potrivire jante 17'' - e92
extasy
nu te arunca
eu am luat un set de jante styling 103 de la unul care vroia sa le monteze pe 335i si nu se potriveau, cred ca et 47 era mult prea in interior....verifica pe catalogul online intai
La 335 etrierii si discurile sunt mai mari decat la 330 si cred ca-i atingeau jantele de etrier fiind prea bagate in interior.
BMW Wheel Hub diameter and sizes, Hub Centre Bore Sizes and ET/Offset
All ET/OFFSET is still dependent on tyre and wheel size so bear this in mind if you are trying to fit wheels from one model to a different model, also if the car is lowered then you may have issues with rubbing/non fitment due to fouling.
The higher the ET number the more the wheel will sit inside the wheel arch
1 Series E81/82/87/88 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-45
1 Series E82M = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 20-31
1 Series F20/F21 = PCD 5x120, centre bore 72.5mm and M14x1.25 bolt thread. ET 33-53
3 Series E21 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 12-20
3 Series E30 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 15-35
3 Series E30 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 27-30
3 Series E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47
3 Series E36 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-47
3 Series E46 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47
3 Series E46 M3 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. Fronts ET 30-47, Rears ET 20-27,
3 Series E90/91/92/93 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 30-45
3 Series E90/92/93 M3 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 34-37
3 Series F30/F31 = PCD 5x120, Centre bore 72.5mm and M14x1.25 bolt thread. ET 31-47
5 Series E28 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 18-25
5 Series E34 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-20
5 Series E34 M5 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
5 Series E39 = PCD 5x120, centre bore 74.1mm and M12x1.5 bolt thread. ET 15-25
5 Series E39 M5 = PCD 5x120, centre bore 74.1mm and M12x1.5 bolt thread. ET 15-25
5 Series E60/61 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. ET 15-32
5 Series E60/61 xDrive = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. ET 40-46
5 Series E60 M5 (Saloon) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32
5 Series E61 M5 (Touring) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32
5 Series F07 = PCD 5x120, centre bore 72.5mm and M14x1.25 bolt thread. ET 25-41
5 Series F10/F11 = PCD 5x120, centre bore 72.5mm and M14x1.25 bolt thread. ET 33-44
6 Series E24 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
6 Series E63/64 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 14-20
6 Series E63/64 M6 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-20
6 Series F12/13 = PCD 5x120, centre bore 72.5mm and M14x1.25 bolt thread. ET 30-44
7 Series E32 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 19-26
7 Series E38 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-25
7 Series E65/66/67/68 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 10-25
7 Series F01/02 = PCD 5x120, centre bore 72.5mm and M14x1.25 bolt thread. ET 25-41
8 Series E31 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
X1 E84 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-41
X3 E83 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-46
X3 F25 = PCD 5x120, centre bore 72.5mm and M14x1.25 bolt thread. ET 32-51
X5 E53 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45
X5 E70 = PCD 5x120, centre bore 74.0mm and M14x1.25 bolt thread. ET 37-53
X5M E70 = PCD 5x120, centre bore FRONT 74.0mm, centre bore REAR 72.5mm and M14x1.25 bolt thread. ET 18-40
X6 E71 = PCD 5x120, centre bore FRONT 74.0mm, centre bore REAR 72.5mm and M14x1.25 bolt thread. ET 38-40
Z1 E30Z = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread.
Z3 E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-40
Z3 M Coupe/M Roadster = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
Z4 E85/86 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 45-52
Z4 E89 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 29-40
Z8 E52 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
BMW Mini R50/R52/R53 = PCD 4x100, centre bore 56.2mm and M12x1.5 bolt thread. ET 37-48
BMW Mini R55/R56/R57/R58/R59/R60 = PCD 4x100, centre bore 56.2mm and M14x1.25 bolt thread. ET 37-48
Aici zice ca poti pune ET pana la 45. Masina mea care este identica cu a ta are jante cu ET 37, iar tu spui ca ai pe masina ET 40. Deci eu as spune ca poti pune cam cu orice ET pana la 45, chiar daca ET-ul este mai mic decat 30 tot se pot monta, doar ca iti vor iesi putin mai in afara.
