca ai E65 ERONAT nu se poate sa nu ai butoane ptr modul manual in spatele volanului , poate nu te-ai uitat tu bine
  • 3 months later...
