Urmatoarele piese/accesorii BMW/MINI de vanzare:
Link cu poze: https://photos.google.com/share/AF1QipOo9crJ8CCUqsynNBRx3D9oFvgTT_0sgf0r6hfIdcV54E13sVzSy94fGVXcaow5_Q?key=aGdVZHVxX1JGY3F1cS1sUTJwWE9ZcVQ0WlZWemtR
Pentru alte poze trimiteti PM.
Contact: 0721482853.
- set 4 jante tabla 15" originale BMW, nelovite, stare foarte buna, Germania, 80 RON (gumele sunt gratis)
- scut motor e46 (plastic) sh original BMW Germania 50 RON
- fulie motor M43TU sh stare perfecta orig. BMW, 100 RON
- mecanism echilibrare motor e46 316i/318i M43TU (vine in baia de ulei), 100 RON
- kit distributie BMW E46, E60, E81, E83, E84, E85, E90, E91 si E92 (motorizari N42, N46 si N46N) - 250RON
- mansete fr. mana BMW e46 negru/gri, ca si noi, orig. BMW la 30 RON/buc.
- radio orig. BMW e46 reverse, ca nou, 40 RON
- rama standard radio/clima e46, 20 RON
- torpedou e46 pe negru, 30 RON
- sertar 4 casete nou si orig. BMW (se monteaza in consola), 20 RON
- trim pt 2 geamuri el. e46 pe anthrazit/argintiu, 30 RON
- calculator + senzori airbag e46 316i 1999, 60 RON
- set mansete originale noi directie e46, 50 RON
- bielete int/ext directie e46, sh si originale, stare buna, 15 RON/buc
- cutie de viteze completa e46 316i/318i cu motorizare M43TU, 200 RON
- diferential E46 316i benzina, raport 3.23, carcasa mica, garantie, Germania, 100 EUR
- etrieri fata e46 sh orig. BMW 25 RON/buc
- placute frana noi e30, vezi poza in link, 30 RON
- al 3-lea stop de frana e46 sedan, 20 RON
- 4 stopuri (2 mari, 2 mici) E46 sedan fara facelift in alb/rosu, cele mari au socluri, originale, impecabile, 120 RON
- stopuri si semnale de E46 sedan cu/fara facelift, originale (rosu/portocaliu) toate 6, impecabile, 80/50 RON
- compresor clima sh original BMW 64526905643 320d facelift 150CP, 150 RON
- compresor clima sh original BMW X5 3.0L benzina si diesel, 150 RON
- klimatrockner / drying container E46 sh BMW 64 53 8 377 330, 20 RON
- furtune clima 316i/318i/320d, 10 RON/buc
- DME + EWS E46 M43, BMW 1 430 940, 200 RON
- Grundmodul E46 (inchiderea centralizata si altele) varianta High/Low (4/2 geamuri electrice), 120 RON
- unitate ASC orig. BMW(toate E46 fara facelift) sh Germania, ca noua, 150 RON
- debitmetru M43(316i si 318i fara facelift) BMW 13 62 1 433 565, nou, original BMW, garantie 2 ani, 300 RON
- debitmetru M43 GERO Germania, 1 an garantie, 50 RON
- racord cauciuc sh flexibil debitmetru e46 M43TU, 20 RON
- debitmetru diesel EU4 orig. BMW 7 788 744 (M47N, M57N) sh, netestat - 30 RON
- toba mijlocie + spate E46, Motor M43, 316i 318i/ci, noi, toba finala e originala BMW, 100 EUR
- pt toate E46: chit trecere clima manuala ---> climatronic (3 motorase + cablu), 50 RON
- modul climatronic E46, impecabil, cu sau fara AUC, 50 RON
- radiator caldura interior e46, 20 RON
- aeroterma e46 (fan-ul), 80 RON
- canale/guri aer interior e46, 10 RON/buc.
- radiator apa/clima e46, 80 RON/buc.
- intinzator curea original BMW 7 512 758 clima, motor M52/M54, sh Germania, 40 RON
- intinzator curea alternator/pompa apa motor M43 316i 318i sh Germania BMW 1 432 104, 40 RON
- motorase geamuri electrice fata, 20 RON bucata
- system audio HiFi standard E46 facelift HAES cu toate cele 6 boxe, perfecta stare, Germania, 80 RON
- inel glisant volan E46 (cel pe care vin manetele de semnalizare si stergator), 30 RON
- maneta stergator parbriz sedan/touring, 25 RON
- maneta cu BC pentru E34 si E38, 25 RON
- maneta semnalizare pentru E46, nu are BC, gratis
- senzor ABS fata (mufa gri cu 3 pini) pt. toate E46 fara facelift, nou si original, 120 RON
- senzor ABS spate nou orig. pt. toate BMW E46 fara facelift, 120 RON
- senzor ABS fata pt. toate E46 cu facelift, sh si original, 50 RON
- senzor ABS spate sh orig. BMW E46 facelift, 50 RON
- rulment spate nou si original BMW 33 41 1 130 617 , 120 RON
- arcuri fata E46, 70 RON perechea
- pompa frana completa pt. toate E46 fara facelift, 70 RON
- pompa servodirectie 316i/318i fara facelift, 80 RON
- fuzeta completa fata st. E46, 50 RON
- suport punte spate E46 ca nou, fara rugina 100 EUR
- lager mijloc cardan, nou si original, pt. toate E46, 150 RON
- 2X cablu frana de mana E46, 40 RON
- brat aluminiu spate st/dr E46, 25 RON/buc
- brat tabla spate jos E46, 25 RON
- sonda lambda noua, original BMW 7 537 984, 250 RON
- sonda lambda noua, original BMW 11781739845, 250 RON
- sonda lambda sh, rulaj < 10000Km, original BMW 1 247 406, 50 RON
- rampa injectoare e46 M43TU, 50 RON
- clapeta admisie e46 M43TU, 50 RON
- galerie admisie e46 M43TU, 50 RON
- ax came 318i M43 apropape nou (are sub 1000 Km, Germania), original BMW 1 436 853, 80 RON
- tacheti hidraulici, BMW 1 433 672, 20 RON/buc.
