Vreau sa invat sa codez cu NCS Expert
am incercat sa fac o codare si am urmatoarele erori la scriere
ERROR! Modul: COAPI.CPP, Proc: coapiGetAbsPathInfo, LineNr: 01, ErrorNr: 1000
COAPI-1000: error
ERROR! Modul: CBD_PROC.C, ProcNr: 02, LineNr: 10, ErrorNr: 40.
003003'01,SONDERTASTE_PANIKALARM (744d, 2E8h)
ERROR! Modul: CDH.C, Proc: CDHGetNettoDataFromCbd, LineNr: 01, ErrorNr: 1043
COAPI-1043: error during processing CBD-file
CAS2.C05
>> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 1043
SG_CODIEREN
COAPI-1000: error
CAS2.C05
SG_CODIEREN
la citire a fost totul ok
are cineva vreo idee de la ce e ?
si mai am o intrebare
vreau la un e60 sa schimb puterea bateriei ca am pus de 100ah
dar nu am gasit ca optiuni decat
KLASSE_BATTERIE 00101107 (01) FF BATTERY TYPE
wert_00 00 00 value 00
80ah 01 01 80 ampere-hours BATTERIE_80AH+!BATTERIE_90AH+!BATTERIE_110AH+!BATT_AGM_90AH+!BATT_AGM_80AH
90ah 02 02 90 ampere-hours BATTERIE_90AH+!BATTERIE_80AH+!BATTERIE_110AH+!BATT_AGM_90AH+!BATT_AGM_80AH
110ah 03 03 110 ampere-hours BATTERIE_110AH+!BATTERIE_80AH+!BATTERIE_90AH+!BATT_AGM_90AH+!BATT_AGM_80AH,(E60,E61,E63,E64)+!(BATTERIE_80AH,BATTERIE_90AH,BATTERIE_110AH,BATT_AGM_90AH,BATT_AGM_80AH)
70ah 04 04 70 ampere-hours
55ah 05 05 55 ampere-hours
46ah 06 06 46 ampere-hours
70ah_agm 07 07 70 ampere-hours (agm)
90ah_agm 08 08 90 ampere-hours (agm) BATT_AGM_90AH+!BATT_AGM_80AH+!BATTERIE_110AH+!BATTERIE_80AH+!BATTERIE_90AH
60ah_agm 09 09 60 ampere-hours (agm)
80ah_agm 0A 0A 80 ampere-hours (agm) BATT_AGM_80AH+!BATT_AGM_90AH+!BATTERIE_110AH+!BATTERIE_80AH+!BATTERIE_90AH
ce fac o las la 90ah sau o pun la 110ah ?
cum o fi mai bine ?
Edited by razzzzvan
Am schimbat codarea din CAS in 110ah de la 90 ah la e60
am citit dupaia CAS-ul si s-a salvat codarea este 110ah
m-am uitat in DIS ca s-o inregistrez si imi apare tot de 90 ah
dupa, am facut ce a facut baiatul asta, cu -B110
1. Open NCSEXPERT
2. File > Load profile > Select Expertmode > Click OK
3. Press F1 (VIN/ZCS/FA)
4. Press F3 (CS/FA f. EC) > Select E89 > Click OK > Select CAS > Click OK
5. Press F6 (Back)
6. Press F1 (VIN/ZCS/FA)
7. Press F2 (Enter FA) > Select E89 > Click OK
8. A window labeled “Eneter VIN” appears with your vehicles VIN number filled in > Click OK
9. A window labeled Enter FA appears > scroll to find VO for old battery (-B090) > highlight –B090 and press delete on keyboard
10. Enter –A080 is “Attribute” box > Click Add > Click OK
11. Press F6 (Back)
12. Press F4 (Process ECU) > Select CAS > Click OK
13. Press F2 (Change Job) > Select FA_Write > Click OK
14. Press F3 (Execute Job)
15. Verify that the write is complete “Job Ended”
16. Press F1 (Change ECU) > Select FRM > Click OK
17. Verify lines : get coded, FRM, JOBNAME = FA_Write
18. Press F3 (Execute Job)
19. Verify that the write is complete “Job Ended”
20. Press F6 (Back) > Exit NCSEXPERT
si tot asa imi arata in DIS, tot de 90 ah
m-am uitat in LCM sa vad daca gasesc vreo codare legata de baterie si nu am gasit
ce sa-i fac ca sa-mi apara in DIS 110ah cand ii dau battery registration ?
unde mai trebuie shimbata vreo codare legata de baterie in agara de CAS ?
Edited by razzzzvan
pffff....asa e ... ziceam de tine ca ai zis de lcm ...dar si eu am chiflat-o intrebandu-te de FRM.... ala nu e la E60 :))) m-am luat dupa pasii ce i-ai pus mai sus in care te pune sa salvezi noul FA in CAS si FRM
la e60 salvezi FA-ul in CAS si LMA cum ai facut tu ... dar mai trebuie sa te joci cu Tool32.
vezi aici :
http://5series.net/forums/diy-do-yourself-14/coding-registering-new-battery-114909/
in LMA nu trebuie sa codezi, trebuie sa modifici FA sau VO cum vrei tu sa ii spui la fel ca si in CAS.
Dupa ce ai salvat noul FA/VO in CAS si LMA golesti fisierul .MAN si ii dai pur si simplu o codare la CAS si la LMA cu acest fisier gol.
Inregistrarea bateriei o faci in INPA sau ISTA/D.
