Problema INPA e36
Am achizitionat de curand o diagnoza bmw pot citi coduri de pe diferite module insa nu pot intra in engine, am cautat disperat o solutie am observat ca au existat si alti colegi pe acest forum cu aceeasi problema si nu au gasit rezolvare defapt nu au mai primit un raspuns. masina este un bmw e36 318 tds precizez ca am instalat programul bine am ster si ; din fata lui ENTRY si tot degeaba in meniul respectiv nu exista codul motor M41. Stima si multumesc pt eventualele raspunsuri.
In EC-APPS\INPA\CFGDAT in fisierul E36.ENG.
Trebuie sa iti arate asa:
[ROOT]
DESCRIPTION=Select E36 V1.15
[ROOT_MOTOR]
DESCRIPTION=Engine
ENTRY= DDE21,DDE 2.1 for M41,
ENTRY=,,
ENTRY= DDE21,DDE 2.1 for M51,
ENTRY=,,
ENTRY= DME17,DME 1.7 for M42 / M43,
ENTRY= BMS43,BMS 43 for M43,
ENTRY= BMS46,BMS 46 for M43,
ENTRY=,,
ENTRY=DME338K2,DME 3.3 for S50 M3,
ENTRY= MSS50,MS S50 for S50 M3,
ENTRY= MSS54M3,MS S54 for S54 M3,
ENTRY=,,
ENTRY= DME331,DME 3.31 for M50 2.5 l,
ENTRY= DME524,DME 5.2 for M44,
ENTRY= MS401,MS 40.1 for M50 2.0 l,
ENTRY= MS410,MS 41.0 for M52,
ENTRY= MS411,MS 41.1 for M52 US with OBDII,
ENTRY= MS420,MS 42.0 for M52 new,
ENTRY=,,
ENTRY= MS430,MS 43.0 for M54,
ENTRY=,,
ENTRY= VNC,VNC for S50 M3,
ENTRY=,,
ENTRY= CARB,Carb-Interface,
[ROOT_GETRIEBE]
DESCRIPTION=Transmission
ENTRY= gsds2,GS8.xx,
ENTRY=,,
ENTRY= gs41x,GS4.1x,
ENTRY= gs7x_k,GS7.x Data field,
ENTRY=,,
ENTRY= jatco,Jatco for M50 Japan / South Africa,
ENTRY=,,
ENTRY= smg,Sequential M-Gearbox,
[ROOT_FAHRWERK]
DESCRIPTION=Chassis
ENTRY= absasc4,ABS/ASC Mk4 ,
ENTRY=absasc4g,ABS/ASC Mk4G,
ENTRY=absasc4g,ABS Mk20 (DS2),
ENTRY= absasc4,ABS/ASC Mk4G1 (K1),
ENTRY=ascdsc46,ASC Mk20 / DSC E46,
ENTRY= absasc5,ABS5 ASC5 DSC5 DSC3,
ENTRY= dscmk60,DSC MK60,
ENTRY= lws5,Steering angle sensor,
[ROOT_KAROSSERIE]
DESCRIPTION=Body
ENTRY= airbag,Airbag,
ENTRY= sbe,Seat occupation detection,
ENTRY= ews,Electronic vehicle immobilization EWS,
ENTRY= bc_v,On board computer BC5,
ENTRY= uhr_bc,On board computer / Clock UHR/BC E36/7,
ENTRY= dwa4,Anti-theft alarm system DWA4,
ENTRY= cvm,Convertible soft top module CVM,
ENTRY= fern_ss,Remote controls,
ENTRY=klima_5B,Automatic air conditioning IHKA,
ENTRY= ihkr,Air conditioning IHKR,
ENTRY= kombi,Instrument cluster,
ENTRY= pdc,Park distance control PDC,
ENTRY= gr2,Cruise control GR2,
ENTRY= toens,Thermal Oil Level Sensor TOENS,
ENTRY= ueb2,Roll over sensor,
ENTRY= zke4,Central body electronics ZKE4,
ENTRY= zv36,Central locking module ZV36,
PS: Daca in Inpa, E36 iti apare doar la OLD models, trebuie sa adaugi linia respectiva si in BMW_ALT.ENG in sectiunea pt e36.
Edited by Kenbobo
am adaugat in BMW_ALT.ENG si degeaba tot nu imi da voie :no: am facut modificarea si in ALT.GER cu fur si degeaba intrebare aplicatia intra in modul doar cu contactul pus sau e musai motorul pornit? in celelalte intra doar cu contactul pus doar in cluster nu vrea sa intre si in engine Edited by bogdane36e34
deci am facut tot ce ati spus si degeaba in inpa nu exista nici un subfisier cu sp daten nu vreau sa ma dau batut dar cred ca o voi face, stie cineva un alt soft in locul lui inpa cu care pot face o diagnoza sau daca are cineva o versiune mai veche eu nu gasesc care sa contina si M41 si bmw coding nu functioneaza l-am descarcat de vreo 5 ori de pe situri diferite cred ca nu ma pricep deloc:)) Edited by bogdane36e34
nu am cautat in care fisier din INPA se gaseste sg-dat....
ii trebuie ADS; are mufa rotunda, si semnal la pin 15....
si in Ediabas.ini pus ADS
erau cativa care se pricep la codari pe forum,trebuie sa dai search
pana la urma prietene ce mufa ai OBD1,2 sau ADS? eu zic ca ai rotunda
nu am rezolvat abia maine ma re apuc am fost plecat si nu am mai avut timp insa de rezolvat o rezolv eu, insa acum am alta nelamurire mare de tot cu cealalta masina e34 o sa postez in seria 5 problema mufa este rotunda daca DIS este un program nu il am unde in gasesc Edited by bogdane36e34
