EWS, Battery & Lumini a intrat pe
Mike85
Cineva mi-a spus cĂŁ am o problemĂŁ cu EWS mea (sistem de alarmĂŁ furt), care este whay mașina nu pornește.
DupĂŁ ce am scos EWS și a pus ĂŽnapoi ĂŽn, baterie, de petrol și de siguranțĂŁ lumini mi centura a venit pe la mea 1997 BMW 740i și trunchiul nu se va ĂŽnchide.
Apoi am aflat cĂŁ bateria este complet mort.
Ceea ce este cauza luminile sĂŁ vinĂŁ pe, ĂŽn cazul ĂŽn care bateria este mort?
Eu sunt la sfârșitul meu inteligența cu aceasta masina. VĂŁ rugĂŁm sĂŁ ajute. Mi-ar aprecia.
In most cases, a broken EWS is going to drain all the power from the battery.
To solve your problem you need a second-hand starting kit for your car (EWS + ECU + keys) or a new EWS from your bmw dealer, or an used EWS + a man who knows how to transfer key & ISN informations from the OLD one in the second hand ews.
after that you can change the battery.
Edited by RobyS
It's better to run a diagnose first.
In only ~20-30euro in Romania for such operation and you will know for sure after that what exactly is the problem and what is the way forward for you.
If you are in Bucharest you can try to go this service. It has good reviews and i am sure that wll help you :)