- volanta noua originala BMW motor M43 316i/318i fara facelift, 120 EUR
- alternator E46, sh si original, 90A, 100 RON
- bobina aprindere motor M43 316i/318i fara facelift, 50 RON
- disc ambreiaj original motor N40,N42,N46 (316i/318i facelift 09/2003 ->) impecabil, 50 RON
- cablu motor M43 (316i/318i fara facelift) 80 RON
- garnitura motor M43 metal, BMW 1 743 191, 20 RON
- senzor arbore cotit pt. toate E46 fara facelift, nou/sh original BMW, 100/50 RON
- senzor bataie e46, sh orig. BMW, 20 RON
- pompa apa originala noua/sh Germania pt. M43 (316i/318i 1998-2001) 100/25 RON
- termostat 316i/318i M43 orig. BMW cu garnitura noua, 70 RON
- suporturi plastic pt radiator E46, gratis
- valva BMW 1 705 497 originala BMW noua/sh (breather valve) 100/50 RON
- mecanism inchidere portbagaj E46 nou orig. BMW, 80 RON
- balamale portbagaj noi si originale, BMW 41 62 7 001 560 si 559, 80 RON setul.
Deasemenea sunt de vanzare urmatoarele componente NOI si ORIGINALE de BMW/MINI:
- BMW 6 913 711, Eject-Box pentru telefon mobil X5 E53 3.0i si 4.4i varianta SUA
- antifurt roata BMW, vezi model in poza
- BMW 8 360 661, stropitor far stanga pentru toate E39
- BMW 1 247 952, intinzator lant distributie E46 316i/318i cu motor M43TU
- BMW 7 132 865 / BMW 7 141 721, compartimentul din partea soferului la 3er E9x
- fisa bujie motor M43TU, cilindrul 1, vezi poza
- BMW 7 202 868 / BMW 7 134 592, telescop hidraulic la portbagajul de 7er(E65 si E66)
- BMW 1 436 760 + 1 437 343, garnituri capac _chiulasa_(cilindrii 1-4 sau 5-8 5er, 7er, 8er, X5
- scrumiera completa spate E46
- senzor nivel antigel E46
- BMW 1 715 504, sensor presiune/temperatura ulei, 4 bucati
- BMW 7 808 032, convertor de presiune 1er, 3er, 5er, X3, X5
- BMW 6 926 435, modul scaun BMW 1er, 3er, X5, X6
- BMW 7 137 193, ornamente boxe mici, 3 bucati
- MINI 3 422 659, actuator recirculare aer
- MINI 3 422 658, actuator distributie aer
- lumina de interior E46 fara facelift
- BMW 7 697 695, modul DWA
- BMW 8 366 381, modul WiWa(stergatoare + spalator parbriz) E34, E36 si Z3
- BMW 8 368 196, modul inchidere portbagaj E39(-> 09/97)
- BMW 8 352 206, motoras pozitie faruri st./dr. 3er, 5er, 7er, Z4 cu sistem ZKW
- BMW 7 501 564/565, valve regulatoare E31 si E38 in 12 cilindrii(750i si 850i)
- BMW 6 938 563, motoras pozitie faruri st./dr. 1er, 3er, 5er
- BMW 8 365 927, cablu de legatura E65 si E66 + adaptor antena FAKRA
- BMW 7 793 166 + 7 794 495, garnituri motor M47N
- BMW 6 924 112, modul alarma Z3
- BMW 7 162 738, reflectoare laterale albe Z4, 2 bucati
- BMW 6 915 039, reflector rosu spate stanga E60 si E61
- 4 cuzineti BMW 7 532 955, 2 cuzineti BMW 7 522 982
- BMW 7 115 229, inchizator capota 1er, 3er, X3
- piesa ZF 7039 442 113 / 7039 301 108a
- BMW 7 793 800
- 4 site cauciucate
- insemn BMW 1er.
Salut.Detin un E46 Coupe din 2000. Ma intereseaza :
- Oglinda cu degivrare(sticla doar) - pe partea pasagerului
https://postlmg.cc/Mff1LZLy
https://postlmg.cc/JDGXy4M9
- Ornament prag interior BMW E46 coupe - Partea stanga((PASAGER).
https://postimg.cc/3W110WXc
https://postimg.cc/F7Gyzq45
https://postimg.cc/3ksFQGhd
- Cheder portiera dreapta / stanga
https://postimg.cc/6Th2fmpH
https://postimg.cc/F7sfWVfh
https://postimg.cc/nXXXZVY5
- Buton comanda sus - jos geam sofer.
https://postlmg.cc/34Csv71F
https://postlmg.cc/3ksVfWbZ
- Emblema BMW capota si Emblema Janta 1 Buc
Pt. detalii rog trimiteti PM !
- BMW 7 793 800
- 4 site cauciucate
- insemn BMW 1er.
