bec placute bord
czr
dupa ce schimbati placutele....daca nu ati asteptat sa se duca de tot si senzorul,si inca sta aprins indicatorul in bord,se procedeaza asa(am gasit pe autodata updates):
After replacing brake pads, depress brake pedal several times to bring pads into contact with discs.
Top up brake fluid level to maximum.
Turn ignition key to position I.
After approximately 30 seconds brake pad wear indicator should extinguish.
merge?
merge?
195302[/snapback]
Incearca si vezi !! :blink:
