E39 525i 2001/09 probleme motor
Salutari
Poate cineva sa ma ajute cu ceva sugestii, de unde as putea sa incep sa caut hiba sau hibele.
Masina merge neregulat, iar la rece face ceva zgomote ciudate la motor?
Pe tester apar urmatoarele:
CB/71 - Oxygen sensor control, bank 2, control limit, mixture limit rich
CA/71 - Oxygen sensor control, bank 1, control limit, mixture limit rich
F2/B2 - Misfire, cylinder 5, misfiring during warm up, worsening emissions (Misfire CARB_B1)
F0/B2 - Misfire, cylinder 3, misfiring during warm up, worsening emissions (Misfire CARB_B1)
F1/B2 - Misfire, cylinder 4, misfiring during warm up, worsening emissions (Misfire CARB_B1)
E3/71 - Oxygen sensor controller, bank 1, deviation too great, deviation rich
E4/71 - Oxygen sensor controller, bank 2, deviation too great, deviation rich
Shadow-memory:
5A/12 - Exhaust temperature before catalyst, bank 1, signal line, short circuit to negative
5B/12 - Exhaust temperature before catalyst, bank 2, signal line, short circuit to negative
5D/12 - Exhaust temperature after catalyst, bank 2, signal line, short circuit to negative
Errors after clear:
no errorsShadow-memory:
Multumesc anticipat.
